Question about Dishwashers
My aeg 60870 sensorlogic dishwasher won't start the wash cycle. The on light are bright red, the salt and filter light are on bright red (soft water area so no need for salt and filters clear). Also the 30 minute cycle and the 40c glass wash cycle are dimly lit. There is no error code in the display panel. The door closes properly. I have tried to cancel the programmes by holding down the buttons. I have tried turning of on the machine and at the plug switch. Nothing appears to work or reset.
How much salt do I need to use; we live in Cornwall water VERY soft have never put salt in b4.
your problem is not the salt, water in cornwall is not soft either, soft water is actually good for your dishwasher... soft water in cornwal is from rain but not from pipes or wells...
i assume this is dishwasher as this question is in dishwasher section. you state that you never put salt before - and why you should put it in now?!? if idea sound st00pid to you - probably it is...
red light indicates that something is wrong, i would start in case of dishwasher with through cleaning of drain filters and drain pump, checking sensors on the doors and injectors, checking seals, then run empty on full cycle and see if anything changes, cannot provide detailed instructions as you did not give any data. i would suggest google it "howto check whateveryourmodelis function free", words howto and free are keywords,whatever you put between them is a question.
now, to have your question answered, you need to state it correctly:
1. what manufacturer
2. what model
3. year of manufacturing
4. what it seem to be a problem
5. what did you try
hope this little intro will help you to solve the problem by yourself, do not forget to vote...
Feb 06, 2015 | Dishwashers
Aeg 60870 dishwasher water not getting in. Error code.10
The most common cause of a fault "i10" is closed valve on the water supply line. So this failure indicates a problem with filling of water.
Possible error causes:
Closed water tap, Inlet valve faulty, inlet hose bent, softener system clogged, pressure switch or pressure switch hose obstructed or leaking, wiring from pressure switch to printed circuit board (PCB), wiring from inlet valve to PCB and finally PCB.
Dado
Oct 04, 2014 | AEG Dishwashers
Washing isnt coming out as clean as it used to... often appearing stained in areas. Filter is always empty of lint. Is there a way i can clean the actual machine???
If you have hard water,,, that is a big if ,,,,, Make sure your softener has pleanty of brine salt and that the softener is working properly. Soft water = bright clean clothes.
Jan 11, 2014 | LG Dishwashers
Aeg electrolux dishwasher wont wash just keeps beeping
well there are several possibility's. What was the washer doing? Rinse or cleaning? If there is standing water in the tub, then the pump went out or is clogged.
Dec 04, 2012 | Dishwashers
Aeg sensorlogic 50700 first showed c2 message; we drained & cleaned filters 3 times; worked half cycle and now showing error message c3?
Error message C3 is most likely indicating the flood switch is triggered. This means water is leaking from under the sump. The C2 error is linked to drain problems which you cleared.
Dec 29, 2010 | AEG Dishwashers
My AEG dishwasher - Favorit no. 60870 sensorlogic - is making a strange noise when on - what should I do?
I don't have the answer - but mine has been doing this too. There's now a metalic/electical smell that has me worried so I've resorted to a basin of water and fairy liquid! Did you solve your problem?
Nov 09, 2009 | AEG 24 in. Favorit 60870M Free-standing...
AEG lavamat 6955 sensorlogic, was showing F2,nowF3
Waited half hour; on start up F3 had cleared..pump overheat? Suspect sticky pump bearing..new pump.
Jun 10, 2009 | AEG Lavamat 88840 Front Load Washer
Where do you purchase the dishwasher salt from I recently purchased the AEG favourit and am having problems sourcing the salt....(brisbane area in Queensland Australia)
if you are in a soft water area then salt is not needed but is essential in a hard water area. normally available from any supermarket
Jul 10, 2008 | AEG Dishwashers
My AEG favorit sensorlogic turbo dry dishwasher keeps bleeping and want start. Im not sure whats wrong with it. I have cleaned the filters and put in new salt and it still wont work. The programme...
hey
I just had the same issue done everything you say above with no joy. i then emptied the water that was in the dishwasher that the filter goes into and its now fine.
good luck
Jun 09, 2008 | Dishwashers
Dishwashers Logo
80 people viewed this question
Top Dishwashers Experts
