Question about Olympus WS-331M MP3 Player
Hard reset button - Olympus WS-331M MP3 Player
Lg g4 reset
To perform a master reset:
1. Back up all data on the internal memory
2. Turn off the device
3. Press and hold the Power and Volume Down buttons until the LG logo appears on screen
4. Quickly release and the resold the power button while continuing to hold the volume down button.
5. Factory data reset appears
6. Use volume down to highlight yes
7. Press power to confirm
8. Volume down again to highlight yes to erase all user data and restore default settings
9. Press power button to reset device
May 14, 2016 | LG G4
How to do a hard reset forgot password?
Hard Reset.
If you have a Android phone or tablet, Power off the device. After device powers down, Hold power button + volume + button, Release power button when device screen appears. Continue holding Volume button + till system recovery opens. Hard Reset or Factory Reset should be available. Hope this helps.
Nov 24, 2015 | Tablets & eReaders
Reset button location
To perform a hard router reset, keep the router powered on. Then, find the unit's reset button, often located on the rear of the device. Use a pen tip or bent paperclip if necessary to depress the button and hold it down. Network administrators are taught to hold the button down for 30 seconds; your router probably does not require waiting that full length of time, but this is a good general rule to follow. After releasing the hard reset button, a router may need up to 1 minute to reboot and resume normal operation.
An alternative method for hard resets involves holding the reset button down for 90 seconds instead of 30, unplugging the router from power and then re-plugging it partway through as described in these instructions for the 30-30-30 hard reset rule. This more involved reset process may not work on some routers and should only be tried if the basic 30 second version does not work.
To avoid Internet connectivity complications, disconnect the broadband modem from the router before performing hard resets.
Mar 01, 2014 | Computers & Internet
Smashed my screen on my mda vario got a new phone now want to active sync in but cant remember my pssword is there a work around?
Yes, you need to perform a hard reset.
To perform a hard reset
1. Press and hold the Comm Manager button and Voice Command
button on the device. At the same time, use the stylus to lightly
press the RESET button.
T-Mobile MDA Vario hard reset soft reset hardreset softreset
2. Keep the Comm Manager button and Voice Command button
pressed, and the following message will appear on the screen:
3. Release the two buttons, and press the Send button to perform a
hard reset
Feb 05, 2011 | T-Mobile MDA Vario Smartphone
My centro is stuck on the hotsync. wht do i do?
You may need to reset your phone by doing a hard reset. Here is how:
Hard Reset
With a hard reset, all records and entries stored in your handheld are erased, except for the default or specimen databases predefined by the manufacturer (but see Extended Hard Reset below). Formats Preferences and other settings are restored to their factory default settings. You can restore any data previously synchronized with your computer during the next HotSync operation. If you're running OS 3.1 or earlier, and you're not using a third-party backup utility like BackupBuddy, you may need to reinstall your third-party applications.
To perform a hard reset:
  1. Hold down the power button on the front panel of the handheld.
  2. While holding down the power button, use the reset tip tool (or similar object without a sharp tip), to gently press the reset button inside the hole on the back panel of your handheld.
  3. Release the reset button.
  4. When the logo screen appears on the screen, release the power button.
  5. When the message appears on the handheld screen warning that you are about to erase all the data stored on your handheld, press the upper half of the scroll button on the front panel of the handheld to complete the hard reset and display the Digitizer screen.
Pressing any other button instead of the upper half of the scroll button will perform a soft reset.
Aug 16, 2010 | Palm Treo 500 Centro
I want to format my ipaq hx2410 please tell me how to do that
To perform a hard reset you need to press buttons 1 and 4 in addition to the reset hole. This should do the trick.
The guidelines for resetting your phone is given below
Performing a Hard Reset
Perform a hard reset only when you want to clear all
user-installed settings, applications, and data from RAM
(Random Access Memory), where data and applications you have
loaded are stored.
CAUTION: If you perform a hard reset, your Pocket PC loses all data
and programs not saved in iPAQ File Store.
1. Press and hold down the Calendar and iTask buttons.
2. While holding down these buttons, use the stylus to
lightly press the Reset button on the bottom of the iPAQ
Pocket PC for about two seconds.
HP iPAQ hx2410 Hard reset
3. When the Pocket PC screen begins to fade, release the
Calendar and iTask buttons first, and then remove the stylus
from the Reset button.
Note: If you simultaneously push and hold the Reset, Calendar,
and iTask buttons for more than two seconds, the battery
disconnects. To restart the device, either plug the device into the
AC Adapter or press the Reset button again.
After performing a hard reset, you may need to reinstall
applications stored in iPAQ File Store to restore shortcuts and full
functionality.
4. The Pocket PC resets and powers on.
To return your iPAQ Pocket PC to factory settings after
performing a hard reset:
1. Tap Start > Programs > File Explorer > My Device.
2. Tap the iPAQ File Store folder to open it.
3. Tap Edit > Select All.
4. Tap and hold the selected files, then tap Delete.
5. Tap Yes to delete all file in iPAQ File Store.
Apr 03, 2010 | MyNetDeals HP iPAQ hx2000/ hx2100/ hx2400/...
On IPAQ hx2700, how do I do a hard reset? I want
loaded are stored.
functionality.
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Sep 23, 2009 | HP iPAQ HX2700 Pocket PC
How di i do a hard reset for the sidekick slide
Hard Reset: stick paperclip in reset hold behind swivel screen and hold down the power button.
or, in other words
Press the power button and reset button at the same time. Unit will vibrate when reset. You can use a paper clip or similiar to hit the reset button located behind the screen.
Jul 15, 2009 | T-Mobile Sidekick II
Need a phone reset
Part 1
Soft Reset
A soft reset tells your handheld to stop what it's doing and start over again. All records and entries stored in your handheld are retained with a soft reset. After a soft reset, the Welcome screen appears, followed by the General Preferences screen.
Use the reset tip tool (see below), or the tip of an unfolded paper clip (or similar object without a sharp tip), to gently press the reset button inside the hole on the back panel of your handheld.
Reset Tip Tool: On most PalmOS handhelds, the stylus that comes with your handheld has a reset tip inside. To use it, unscrew the barrel from the stylus quill.
Double-Soft Reset
If your device doesn't seem to want to power up after a soft reset, and you've checked the other obvious solutions (fresh batteries, power button, contrast wheel, contrast button) you may want to try the 'Double-Soft Reset'. Simply perform a soft reset as directed above, but press the reset button twice in quick succession.
Warm Reset
A warm reset bypasses any system extensions (such as HackMaster hacks, OS patches, Alarm settings, etc) that are loaded on your handheld. Sometimes a damaged third-party application will try to respond to a reset but will fail and cause the handheld to 'hang'. Using a warm reset, you can start the handheld, then delete the damaged application before it has a chance to try to run again. After deleting the application, follow with a soft reset to start up the handheld normally.
To perform a warm reset:
  1. Press and hold the upper half of the scroll button on your handheld.
  2. Using the reset tip tool (or a similar object without a sharp tip), gently press the reset button inside the hole on the back panel of your handheld.
  3. When the Palm Computing Platform logo appears on the screen, release the scroll button.
If you're not sure which application is damaged, you can use a tool like ResetEmu in conjunction with a warm reset to help pinpoint the offending application.
Hard Reset
Never perform a hard reset unless a soft or warm reset does not solve your problem.
Extended Hard Reset
An Extended Hard Reset will completely erase your handheld, and will also bypass the creation of some default databases.
This differs from a normal hard reset, which will automatically create the databases for the built-in applications, and will insert some specimen records into those databases: numbers for Accessories and Technical Support will be created in your Address database, a registration reminder will be created in your ToDo database, and several helpful memos will be created in your Memo database.
In addition, a normal hard reset will also create a Network database with some default Network profiles for your Network panel in Prefs, and a file of several default MIDI alarm sounds will be created.
If you have the Notepad application, a normal hard reset ensures a sample note will appear on your NotePad, and if you have the Mail application, an email message from 'Mail Help' will be automatically inserted in your handheld Inbox.
An Extended Hard Reset will ensure that all of these startup files are not created.
If you decide to perform an Extended Hard Reset and install one or more third-party applications that expect to see the built-in databases present, you may encounter an error. For this reason, it's suggested that after an Extended Hard Reset, you run each of the built-in applications (Datebook, Address, ToDo, Memo, and if installed, NotePad and Mail) at least once to ensure empty built-in databases are created.
After an Extended Hard Reset, you will not be able to select alternate alarm sounds for Datebook alarms, but the default alarm sound will still be heard for appointments with alarms set.
To perform an Extended Hard Reset:
  5. When the message appears on the handheld screen warning that you are about to erase all the data stored on your handheld, press and hold the upper half of the scroll button on the front panel of the handheld.
  6. While still holding down the scroll button, press, in any order, the Datebook button, the Address button, the ToDo button, and the Note/Memo button.
  7. Release the scroll button, to to complete the hard reset and display the Digitizer screen.
Pressing some but not all the buttons while holding the scroll key will result in a normal soft reset. Pressing no buttons while holding the scroll key will result in a normal hard reset.
Feb 18, 2009 | Palm Treo 650 Handheld
Reset
The P300 has 3 kinds of reset mechanisms, 1. Soft Reset: you can keep all DRAM data. Procedure: Push the Reset button 2. Hard Reset/Save SDRAM -- Use hard reset/save SDRAM mode to reset the MobilePro P300 without losing the data in SDRAM. Use this mode if the safe software reset mode doesn't improve system operation. Procedure: Reset Button and Power Buttons at the same time. 3. Hard Reset/ Clear SDRAM: You will lose all data. Use to reset the MobilePro P300 and delete the contents of SDRAM. Use this mode to reset the MobilePro P300 to its factory defaults. This is also referred to as a hard reset/clear SDRAM. **Caution** This procedure will delete all user installed applications and user data. If necessary, back up your data before performing the hard reset. Procedure: Push the Reset, Power, and Record Buttons at the same time
Sep 15, 2005 | NEC MobilePro P300 Pocket PC
Olympus WS-331M MP3 Player Logo
27 people viewed this question
Top Olympus Audio Players & Recorders Experts
pankaj rautela
pankaj rautela
Are you an Olympus Audio Player and Recorder Expert? Answer questions, earn points and help others
