Question about Hampton Bay Ceiling Fan. Chateau Deville 52 in. Deville Walnut
Hampton Bay Chateau Deville with remote stuck in high. Remote works fine for light with dimmer, but will not turn off fan or change speed. Stuck on high.
Have tried replacing battery in remote. Have turned off at breaker panel for possible reset. The light on the fan works fine and dimms and brightens fine. But fan speed is stuck on high, and will not repond to remote to change the speed from high to med or low speed. Have changed frequency codes on both fan and remote. Stuck on high speed
    Top Expert:
  • Hampton Bay Master
  • 44,894 Answers
When you had the batteries out of the remote, did you press all the buttons to be sure one is not stuck? Also, this could be a button failure.
Posted on Nov 21, 2013
Testimonial: "Gracias, y Comprende on the stuck button theory..however have another matching fan in close proximity set on different frequency codes with no problems and they are on seperate remotes. Done all the troubleshooting that is possible noted aboe and have determined it is the non factory installed receiver in the fan assembley , which can be replaced by odering it online."
  • Patti Gregory
    Patti Gregory Nov 22, 2013
    The remote controll (transmitters) are definately not the prob
  • Patti Gregory
    did the most obvious process by elimination tests prior to posting...
4 Suggested Answers
suarezelec20
  • 259 Answers
SOURCE: on its own went from low to high speed and can't slow it down
Windings in the motor shorted out or the switch shorted out.
Posted on Sep 11, 2012
  • 44894 Answers
SOURCE: reverse function on remote control will not work on my hampton bay ceiling fan
You might have to go through stop before selecting reverse.
Posted on Sep 15, 2012
MN_Jack76
  • 45 Answers
SOURCE: Installing a Hampton Bay Trieste ceiling fan, and I don't know where to locate the remote receiver. It doesn't seem to fit in the canopy or the fan base. It is rectangle shaped about the size
If it's a thin rectangular receiver (probably has UC7067 printed on it) It "slides" into the mounting bracket up by the electrical box. If this doesn't help you can call toll free 1-866-600-3267 at http://www.fanmanlighting.com/default.asp and ask for Jack Jr
Posted on Dec 02, 2012
How do I get my ceiling fan and light back on? The remote died, and I have replaced the battery and nothing turns on now. Tried the switch and the cords. Reset the breaker panel and nothing.
Take the ceiling fan down and check to see if there is power in the line going to the ceiling fan, the wires may have shorted out, which can be a major problem (possible fire).
Jan 02, 2016 | Dryers
Hunter fan 27185 has lost speed
Remote controlled ceiling fans can suffer a lapse of memory when there is a power outage. You eliminated the possibility of a dead battery in the remote by installing a new battery, but just to be sure remove the new battery and press all the buttons on the remote to eliminate the possibility of a stuck button then reinstall the battery. Next disconnect power to the fan at the breaker box, not a wall switch or by tugging on a chain. Turn the fan power on again. Using only the remote, check operation.
Apr 20, 2013 | Hunter Dryers
Remote lights up when pushing but does not make fan go
First of all, remove batteries from the remote and press all the buttons to eliminate the possibility of a stuck button. Reinstall the batteries or install new batteries.
Next, turn off fan power at the breaker. Pause, then turn on the breaker.
Try the remote again
Jan 11, 2013 | Hampton Bay 24002 Ceiling Fan
My Redington IV ceiling fan with remote controller is stuck at low speed. I can turn on/off light and on/off the fan but can't change speed. It just happened recently after about three years of working...
It's possible the fan is in reverse and some fans will not on function faster or lower speeds, check for a switch on the side of the fan just above the blades.
May 27, 2011 | Hampton Bay 52 In. White Redington...
Hi my control will completly work fofr the fan, but with the light it will only dim it and make it bright it wont turn it off from the remote, only by pulling the chain or the master switch i can turn the...
Possible that the ,main unit has a fault as the control signals are not processed. You will need to confirm your remote to be working fine specially with the light switch ON and to brighten up.
If the remote is not working check the pads of the remote.If not the fault can be the main unit possible failure of the SCR/Thyristor or a possible control unit..
Oct 29, 2010 | Hunter 52" Ceiling Fan With Light And...
My Hampton Bay ceiling fan runs only on high speed and the remote has stopped working even after changing the batteries. Does Hampton Bay have a life time warranty?
Yes, look up www.hamptonbay.com and get their contact number from them. It sounds like your transmitter (Remote) has failed. If it were the receiver the fan would most likely not work at all.
Jun 09, 2010 | Hampton Bay 52 In. White Redington...
My ceiling fan suddenly stopped working. It has a remote and 2 pull chains, and neither the light or the fan are working. Only button i see on side of fan is a slide button that controls direction of...
Did you notice if there was anything else not working in the house? If so, most likely a breaker tripped. If it did, then there is a problem with the circuit. Unplug everything on this circuit and try resetting the breaker. If it still has problems, call in a licensed electrician to troubleshoot the problem.
Did anyone work on anything prior to this event? May be a loose connection. turn off ALL the power in the electrical panel before you work on the fan because you have no idea which breaker (or fuse) operates this unit. Check all the connections in the fan. If the connections are good then we need to stop here because more details would be needed.
May 15, 2010 | Hampton Bay 24750 Huntington III Ceiling...
Hampton Bay Ceiling Fan. Chateau Deville 52 in. Deville Walnut Logo
194 people viewed this question
Top Hampton Bay Televison & Video Experts
Tom Chichester
Michelle Balcom
Are you a Hampton Bay Televison and Video Expert? Answer questions, earn points and help others
