Question about Robot Coupe R2U Ultra Food Processor
I have a r6vn and it will not run I have replace the bowl and it still not working.
Push start button and nothing happen replace bowl and still nothing.
I have a food processor that worked fine the last time it was used, now it will not do anything.
You have probably solved this by now but generally it will be replacement of either the bowl or the lid to solve it. The mechanism is not overly robust within the handle & lid, movement gets lost and it won't activate that switch just above the button panel.
Nov 24, 2015 | KitchenAid Food Processors
I have a Kitchen aid food Processor no longer under warranty. I checked all the troubleshooting suggestions in the manual and all appears as it should. but when pressing the button nothing happens, w
Remove everything and have just the bare motor, plug it in and press the run/go button while at the same time depressing the safety microswitch activator at the front, just above the buttons where it would be hidden by the bowl if the bowl was on. If it runs then you have a lid or a bowl problem, if it doesn't run you have an inside the motor housing problem. Lid problems are more common than bowl problems but there is no guarantee yours will be the most common.
Feb 15, 2015 | Food Processors
Very frustrated with kitchenaid food processor - using any slicing disk only the first batch of food works, when you put in the 2nd batch nothing happens
Mine is older and works fine once I realized bowl has to be snapped into place before the cover and then the cover has to be locked in. This activates a small button at the base of the bowl that activates a safety switch.
Jan 03, 2015 | KitchenAid Food Processors
Hamilton Beach food processor
make sure bowl and lid are on correctly. If not, it wont run. Both have safety switches where they lock onto the unit. If latch tab is broken, you will need new bowl or lid. If still nothing, switch itself is bad
Jun 28, 2013 | Food Processors
When i try using it, nothing happens. i cannot
Remove the work bowl, blades, etc from off the base.
Plug the processor in and press the ON pedal down.
Use a pen to press in the rubber button on top of the base - you should hear a sound.
Now reassemble the bowl - lock the bowl in so that the handle faces front; insert blade of choice; place the tab under the feed tube of lid slightly left of center of the work bowl handle and slide the lid counter-clockwise until it clicks into place; insert pusher and make sure it locks into place.
You should be good to go again.
Sep 30, 2009 | Cuisinart Food Processors
Unit assembled, lights are on (pulse, on) nothing happens
The Kitchenaid food processors have a few safety features implimented. If the unit is not assembled properly, this may prevent the unit from turning on. I am thinking this is an issue of assembly because the light is on, so the unit is definitely getting power.
Proper assembly is below:
If it isn't all ready, please disassemble the entire unit. This means removing the blade and/or disc, blade, removing work bowl, work bowl lid, and blade.
Start by placing the work bowl onto the motor base. The work bowl handle should be facing at 9 o'clock, which is out to your left. Rotate the handle downward until it locks in at the 6 o'clock position, which will lock over the center of the button panel.
Repeat the process with the work bowl lid. The blade does not need to be present for the motor to engage, if this is an assembly issue.
Jul 19, 2009 | KitchenAid KFP740 Food Processor
Food processor does not work but light is on
Put the work bowl, lid, and pusher on one piece at a time - handle of work bowl faces the front of the food processor, hollow feed tube faces the back, and the sliding lock switch on pusher sleeve faces the front. Should turn on.
If it doesn't, test the motor - remove the work bowl and other parts completely. Plug the base in and turn it on, and use a pen to push in the dark grey or black button on top of the base - if it spins, the motor is still good - you may just need a replacement part. If it doesn't make a sound, it needs to be sent in to Cuisinart for repair.
Mar 29, 2009 | Cuisinart DLC-8S Pro Custom Food Processor
I plug my cuisinart and it will not start. It worked the last time I used.
Mar 28, 2009 | Cuisinart DFP-11 Deluxe Food Processor
Tried to use my powerprep pluss cuisinart food processor and nothing happens. The on button lights up but nothing happens when i press the pulse button.
Remove the work bowl from the base of the food processor, and separate the bowl, lid, and pusher sleeve.
Plug the base into the wall outlet, turn the food processor ON, and then use a pen to press in the dark grey or black button on top of the base of the food processor - if you hear some kind of noise, then your motor is still good.
Put the work bowl on first, with the handle facing the front of the food processor.
Put the lid on, with the lid lined up with the handle of the work bowl.
Put the pusher sleeve in the lid, with the metal piece facing the front of the processor.
Your processor should now turn on.
If it doesn't call Cuisinart and see if you are still in-warranty (3-year warranty).
-Tha Mp3 Doctor (also loves Cuisinart)
Mar 23, 2009 | Cuisinart DLC-2014 PowerPrep Plus Food...
My food processer does not work
I had the exact same problem. The red light came on when I hit the "On" button, but nothing happened. Then I noticed that when the lid is locked into place, a small pin in the handle goes into a small hole in the base. I took a wooden chopstick and poked it in this hole in the base, and the unit started running. I put the bowl and lid back on the unit and locked them into place, and this time the unit ran just fine. Yeah! I will remember this the next time my unit won't run even though I know that I've properly locked down the bowl and lid. Good luck!
Oct 11, 2007 | KitchenAid KFP750 Food Processor
Robot Coupe R2U Ultra Food Processor Logo
Top Robot Coupe Food Processors Experts
eyecam
Are you a Robot Coupe Food Processor Expert? Answer questions, earn points and help others
