Question about RCA P52926 52" Rear Projection Television
Leaking ploy silicon
Yes hi my ty is leaking some clear stuff ,fom one of the lens what is that stuff ,and is it repariable??
  • 1 more comment
  • Joey Figueroa
    Joey Figueroa Oct 09, 2007
    Dude i did touch the stuff lol .. oh well ,but i did clean my hands it did feel like antfreeze .Would it be possiable to add clean water in the mean time?Some did get on the board but i cleaned it up the tv still looks good but i should not turn it on until i replace tha coolant "right"
    And thanx for the help RCA was not they were lost thankyou very much:)
  • Joey Figueroa
    would you know how much to put inside the crt,would one bottle refill it to the right level?
    And again thanks you really saved my tv from that stuff getting on the board.
  • Joey Figueroa
    Joey Figueroa Nov 01, 2007
    Were can i get the seal for the crt that is leaking coolant?
    Genius:
  • 1,153 Answers
Yes and that stuff is poisionous. So be careful, not to get on hands, if do clean really good, it's antifreeze like you put in a car. It's called CRT coolant, and it keeps the bulbs cool in your set. Yes it's repairable, If you get it on the circuit board it will damage your tv. You must clean completely if dropped on PCB. You can purchase at places like MCMelectronics, bluestar-online, tritronics etc. While leaking it must be a bad seal need replacing or screw loose.
Posted on Oct 09, 2007
  • Lashawn Robinson Oct 09, 2007
    You are welcome, but water will not do it. It needs some kind of chemical solution to it, the bottles are not very much. You may find them locally try Radio shack or Electronic Store. But I know that you can find it at MCM, etc. If you don't use it the picture will look different and it will eventually burn out crt.
Where to put the silicone/oil into brewing unit
Hi. Spray the piston guide slides in the brew unit. As the brew unit moves up and down, you'll see the piston being guided. Rince with water 1st. Use a silicon spray that dries clear. not that white sticky stuff. It just collects coffee grounds and jams the piston. Dazza REPAIRER
Sep 23, 2011 | Miele CVA4070 Coffee Maker
I HAVE A 96 BUELL WITH THE 1200 SPORSTER MOTOR, AND IT LEAKS OIL FROM THE CRANK CASE HALVES IN JUST A SMALL AREA ON THE FRONT OF THE MOTER JUST WHEN ITS RUNNING. IS THERE A STOP A LEAK ADDITIVE, CAN IT BE...
Dont put any kind of stop leak in a motorcycle..You will have to replace the gasket. It leaks when it's warm because the oil thins out due to heat. You could possibly try to smear some chemical resistant gasket silicone in the crease and hope.
Aug 09, 2011 | 2001 Harley Davidson XL 1200 C Sportster...
Windshield leak began on passenger side of front seat area about three months ago....appears to be across top edge...runs down inside of windshield when in rains....truck has been parked outside since...
Windshield leaks are very difficult to stop. Not even pros can get it right all the time.
There is a silicone windshield sealant (Pep Boys) which has a consistency allowing it to "run" down into the holes / cracks -- sometimes this works sometimes it doesn't.
Yes, windshield trim will need to be removed...
And, yes, the light fixture should come off from top of vehicle, and "standard" silicone caulk can be used around that fixture to stop leaks.
Charlie
Jan 06, 2011 | Ford F-350 Cars & Trucks
Every time i try to play a ps1 game in the ps2, i get a disk read error even though i am using a ps1 memory card and ps2 games work perfectly on it. i have the original ps2
Hi,the unit needs to have the laser reader lens cleaned but DON'T use regular rubbing alcohol.
Get pure stuff....the rubbing type leaves a glare on glass and plastic lenses.
Also ,the chrome rails that the laser moves along need to be cleaned and lubed with liquid silicone.
This method clears read problems most of the time.
That will do.
Take care.
Oct 10, 2010 | Sony PlayStation 2 (PS2) Console
My disc reader motor wont spin. it refuses to read the disc
Hi,the unit needs to have the laser reader lens cleaned but DONT use regular rubbing alcohol.
when a disk reader refuses to spin, sometimes it might be from the motor mechanism that allows it to spin when you insert a disk inside the disk reader is damaged that's might be the reason it does not spin.
You can check both the lens and the mechanism to be such which needs to be replaced.
Take care.
Oct 08, 2010 | Nintendo GameCube Console
Will not read the disc when loaded
The unit needs to have the laser reader lens cleaned but DONT use regular rubbing alcohol. Get pure stuff....the rubbing type leaves a glare on glass and plastic lenses.
Also ,the chrome rails that the laser moves along need to be cleaned and lubed with liquid silicone. This method clears read problems most of the time.
Apr 14, 2010 | Microsoft Xbox 360 Console
GOT CAN DENTED,, CHROME FINISH ..CAN IT BE REPARIED
Yes and no, You are talking about the exhaust? You can pull them apart, but I don't think you will get the dent out without some serious tools, and then some polishing stuff to make it look right. A muffler shop with a bending machine might have something, a bumper shop, with old school stuff, dent removal and plating tools might be able to do it. You might just have to wait for somebody on ebay to but a carbon fibre can and sell his stock one.
Mar 01, 2010 | 2004 Yamaha XT 660 X
Wont read discs
Dec 24, 2009 | Microsoft Xbox 360 Pro System Console
Under the lens is a leaking. and the color is messed up.
The silicone liquid coolant is leaking, you can try looking here:
www.mcmelectronics.com
Nov 15, 2009 | Philips 60PP9202 60" Rear Projection...
My xbox wont read any discs
Oct 02, 2009 | Microsoft Xbox 360 Console
RCA P52926 52" Rear Projection Television Logo
52 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
