Goodman awb2405d how to install air handler
Joe_Rex
  • 114 Answers
SOURCE: GOODMAN # ARUFO49 AIR HANDLER
MOST ALL GOODMAN ( UP TO 3 TONS)INTERNAL FILTERS ARE 22" x 22" X 1". YOU CAN GET THEM ON LINE AT www.filtera.com. ALWAYS TAKE A TAPE RULE AND OPEN THE BOTTOM FILTER DOOR AND MEASURE THE FILTER RACK. MAKE SURE YOU DO NOT HAVE A RETURN-AIR FILTER-GRILLE. LARGE WHOLE -HOUSE RETURN AIR VENT NEAR OR AT YOUR FURNACE, A/C AIR HANDLELER. Joe_Rex New Member of FixYA Retired HVAC&R contractor 45+ years exp.
Posted on Apr 28, 2007
  • 121 Answers
SOURCE: Wiring diagam for goodman heatpump
On your t-stat you have Y, W1, W2, R, O, G, B or C or X. Y is your cooling circuit and will be the same in the air handler and heat pump unit, use the yellow wire for this circuit. W1 and W2 are your back up elec. or gas heat. Depending on how many kws or heat strips you have and t-stat wires you will put the white wire to W1 in both the t-stat and air handler. W2 is for your second stage back up heat if air handler calls for it, this will be a tan or brown or black t-stat wire and goes to W2 on t-stat and air handler. R is half of your 24v control power from the transformer and is the red wire and goes to the t-stat, air handler, and heat pump. O is for the reversing valve in the heat pump that switches it from heating and cooling. You guessed it the orange wire connect to t-stat and heat pump. G is for the blower and is the green wire to the t-stat and air handler. B or C or X is known as the common which is the other half of control circuit from 24v transform it is the blue wire and goes to the t-stat, air handler, and heat pump.
Posted on Oct 09, 2008
  • 306 Answers
SOURCE: Air handler motor and capacitor
Just take out the fan and capacitor they are not OEM so any fan motor would work as long as same Horsepower and milti speed. And the capacitor is a 5 uf or maybe 7.5. You might have to cut off the shaft of the new fan motor so it don't stick out.. You can get a new fan and capacitor at any Heating and Air parts house. And you are sure they are bad you ohmed them out? Fans are not cheap about 50-75 bucks retail. Let me know how it goes. ken
Posted on Dec 23, 2008
  • 37 Answers
SOURCE: I removed the blower motor out my goodman air
look at the wiring diagram.
Posted on Apr 25, 2009
james3751
  • 614 Answers
SOURCE: MY GOODMAN AIR HANDLER IS DRIPPING WATER FROM THE
You may have dirty stopped up drain pan or drain. Take a dryvac and **** the drain from outside. This will clear all the drain. Is it cooling ok? Is the unit in an attic? The drain is not hard to clean. Check your coil(evap) inside to see if this is clean. Rus
Posted on Jul 11, 2009
Why does the drip pan overflow?
The pan may have been installed incorrectly but it also is possible that debris may be clogging the outlet periodically.
Jul 16, 2015 | Goodman Manufacturing Goodman ARUF182416...
Have GOODMAN AWB2405D UNIT and turned thermostad to heat and then when it got warmer, I turned back to ac/fan, but nothing is happening. Any tips would be appreicated.
i would say a thermostat issue. mine acts like that sometime havee had to pull front cover on stat and clean contact surfaces.
Feb 22, 2015 | Goodman Heating & Cooling
What cause 3 amp fuse to keep blowing when power in turn on goodman 16 sier air handler
Hello...
Apparently, there is an overload or shorted wires. Elequipo Disconnect electricity and check the cables are in good condition.
Nov 13, 2014 | Goodman Manufacturing Goodman ARUF48D14...
What cause 3 amp fuse to keep blowing when power in turn on goodman air handler
The 3 amp fuse is in the red low voltage (24 volt) thermostat wire
and only gets power when the thermostat is set to turn on heat or a/c It should be connected to the red wire from the thermostat
Difference in seer
i would check fan speed. it's probably on high. you might be moving more air with new system. a dirty evaporater on old unit woud have gave you a larger temperture drop.
Jun 16, 2014 | Goodman Heating & Cooling
Keeps freezing
low air flow or low on refrigerant.
Jul 24, 2013 | Goodman Heating & Cooling
Air handler keeps running
Most likely this the fan delay. They weld closed and cause the fan to continuously run. They are available at your GOODMAN dealer.
Feb 20, 2013 | Goodman Manufacturing Goodman ARUF193116...
Not hot air
One of three issues
Thermostat not wired properly
failed heat sequencer in air handler
bad heat element in air handler
Feb 10, 2013 | Goodman Manufacturing Goodman ARUF182416...
There is no schematic or number on air handler .outside unit is Goodman # CPE48-1FB.How can i get a schematic for Air handler.
I need more info than just the outdoor unit number. The air handler will be a specific number. If you pull the access panel off the heater, there will be a faceplate inside with the unit name and model number as well as a schematic on the back side of the door.
May 12, 2010 | Goodman CKL60AR60 Air Conditioner
Heating & Cooling Logo
61 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
