Printing problems on legal size paper - Office Equipment & Supplies
  • 29 Answers
In order to change the paper size for the printer, One do not have to
click on the "File" menu at the top of the window and then select "Print". Making paper size changes in that manner will not affect the
paper size that Acrobat will use to print the document. That's it.
https://www.structuredsettlement-quotes.com/
Posted on Nov 23, 2013
3 Suggested Answers
  • 186 Answers
SOURCE: Won't print out legal size paper
some machines have a setting on the tray as well as in the menu. I would check both.
Posted on Jun 21, 2007
SOURCE: won't recognize legal size paper
I have a Brother MFC-8840Dn (full legal-size flatbed as well as document feeder). I use Windows XP Pro and a USB connection. I'm not sure my fix works with other Brother models or different Windows operating systems, but it's a way to start troubleshooting at least.
I've always been able to print legal-sized pages from word processing or spreadsheet programs and receive legal-sized faxes. But I never could make legal-sized photocopies or PDF scans. The image was always cut off at Letter size. The fix is a Brother Utility set-up setting:
*** Go to Start / All Programs / Brother / MFL-Pro Suite MFC 8840Dn / Scanner Utility. (This link may also be called something like Scanner Settings.)
*** At the "Maximum Scanning Size", select "Legal" instead of "Letter/A4".
*** Click OK and restart your PC for the new setting to take effect.
It's like magic -- I can now scan a full legal-sized PDF, whether on the flatbed or through the ADF. I also tried a compressed TIFF scan and it came out fine.
**** Make sure your software and/or Brother Control Center scanning configurations are set to Legal if that's what you want for the particular image scan. The Brother Utility setting simply enables the option of choosing the larger legal-sized paper, which then allows the full legal-sized image scan, You always have to set your software to make that choice, just as you would to make and print smaller images on Letter, A4, envelopes, etc. (NOTE: I always start scans through software on my PC, like Adobe Acrobat or PaperPort, and the Utility Setting fix is working fine. However, I just tried pressing the SCAN button on the front panel of the MFC itself with a legal-sized document on the flatbed and through the document feeder. I still got Letter-sized image scans. So, there must be another setting somewhere for starting scans directly from the MFC that I'll locate later.)
I was about to buy a different brand of scanner because of the frustration with legal-sized images. It's like having a new scanner now :) I hope this Utility Setting info helps you troubleshoot your legal-sized image problem.
Posted on Jan 07, 2009
Brother 9840 print on legal size paper
it seems that on your model you can only use legal size paper on tray 1 & 2, then you have to set the paper size.
here is a link to instructions for your model.
http://download.brother.com/welcome/doc002258/mfc9840_uk_usr_b.pdf
Feb 19, 2015 | Brother MFC-9840CDW Laser Printer
Canon IR1022if copier can't print in Legal size(8.5inx13in) using bypass or even paper cassettee
Did you trying hitting an Ok button, green button, etc to confirm legal size paper, maybe it wants you to confirm paper size. Also legal is 8.5x14, did you select legal or enter the size as a custom page?
May 22, 2014 | Canon IR1022IF 220-240 VOLT, 50/60HZ
How to Print Legal size paper in Canon IR2420L
I purchase the cannon IR2420L machine, But I cannot the legal size paper print. please load correct paper message display.Please help me. Thanking you.
Nov 30, 2012 | Canon Office Equipment & Supplies
Copying legal size on a Brother MFC 7420
This is for a temporary, as needed solution: Press "Menu/Set" button. Select "General Setup". Scroll down and select "Paper Size", find and select "Legal" size. Press Menu/Set button again. Press "Stop/Exit" button.
Insert legal size paper to be copied on the feeder tray and put a legal size paper in the Manual slot. Hit "Print"
You need to do these same steps again to return the settings to Letter size again.
May 09, 2012 | Brother MFC 7420 All-In-One Laser Printer
Hello, I have a question about the HP 1312 all in one printer. Does it print on legal size paper and where do I load the legal size?
Yes, it can print on legal size paper. Do the following:
Lower the paper tray, and if necessary, slide the paper-width guide to the outermost position.
Fold out the paper-tray extender to catch paper as it exits the device.
Tip: For best results when loading legal-size paper, fold in the paper-tray extender before loading the paper to avoid a paper jam.
May 13, 2011 | HP Office Equipment & Supplies
Can't print proper legal size documents
please you aply the comand control p and you go the property select
and ok. you so the paper select and ok and you so the paper size
in select legal is ok and ok
and aply print legal size print ok
Sep 15, 2009 | HP LaserJet 1018 Printer
Print legal size paper problem
when you give print command that time chage the paper size from a4 to legal in print proeprties and choose paper size legal.
Sep 08, 2009 | Canon LASER SHOT LBP-3000 Printer
We had problems to print legal and after 30 minutes of trying it finally printed legal. Now we cant go back to letter size so every document prints on legal paper. Can I get clear instruction on how we can...
When you say printing? Do you mean from the computer or are you making copies. If you are printing from the computer you need to change the paper size that you are printing to under the printers properties or the out put tray. If you are making copies just hit the reset button or just manually select another paper tray on the display pannel. Or if you have change a paper tray to leagal size change it back to LTR and make sure the paper is installed the correct direction.
Nov 26, 2008 | Canon imageRUNNER 2200
Cannot print to legal size paper format
There could be a few issues causing this problem.
1. Your document size on the actual document you are attempting to print believes it is letter (which is the default).
To change this setting, you must tell the computer you wish to print on legal paper.
To do this in MS. OUTLOOK:
Put the curser at the top of the page
then...under 'File-Print-Preferences-Layout-Advanced-Paper size-change to legal (from Letter'
-slightly tedious...but follow along and this should help
2. The printer needs to be adjusted to hold the legal paper.
Open up the legal tray to adjust the paper holder to hold the paper snuggly...it slides roughly.
Hope this helps..if you need more assistance please ask...also please rate my solution.
PLEASE note that anything other than a FIX-YA is actually a negative rank...and will lower my success...I didn't make the system...but that is the way it is in FIX-YA.
thanks
bearb
Nov 10, 2008 | HP LaserJet 2605DTN Color Printer
CANON IR2000 CANT PRINT MORE THAN 1 COPY
You just stated the problem yourself!!!!!!!!!!!!!!!!!!!!!
Are you using Letter or Legal?? then the tray need to be set to that particular size.
If using Legal set to Legal, otherwise the machine will automatically know you are using the wrong size.
Aug 14, 2008 | Office Equipment & Supplies
44 people viewed this question
jasbo
jasbo
