Question about Dishwashers
Programme stops at 56 minutes and there' still water in the washer.
    Problem Solver:
  • 8 Answers
Hi Stephan
At a rough guess either your pump is blocked so won't pump water out or there could be a kink or blockage in the waste pipe.
If you can take out the filter and fish around in there you may find the item. Generally chicken bones. In some cases it will burn out the pump and will need a service man
Posted on Nov 22, 2013
Hoover washer dryer Error Code E12 during dry programme. How can I fix?
E12 means a problem filling on dry cycle.
Unplug the appliance, take the top off and check that the plastic condenser below the fan is clear and clean.
If this is ok, the most likely fault is the triple valve isn't opening properly to feed water into the condenser.
Nov 03, 2012 | Washing Machines
Fisher paykel front loader stops almost immediately
Hi, is your water valves on, if so check the water inlet on the washer for continuity. If no continuity than replace it.
Sep 26, 2012 | Washing Machines
Machine wont stop washing on programme 9! went for days. Had the error lights flashing but that stopped.
If you select a rinse and spin programme and it completes the cycle, then I would say that the heater element is probably faulty, because the programme will not advance until the water has reached the correct temperature.
If it does not complete the rinse and spin cycle, then it is likely to be the control module that is the problem.
Feb 09, 2010 | Indesit W 123 Front Load Washer
Hi I have model No WF 740 1400 spin! However programme L is filling up with water, appears to be washing as normal until it reaches final 7 minutes, then machine becomes laboured and will not spin! the...
it appears that the pump is not removing the water that is spun out  if there is a belt on the pump then it may have fallen off or need replacing   if it is intact then the pump either failed or there is a blockage in the line
Nov 08, 2009 | Hotpoint Aquarius WF000 Front Load Washer
CDA dishwasher (model number CW496) , stops working at the rinse cycle, and does not empty, filter is ok, tried re-setting the programme but unless there is no water being held the programme won`t work
my dishwasher starts off with good intentions then a couple of minutes later it starts beeping non stop.I open the door to find it has turned on to the rinse cycle and will not do its job.I continue to start it again and then it repeats the problem again.Can you help?
Sep 21, 2009 | Dishwashers
ERROR E7 TOSHIBA WASHER AW8960S
check the water level switching or door sensor
Sep 09, 2009 | Washing Machines
Hotpoint washer dryer BWD 129 stopped and won't drain or spin
unplug for 40 minutes in an attempt to reset the ECU.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jan 15, 2009 | Washing Machines
Display panel (cont.)
hi there try pressing and holding the start button for about eight seconds
Oct 10, 2007 | Hotpoint Aquarius WD640 Front Load...
Dishwashers Logo
Top Dishwashers Experts
