Which oil to use for gear box and for hydrolic system and how much time require to change the same.
pippall
  • 1486 Answers
SOURCE: can t shift gears
loosen the bleed screw.Then check if you can press the pedal down.If you can you have to change the clutch Assembly.If you still find it hard to depress then the master cylinder needs to be replaced.Hope this was useful.
Posted on May 31, 2009
MNfisherman
  • 11896 Answers
SOURCE: Changing of timing belt and automatice gear box oil.
If it is a timing belt and not a chain, the book suggest 4-7 years. If the belt does not look worn or cracked, than I wouldn't worry about it. If it looks like it needs to be changed soon, than it is probably that time to be changed
The transmisson fluid and filter should be changed ever 2 years.
Posted on Jun 02, 2009
co7196
  • 3433 Answers
SOURCE: WatNut must take out to change gear box oil
What you are looking for is a plug that has a hex(for allen wrench) in the middle. It should be on the bottom of the transmission, assuming this is a manual transmission.To refill a manual trans, after putting the drain plug back in, Remove the plug on the side of the trans. Same thing on the tool or the plug has a square head. You can use a crescent wrench on the square. Fill the trans thrrough the side hole with the proper oil. Proper level is aproximately 1/8" from bottom of threads of hole Put you pinky in in the hole straight and push downward until the tip of your finger touches oil. Keep your finger straight. Theskin/meat on your finger will give about 1/8" as you press down. That done, chk both plugs and you're done.
If this is an automatic trans, the pan needs to be taken down to change oil. Good Luck.
Posted on May 28, 2010
jturcotte
  • 8836 Answers
SOURCE: I need to pump the
there may be air trapped in the slave cylinder. Try bleeding the slave by pushing in the slave piston with the bleeder open. Close the bleeder before releasing the piston and repeat until no air comes out. OK?
Posted on Dec 06, 2010
skychief2001
  • 21873 Answers
SOURCE: hydrolic clutch has air
If the slave cyl has a bleeder screw you should be able to do it just like a brake system.
Posted on Sep 11, 2012
How effective is transmission oil /gear box oil to an automatic vehicle if it has not been changed for a long time. What can it cause on the vehicle? (in my case a Toyota Noah Auto)
all transmission oil break down from the heat and stresses generated by the transmission operation
the additives in the oil are eventually all neutralized and the residues so formed create a gum that slows down the change actions and the ability of the servos and solenoids to operate correctly
bands and clutch pack tend to slip or not release quickly on ratio changes
indications that an oil change is require include slow to change up or down
staying in a ration when coming to a stop resulting in sudden gear shift or shudder
not change at the required speed/engine rpms range
requiring the foot to be lifted to effect a change of ratios
many manufactures recommend a change at around 60,000 klms but other manufacturers like GM say it is not necessary
if you have a dipstick, pull it out and if the oil is not cherry red or a really light tan color ( depending on the atf specified oil) have it changed professionally
Jan 13, 2017 | Toyota Cars & Trucks
I have a automatic 93 4 door pajero the problem starts that 4x4 was not conected when got conected it started making grinding sort of noises so i disconected it and its still making noises in normal mode ...
metal indicates bearings ,gear teeth problems
will need a removal and inspection for a rebuild
if the quote is too expensive consider a good unit from the wreckers /junk yards
make sure that the box is not a CV transmission as gear oil will not be correct
if it is in the transfer case then gear oil will be ok
Jan 18, 2018 | Cars & Trucks
My rover 75 1.8 club has a hydrolic clutch but find it hard to change gear mainly down shifting
decent car the rover i like them anyway,now if vehicle is going into gear ok and the pedal bite is the right height then check the gearbox oil level EP90 oil is used for this never mind this thin stuff used on modern cars its not a lot of good regardless what the designers say ,a nice bit of thick hypoid oil is the best as its a diff and gearbox unit all in in one on front wheel drive car and no lubrication around the syncros and baulk rings will cause this problem ,if after topping up the gearbox and it goes noisy then pump some LM grease into the box about a grease gun full as this will end up in the bottom of the box and help stop any leaks along the bottom gasket or the drive shafts and help quieten the box ,yes i know its a arthur dailey type trick but it works ,well what do expect from a old truck fleet fitter like myself no dealer unit changer here
Sep 22, 2012 | 2007 Honda CR-V
Hydrolic clutch has air
Sep 11, 2012 | Chevrolet Cavalier Cars & Trucks
I CANT SEEM TO GET THE AIR OUT OF THE CSYSTEM NO MATTER HOW MANY TIMES I BLEET IT...IT IS STILL NOT ABLE TO CHANGE GEARS....
the hydrolic has a leak on one of the seals. somewhere there must be a place where oils build up can be seen. check and replace.
Aug 04, 2010 | Daewoo Leganza Cars & Trucks
I have a 1998 Accent 5spd manual. Cant shift into any gear while car is running, if I turn the car off and put it in gear it will start and move in the process or start and not move but if I let off the...
It is possible that your clutch and the idling counter wheel is not getting detached. Unless the selected gear are moved into the notch the particular gear will not engage. So in this case we have the gear box as the complaint. I hope the gear oils were changed on time and so there is no scope of wear out. Adjust your clutch for full release if the clutch was not full pedal down. If the fault changes you can continue to use or else it wil require for taking the gear box out for resetting. The cost will be for taking the gear box and putting it back as it may only require the idler selector to be reset or the worn out ones changed. Take a estimate at your Hyundai dealer and decide. Good day
Aug 03, 2010 | Hyundai Accent Cars & Trucks
Having trouble with gear selection especially changing down manual transmission
the clutch probably needs to be tightened up a bit that is if you can i dont know if it has a cable or is hydralic
if it has a cable then tighten it untill you have a little free play you can feel when you depress clutch pedal
if hydrolic then you may have air in system or master/slave cylinder may be going bad
also if you have recently had the gear oil changed they may have put in to thick an oil or the wrong type
Mar 22, 2010 | 2006 Toyota RAV4
Toyota Landcruiser VX 4.2 turbo diesel automatic
Bit of a long shot, but check the output of the throttle position sensor with a multimeter.
Also, check that the low range switch isn't continually reporting that you are in low range. The gearbox computer adopts a VERY harsh shift pattern in low range, holding gears until approx. 3500 RPM and even then producing very hard shifts.
Try unplugging the connector that carries the low range sense signal from the transfer box under the vehicle and see if that makes a difference.
Jan 29, 2010 | 1994 Toyota Land Cruiser
238 people viewed this question
k24674
jasbo
jasbo
