Question about Ingersoll Air Tools & Compressors
My wife left on my air compressor it is a Ingersoll-rand and now it turns on but doesnt sound like the motor is running but one of the belts in broke any ideas
    Problem Solver:
  • 20 Answers
The motor turns the belt that drives the actual compressor portion of the system. Replace the belt, make sure there is oil in the compressor pistons and try it out.
Posted on Nov 21, 2013
4 Suggested Answers
hdpanama
  • 65 Answers
SOURCE: ingersoll rand air compressor 185
How old is the compressor ? This trouble shooting is directed to the vane and screw types of air compressors.
Caution,
For exact information on the equipment you are working on, go to the manufacturer’s maintenance and repair manual.
Here are some possibilities.
Compressor does not reach design pressure or capacity:
Air Pressure safety valve is leaking
Receiver air valve is open
Unloader valve is leaking
Loose Piping or fittings
Compressor will not load or unload:
Unloader valve defective
Air control valve is sticking or dirty
Unloader pressure is improperly set too high or too low
Water in the control lines
Plugged control lines
The air compressor CFPM is low:
Dirty air compressor air filter
Defective air intake control valve
High idle on power source improperly set
Damaged or worn rotor blades
Posted on Nov 25, 2008
  • 1383 Answers
SOURCE: Honda 5.5 hp air comp. no spark wont run
Most honda engines have an oil sensor that prevents the engine from starting if the oil level is low or oil is dirty. Test coil by disconnecting oil sensor wire. With sensor disconnected coil should fire. If still no fire, check kill wire for short. If still no spark, coil may need to be replaced. enjoy
Posted on Nov 29, 2008
SOURCE: ingersoll Rand SSR compressor shuts down loaded or
When it shuts down, press DISPLAY SELECT button once and use the up down arrows to see the code just before shutdown.
HIGH AIREND TEMP
HIGH AIR PRESSURE
LOW SUMP PRESSURE
PRESSURE OR TEMP SENSOR FAIL
CHECK MOTOR ROTATION
MOTOR OVERLOAD
FAN MOTOR OVERLOAD
STARTER FAULT
I am assuming this has a Intellisys controller.
Posted on Sep 25, 2009
What level does the coolant need to be in the sight glass?
About 31,000 results (0.83 seconds) Search Results
    [PDF]IRM-G-8780 2-25hp US - Ingersoll Rand Air Compressor
    www.ingersollrandproducts.com/...
    Ingersoll Rand Industrial TechnologiesIngersoll Rand compressors are not designed, intended or approved for breathing ...does not approve specialized equipment for breathing air applications and ... unmatched service to meet your needs. ... drain, and low-oil-level .... Oil Sight Glass ... Value Package (5, 7.5, 10 & 15hp) An economical choice in a dependable ...
    [PDF]Owner's Manual - Air Compressors Direct
    www.aircompressorsdirect.com/.../irmanual2340_2475_2545_7100_15t...
    installation, operation and maintenance of your Ingersoll-Rand air ... An air-cooled aftercooler, low oil level ... for Models 2340, 2475, 2545, 7100, 15T & 3000 ... Ifcooling of the discharge air is required, .... motor does not have this button and the unit does not have a ..... l Drain compressor oil and clean oil sight glass.
    [PDF]XF 7.5 - 15 EP 7.5 - 15 HP 7.5 - 15 XP 7.5 - 15
    diagramasde.com/.../Manual%20comp%20ingersollrand%20SSR-15.pdf
    EP 7.5 - 15. HP 7.5 - 15. XP 7.5 - 15 ... The Ingersoll-Rand Company Rotary Screw Air Compressor that has been filled prior to its ... after shall have its AIREND warranted for twenty four (24) months from the ... comes first, when using ULTRA COOLANT.Coolant ...... check coolant level in the sight glass on the separator tank.
    Ingersoll Rand Air Compressors - About Air Compressors
    www.about-air-compressors.com/Ingersoll-Rand-air-compressors.html
Feb 08, 2016 | Ingersoll Rand 15 Horsepower Rotary Screw...
Whare can i get picture of ingersoll rand type 30 model 234 with serial no 645261
Hi Omran,
The capacity of your compressor is 7.46 if the motor drive is 2 hp. 9.79 if the motor drive is 3 hp.
Hope i can help you.
Sep 13, 2012 | Ingersoll Rand - Rand Type - 30...
I have a Ingersoll Rand en6f75 compressor. Does it have to run in a particular direction as I cannot see any direction arrows on it.
We provide tech manuals for all of our products at www.irtechpubs.com. We also supply technical information on our website www.ingersollrandproducts.com. Hope this is helpful.
Ingersoll Rand Employee
May 13, 2011 | Ingersoll Rand - Rand Type - 30...
Hi i have an Ingersoll rand 80 gal, 7.5 hp, model #2475 air compressor and the electric motor is arcing when trying to run then blows the breaker. Any ideas? thanks
It sounds like either a problem with the brushes in the motor or the engine shaft is jammed. Have you on many previous occasions run the compressor on that circuit with no problems? It may be as simple as the breaker is not sufficient for the power draw of the compressor.
If you have had the unit for awhile and it has been run lots and the engine shaft spins easily when turned by hand (unplug first) then it may be an issue with the brushes on the electric motor. Take the engine apart and replace the brushes with new ones from an electric motor shop. Take pictures as you disassemble the unit so you will be able to refer to them when it comes time for reassembly.
If the motor shaft does not turn by hand, remove the belt that connects it to a compressor and try again. If this works, reconnect the power and see if the electric motor now works with power on and the belt off. If the motor works and there is no short to throw the breaker, then your compressor is in need of a rebuild and that will cost money and time.
Mar 15, 2011 | Ingersoll Rand Electric Driven Two Stage...
I have ingrosoll rand t30 model 2340 motor is working very hard to spin the compressor sound of compressor is different to , rubber burning smell is also there , but belt is in good shape it is not loose.
May have a bearing going bad. Remove the v-belt and turn the motor by hand. Does it turn hard or produce an unusual noise. If so you have a bad motor bearing. If not turn the pump by hand. If it turns hard or produces an unusual noise you have a bad bearing in the pump. Also move the pump fly wheel up and down , left and right. If you can move it the front bearing is bad.
Sep 20, 2010 | Ingersoll Rand - Rand Type - 30...
Motor seems to work but doesn't turn the pulley doesn't sound like it normally does
I have a Ingersoll Rand Compressor model# H15T4 and it constantly pops PRV. What do thing is the problem. Thanks.
Sep 05, 2010 | Ingersoll Rand - Rand Type - 30...
Wont turn over
did u check oil level in pump end take belt off and try 2 turn pulley iff no go pump is seized pull off head and see iff ring is broke
Jul 31, 2010 | Ingersoll Rand SS3J5.5GH Wb Ir Portable...
I have a two stage electric air compressor that wants to stall. I turn it on and as it runs up, it will labor and stop. Checked oil and it is full. This compressor is used very little, what should I do...
check both motor start and run capacitors if it starts o.k. but loses power as pressure increases,this could be a sign of a weak motor run cap.if this helps replace both caps cause its cheaper than a new motor
Aug 30, 2009 | Ingersoll Rand 231C-KS - 1/2" Super Duty...
Service of ingersoll rand
Actually not a lot of Parts.
1) Remove & Clean the Air Intake Element
a) Check and see IF the Secondary Pump Head has a Filter/Breather and Clean That also...
2) Drain and Change the Oil (per Manufacturer Requirements-I PREFER Ingersoll-Rand Compressor Oil Myself) Don't Over-Fill!!
3) Check the Wear on the Drive Belt(s) and Tension ( Deflection shouldn't be more than 5/8" Between the Motor and Compressor)
4) I usually Blow out the Motor with about 20psi of Air, since it probably has Sealed Shaft Support Bearings, and is the Brushless Type, Not Much to do. Pull Off the Inspection Plate, and Check for How Clean the Inside of the Motor is BEFORE you "Air-it-Out", if there are any signs of Greasy Dirt, you may want to get some Electrical Spray Cleaner, and spray just enough to Wash the Contaminants off...
5) DRAIN Your Main Holding Tank: Drain Until there is NO Moisture Left, just Dry Air. You could Drain into a Pint Mason Jar-Just make Sure you Only Open the Drain just enough to let a Minimal amount of Flow, and see what Contaminants are in your Tank...(this should be done at least Once a week anyways) I installed a Auto-Drain on Mine, AND a Auto Water Drain on the Regulator is a Great idea too...
6) Check ALL your Wiring Connections, make sure they are Tight...Vibration will cause them to Loosen.
7) Sometimes is a Good idea to Check Your Keyways on Your Pulley Shafts for Wear, should be a "Press-Fit"
8) Check the Pulley/Belt alignment, make sure it's running True. IF Not, Check Your Motor & Compressor Mounting Bolts
I usually do a PM (Periodical Maintanence) about every 3 Months on My Compressors...and don't forget to Oil Your Air Tools Before each Use.
Jan 29, 2009 | Ingersoll Rand Type 30 Electric Driven Two...
Air Tools & Compressors Logo
51 people viewed this question
Top Ingersoll Air Tools & Compressors Experts
elunsford
John Trevino
Joe Garcia
Joe Garcia
Are you an Ingersoll Air Tool and Compressor Expert? Answer questions, earn points and help others
