And does the tv find stations itself??? ...(should have got dad to do this)) Thanks
  • 20 Answers
I don't know the tv type but use the remote control menu,look for settings and use the auto search to scan the stations whiles you save them how you want them..
Posted on Nov 21, 2013
I have a VIZIO E552VL TV hooked up to an Over the Air Antenna and want to MANUALY put in channels NOT AUTO SCAN
Not sure if your TV is digital or analog, but I think an analog TV does not have the ability to perform auto scan, so you may be able to manually input the channels. As a kid, my dad installed a rotary antenna, and as it rotated and TV pictures displayed on the screen, dad noted the specific spot on the rotary unit; and every time we turned the set on, we just pointed the arrow on the dial on the unit to where dad noted what the channel number was on the unit, and the antenna turned toward that direction, and the pictured appeared on the screen.
Nov 16, 2014 | Vizio E552VL 55" 1080p 120Hz LCD HDTV
Emerson tv 32 in --the channel 7.1 ABC only has picture without sound.
Check the Chanel 7 broadcast signal on the other tv have sound,could caused by the tv broadcasting signal from the tv station itself.Check if ur tv have a function known as S.A.P. make sure it is off,could effected no tv audio problems,because the tv station in ur city or town don't broadcast in that signal frequencies.
Feb 24, 2013 | Emerson Televison & Video
My tv model #27F500T is changing stations all by it self
the stations are changing by itself on your TV because the channel button on the TV is partially stuck in, that is why it keeps changing all by itself. This same thing may also happen to the remote control of the TV if the channel button of the remote stuck in and pointed at the TV.
Use your finger to rub the buttons on the TV, especially the volume control button. Do same on the remote and most definitely problem should be solved.
Please give me a feedback if solution does not work for you.
Yours sincerely.
Elect_Comp
May 26, 2011 | Televison & Video
I cannot put in tv stations manually the auto search doesn't pick
cant help you there, Most TV's have a little flap you lift up to access a little wheel and switch that has 4 regions you start at 1 and roll the wheel till a station is found and is cleasr to view. then move on to the next set of switch and wheel to rotate that to get a different channel. If your TV does not have this manual input then you can only do it from either the remote or some buttons on the TV itself
Jul 30, 2009 | Televison & Video
My Visio turns itself off and on when I change to one channel
I had the same problem. Tech support told me to turn the tv off, then unplug it. Then hold the power button (on the tv - on the bottom of left side) in for 30 seconds and try again. This did solve my problem.
Jun 14, 2009 | Vizio VW32L 32 in. LCD HDTV
I am unable to figure out how to remove SAP from 2 of my stations when I run the VCR through the Zenith TV. This is a relatively new problem. All the other channels I record are okay. I downloaded...
LEAVE TV UNPLUGGED OVERNIGHT TO RESET ITSELF. IT SHOULD BE BACK TO NORMAL AFTER POWER DRAINS FROM POWER SUPPLY. THAN GO INTO YOUR MENU SETTINGS AND TURN SAP OFF
Apr 19, 2009 | Samsung Televison & Video
Philips 19ps35s322
Don't know if this is of any use at this late date but . . .
This site does pretty well at supply either the original remote or a suitable substitute:
Remotes
Jul 15, 2008 | Philips 20PT6441 20" TV
Insignia TV and Direct TV Remote issue - cannot get the closed captioning turned off
The TV slowly, all by itself, ran closed caption on the major stations.
Unable to turn off through the menu as that option was greyed out.
Now all channels have this unwanted closed caption.
Any similar problems and ideas.
Thanks, Harold
Jul 07, 2008 | Samsung HCN4226W 42" Rear Projection...
You requested more info on my tv
It sounds that you are talking about the video amplifier board and the other part is called the "yoke".
Can you provide me with the exact model and chassis number of your TV to find a part supplier that carries those RCA parts.
Apr 12, 2008 | RCA F38310 38" TV
Sony Wega KV-27FS100 RANDOMLY Turns itself ON
You said around 4pm TV is switched on everyday. Check in menu options any on-timer and off-timer is changed. If it is not there is a problem in microprocessor section. EEPROM ic malfunction also shows these type of symptoms. But it can be done by Technical persons only. This is not a major problem. This is due to surge current and lightening like that.
Sep 06, 2007 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Televison & Video Logo
16 people viewed this question
Top Televison & Video Experts
Electro Med Services...
