I NEED TO REMOVE SCREWS HOLDING BEZEL AROUND INSTRUMENT PANEL ON 1991 JAGUAR VP. HOW DO I FIND THE SCREWS?
  • 28 Answers
SOURCE: Instrument Cluster removal
you need to take off the steering column cover upper and lower halves to get two the two screws that are hidden under the rubber dust cover.thanks for using fixya!
Posted on Aug 30, 2008
MNfisherman
  • 11896 Answers
SOURCE: Honda Removal of factory radio 1991 Accord lx
start by removing the console. there should be four screws that hold it in; two on each side; one in the front and one in the rear. you may have to take the gearshift knob of if the car is manual trans.then, remove the ash tray. there are two screws at the front of the ashtray receiver and one at the back.with the ashtray and slide removed, take the bezel off of the radio. there should be two screws behind or above the air outlet vents on top andn two screws in the under the center dividing rail. you may have to pop out the air outlets to get to the screws. there may also be a screw at the bottom of the bezel in the center.with the bezel removed the only thing that holds the radio in at that point is two screws that come up from underneath where the ashtray receiver was. take out those two screws and the radio should pull out from the front. Be sure to disconnect the antenna lead and the connector from the back of the radio before pulling on it too hard or you'll damage one or the other.hope that helps
Posted on Jan 17, 2009
  • 73 Answers
SOURCE: Need to replace burnt out dash board lights 2001 Toyota Corolla
Just remove the 4 screws and then slowly pull the cluster out and reach behind and disconnect the plugs on the back of the unit and then remove the cluster. The bulbs can be removed by turning them and pulling out.
Posted on Sep 26, 2009
  • 4044 Answers
SOURCE: Removing the door panel on a 2005 Nissan Altima
If you have the door panel loose you should be able to see the plastic clips that are holding that in or a plug you can undo to be able to remove the panel completely. If it has clips you can release them with a screw driver.
Posted on Dec 03, 2009
SOURCE: removing inside door handle
i have a hyundai accent 2001 and i need to find fm stations manually.
Posted on Mar 06, 2010
How to remove the instrument cluster cover 98 chevy cavalier
The cover-is that like a bezel? Older cars always used screws to hold the bezel in place. On lots of newer, the bezel or cover just has plastic clips that snap into holes or slots. If you see no visible screws, try pulling the cover off, starting at one end. Once the cover is off, you can see the screws that hold the cluster to the instrument panel.
Dec 06, 2016 | Cars & Trucks
How to replace the headlight switch assembly on a 1997 dodge grand caravan
The best I can offer is for a 1996 caravan:
REMOVAL
  1. Remove steering column cover.
  2. Remove over steering column bezel.
  3. Remove left end cover.
  4. Remove screw at left end of cluster bezel and headlamp switch.
  5. Remove screws holding cluster bezel to instrument panel from each side of steering column.
  6. Disconnect clip holding cluster bezel to instrument panel from above right vent louver.
  7. Separate cluster bezel from instrument panel.
Disconnect wire connectors from back of the bezel.
INSTALLATION
  1. Connect wire connectors into back of the bezel.
  2. Place cluster bezel in position on instrument panel. Use care not to place hands on louvers.
  3. Connect clips to hold cluster bezel to instrument panel. Use care not to add pressure on the A/C louvers to seat the cluster bezel clips.
  4. Install screws to hold cluster bezel to instrument panel on each side of steering column.
  5. Install screw at left end of cluster bezel and headlamp switch.
  6. Install left end cover.
  7. Install over steering column bezel.
  8. Install lower steering column cover.
May 02, 2015 | 1997 Dodge Grand Caravan
I need to know how to install an after market radio in a 1997 town and country lx
Go to Best Buy Or Pap Boys and Buy an Aftermarket install kit and A direct fit harness! Very easy to remove center bezal:
  1. Remove screw access cover.
  2. Remove the attaching screws holding bottom of the bezel to instrument panel.
  3. Remove the attaching screws holding top of the bezel to the instrument panel.
  4. Remove the bezel from the instrument panel.
  5. Disconnect the wire connector from back of the rear blower switch, if equipped.
  6. Disconnect the wire connector from the back of the HVAC Control.
  7. Remove the bezel.
Dec 23, 2014 | 1997 Chrysler Town & Country
Removal of instrument panel in a 1991 c2500 chevy pickup
remove bezel from around instrument panel , take your time not too break the bezel , block wheels pull shifter down into 1st if automatic and then take bezel cover loose and unplug wiring frrom switches .
be careful not too break these pieces they r usually very easy to break
then remove four retaining screws and gently remove cluster and unplug wires .
install in reverse order
Feb 02, 2013 | 1991 Chevrolet Silverado 2500
I need to replace the instrument panel bezel. How do I remove the headlight switch in order to remove the dash bezel?
DISCONNECT NEGATIVE BATTERY CABLE FIRST,REMOVE HEAD LIGHT SWITCH KNOB, REMOVE THE AUTO DIMMER KNOB. REMOVE THE RIGHT AND LEFT MOULDING FROM THE INSTRUMENT PANEL BY PULLING AWAY FROM THE INSTRUMENT PANEL AND SNAPPING OUT OF THE RETAINERS.REMOVE 12 SCREWS RETAINING THE FINISH PANEL AND REMOVE THE PANEL,REMOVE THE 2 HEADLIGHT SWITCH BRACKET RETAINING SCREWS AND PULL THE BRACKET AND SWITCH FROM THE INSTRUMENT PANEL,REMOVE THE NUT RETAINING THE SWITCH TO THE BRACKET, DISCONNECT THE CONNECTOR AND REMOVE THE SWITCH.
May 28, 2011 | 1991 Lincoln Town Car
How to change check engine bulb
You must remove the instrument panel to replace this bulb. You must first remove the bezel around the instrument panel to gain access to the screws holding the instrument panel in. Once the panel is removed it is just a matter of replacing the bulb in the back of the panel for the check engine lamp.
Nov 07, 2009 | 1998 Ford Explorer
How to replace corolla dashboard lights
Difficult to explain step by step. You need yo remove the instrument cluster. If youre technically minded its not very hard, start by loosening the Phillip"s head screws that is visible on the panel directly under the instrument cluster, give it a try!
Regards
Phillip
Sep 18, 2009 | 1995 Toyota Corolla
I need to replace an ignition switch on my 1999 Chrysler Sebring convertible, how do I remove the dashboard
This is for the ignition switch like you are asking for:
Ignition Switch REMOVAL & INSTALLATION Cirrus, Stratus, Sebring Convertible and Breeze CAUTION
The Supplemental Inflatable Restraint (SIR) system must be disarmed before working around the steering column. Failure to do so may cause accidental deployment of the air bags, resulting in unnecessary SIR system repairs and/or personal injury.
  1. Disarm the air bag system, as described in Section 6.
  2. Remove the left end instrument panel cover/fuse panel and remove the retaining screw holding the end of the instrument panel top cover.
  3. Remove the instrument panel center bezel.
  4. Remove the screws that secure the instrument panel top cover to the center of the instrument panel.
  5. Lift the instrument panel top cover enough to gain access to the knee bolster attaching screws.
  6. Remove the lower knee bolster attaching screws and knee bolster from the vehicle.
  7. Remove the lower steering column cover attaching screws. Pull down on the lower cover to clear the ignition key cylinder and key release (if equipped).
  8. Remove the lower steering column cover, sliding the cover forward while holding down the steering wheel tilt lever.
  9. Tilt the steering wheel down to the fully lowered position and remove the upper steering column cover.
  10. Remove the screws that hold the combination switch to the ignition lock housing.
  11. Place the ignition lock cylinder in the RUN position.
  12. Insert a small prying tool into the hole in the lower cover and depress the cylinder release tab.
  13. Remove the ignition lock cylinder from the steering column.
  14. Unfasten the electrical connectors from the switch.
  15. Using a No. 10 Torx® bit, remove the ignition switch mounting screw.
  16. Depress the retaining tabs and remove the switch. To install:
  17. Place the ignition switch in the RUN position. Be sure the actuator shaft in the lock housing is also in the RUN position.
  18. Install the switch, making sure the switch snaps over the retaining tabs.
  19. Install the retaining screw.
  20. Connect the wiring to the ignition switch.
  21. Install the ignition lock cylinder.
  22. Install the 2 combination switch mounting screws.
  23. Install the lower and upper shrouds.
  24. Install the knee bolster to the lower dashboard panel and tighten the lower knee bolster attaching screws.
  25. Install the screws that secure the instrument panel top cover to the center of the instrument panel.
  26. Install the instrument panel center bezel.
  27. Install and tighten the screw holding the end of the instrument panel top cover. Install the left side instrument panel/fuse panel cover.
More coming.....
Jun 26, 2009 | 1999 Chrysler Sebring
Dashboard Gauge
  1. Disconnect and isolate the battery negative cable.
  2. Remove Over Steering Column Bezel Replacement.
  3. Remove over steering column bezel.
  4. Remove left end cover.
  5. Remove screw at left end of cluster bezel and headlamp switch.
  6. Remove screws holding cluster bezel to instrument panel from each side of steering column.
  7. Disconnect clip holding cluster bezel to instrument panel from above right vent louver.
    1. Separate cluster bezel from instrument panel.
    2. Disconnect wire connectors from back of the bezel.
    INSTALLATION
    I wouldnt Recomend This Procedure To Anyone juse for Cleaning Purposes Unless Your VIEW OF IT IS "SERIOUSYL IMPARED IF it Moisture Has Accumilated Behind Face of it Then Find Out WHY and Resolve THAT PROBLEM FIRST Onherwise Here you Are. Have A Great DAY !! And Please Dont forget to RATE Me Thank You !
Jan 15, 2009 | 1999 Dodge Caravan
Computers & Internet Logo
12 people viewed this question
David Payne
David Payne
