Question about Electrolux Washing Machines
Eiflw50liw stuck on Clean tub? any way to reset?
How do I get a stuck hot tub filter out
The best way to never having your hot tub filter getting stuck is.
  1. remove the hot tub filter monthly for a cleaning
  2. Only install the filter hand tight
  3. Replace your hot tub filter yearly
If your hot tub filter is stuck the best way to remove it is
  1. Turn off the hot tub power
  2. Use a strap wrench for leverage
  3. You may have to remove the water for better access
How to Remove Stuck Hot Tub Filter
Aug 03, 2014 | Viking Spas Comp. Pool and Spa Filter...
Hot tub stuck in PR mode.
Are the pumps primed, the code represents that the pumps are being primed and should only stay on 2 - 5 minutes. If the pumps are not primed then you may have an air lock or dirty filters. You need to release the air or clean or replace the filters and your pumps will prime.
Mar 27, 2014 | Pool & Spa
High speed pump won,t shut down. New pump installed and new sensors
check for stuck high speed relay..if its stuck there has to be a reason..unplug the tub and check relay for fused contacts on the relay..clean with sandpaper or a fingernail board..(emery board)
Nov 08, 2013 | Pool & Spa
Washed a pillow and it exploded. Cleaned it out filled again did not wash does not make a sound does not spin does not empty NOTHING
If it is a front end washer some of the pillow maybe stuck behind the rubber between the door and the washer tub. Pull back the rubber and see if anything is stuck behind it. All the fibers from the pillow may have jammed the tub and made the machine overheat. Clean out anything you can reach and see if that frees up the tub. If the tub is moving look in your owner's manual and see if their is a reset button. Also check and see if the electrical fuse is kicked off, especially since most washing machine are on GFI outlets which are easily set off.
Oct 07, 2013 | Washing Machines
Auxiliary jr80 when going fast will choke itself and gas will drain out tub
im guessing its draining out the carby. you will need a new orifice, also make sure the float isnt broken or has holes. clean the carby really well
Oct 31, 2012 | Motorcycles
When we turn our washer elite on it gives us a error of sud?
susds error is a an fault error ....the machine has detected excessive tub pressure could be from not using "HE Soap ....if your are good but you might be using to much.... whens the last clean cycle you have ran to clean excess inner tub buildup on your washer .....
1 #drain all water out of filter sump behind lower front axcess panel make sure washer is unpluged
2# reinsert filter sump and and leave axcess panel off u make have to do this several times...
3# now check black rubber hose that goes from pump to bottom of tub remove clamp check for any obstructions in bottom of tub clean float ball of debris and reinstall and reconnect clamp to buttom of tub..
4# now pour 1 cup of vinegar directly in the tub where your clothes go and shut door( dosent mater what kind of vinegar or an affresh tablet
5# plug washer back in now lets run a clean cycle or any cycle that usues hot water ....
6# if unit suds code again this could happen a few times we need to flush out the buildup you may have to repeat steps 1-6 a couple of times....
Jan 26, 2011 | Kenmore Elite HE5t Washer
Water left in tub at end of load smells bad you don"t see water but can hear at a turn of the tub by hand.
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Hope your filter is clean. Don’t wait for the machine to jam to look into your filter.
You can use Affresh to clean your front loader. Deposits of soap and other such things can be stuck around the inside tub of your washer. Try this product, it works great on all front loaders. Use very hot water with the Affresh pellet with no clothes and run the machine through a cycle. Also helps with any stagnant water smells. Put the Affresh pellet inside the machine, not in the soap dispenser.
You can give me a ‘very helpful’ rating for the free help, can't you. Thanks.
May 20, 2010 | Maytag Neptune MAH5500B Front Load Washer
Buildup/smell inside washer
  • Hi,
  • Try this..
  • Check that the drain line is clear
  • Check the drain hose for kinks or blockages
  • Check pump for blockages
  • Check for build up of soap in the outer tub
  • Check for article of clothing stuck in the outer tub
Please rate my suggestion...
Apr 14, 2009 | Maytag Washing Machines
Washing Machines Logo
26 people viewed this question
Top Electrolux Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you an Electrolux Washing Machine Expert? Answer questions, earn points and help others
