Question about Gentex 2008 Kia Sedona - All Sedona models - K2 Auto-Dimming Rear View Mirror
Rear AC not blowing
The AC in the front of the van works, but not the rear unit, whether controlled in the front or rear controls.
1998 Ford Econoline Van E-150 Front A/C blows cold rear A/C blows warm?
Generally you would need to check the level of freon in the system, and probably the expansion valve in the rear unit. You should have one hot and one cold ac line going to each evaporator.
Aug 22, 2012 | Ford Cars & Trucks
No rear air but blows good
if the front ac works well but the rear is hot check to rear control switch located in the front ac control head.
it has a vaccum-electrical switch and these go bad often
Aug 05, 2010 | 1999 Ford Windstar
Does the 2002 Dodge caravan have AC in the rear of the van? Or does it have just AC vents in the front of the Van.
If your van has rear AC/Heat there is a roof mounted control for the rear. There is also a control knob on the front panel, that says rear control auto, rear control & rear control off.
Jan 19, 2010 | 2002 Dodge Caravan
The ac blows hot air in the front and cold air in the back
Either the door that controls whether air from the heater or ac is stuck in between or the ac system is having trouble. Minivans sometimes have seperate compressors for the rear and front.
Sep 17, 2009 | 2000 Pontiac Montana
The a/c is not working in the rear
what guage ? temp guage or pressure guage?
is the fan motor putting out any air movement at all ? if the front ac works fine and only the rear is not working it should point either controls for the rear or rear fan motor not working... make sure you check rear contols as well as the main console control...
Aug 04, 2009 | Heating & Cooling
Air conditioning not working properly
Would have him check out side air temp sensor ,thermister and rerove control head and inspect for burned terminal.1st.
Jun 20, 2009 | 2002 Oldsmobile Silhouette
2004 suburban rear a/c only blows hot air
ase mechanic:
there are separate actuators for the blend doors. one for heat and one for cool. they work opposite and in conjuction with each other, if that makes any sense. ones open, ones close, for each different climate. sounds like the the cold one isn't opening in the rear.
Jan 27, 2009 | 2004 Chevrolet Suburban
AIR CONDITIONER
On most vehicles with front and rear A/C, the two systems are basically independant of each other just sharing the compressor and condensor. It is possible that the Mode Door (controls where the air flow is sent; ie: windshield, vents, floor) is out of adjustment or sticking.
May 20, 2008 | 2004 GMC Savana
Gentex 2008 Kia Sedona - All Sedona models - K2 Auto-Dimming Rear View Mirror Logo
52 people viewed this question
Top Gentex Optics Experts
Lawrence Oravetz
Timllfixit
ka4iup
ka4iup
Are you a Gentex Optic Expert? Answer questions, earn points and help others
