Question about HT 125 Stretching Robotic Human Touch Massage Chair - Black
Pup down is not function
If i try the upp down the chair don't move and the the program stops.
Bruno Electra-Ride III stair chair lift goes up but will not come down.
good test method the motor works ok
faulty up down switch
or the part/solenoid ? that reverses the current to the lift motor so they run clockwise and reverse
for up and down the stairs
wow some have remotes
could be a faulty receiver it remote to the chair
Nov 13, 2016 | Cars & Trucks
Hoveround won't move.
Double check to be sure drive levers are fully engaged. Go down and up a few times. If problem persists have Hoveround come and check it out. One of the drive motors may have shorted out when you continued driving with gravel in the wheel.
Mar 29, 2015 | Hoveround MPV5 Electric Wheelchair - Used...
What is a PUP file
PUP stands for Potentially Unwanted Programs. Basically anything installed that could potentially causes problems with your system
Feb 20, 2015 | Microsoft Windows 7 Home Premium 64BIT...
What the lights moving right to left on jazzy select 6 power chair
If you are moving as soon as you turn on the chair, the lights will move from right to left. Try waiting a few seconds and see if the lights stop moving. If they do stop, then you can move forward. Hope this helps.
Jun 20, 2014 | Pride Jazzy Select 6 Indoor Power...
Pronto m41 moves slow at all times
If you have a seat lift on your chair, you will have to lower the seat lift. This is call limp mode so the chair does not move to fast and tip over while the person is in the chair. If this is not the case, then your chair controller may be over heating and it will also cause the chair to go into limp mode. this is a better option than totally stopping. the way to correct this is to let the chair sit and "cool down" for a little while. It usually takes about 30 minutes, sometimes less in cooler environments to get the chair back to normal use. If neither are the solution, then you have a problem with the chair that causes the controller to reduce the output. You will need to get an authorized Tech to check the chair out to determine the root cause.
Oct 30, 2013 | Invacare Pronto M41 Power Wheelchair
DATAMNGR COORDINATOR HAS ENCOUNTERED
Depending on which level of risk of the Pup.datamngr virus has infiltrated your PC, you might find it is hard to get rid of this sophisticated worm. Some people have successfully cleaned out the stubborn worm, but since one of the primary functions of this virus is to disable security programs,so the method of using anti-virus program is not always a foolproof approach.
Please follow these steps to get rid of Pup.datamngr virus manually:
Step 1: Press CTRL+ALT+DEL or CTRL+SHIFT+ESC. Open the Windows Task Manager.
If that didn't work, try another way. Press the Start button and click on the Run option. This will start the Run tool. Type in taskmgr and press OK. This should start the Windows Task Manager
Step 2: Within the Windows Task Manager click on the Processes tab. Find the process by name. random.exe. Then scroll the list to find required process. Select it with your mouse or keyboard and click on the End Process button. This will kill the process.
Step 3: Delete malicious registry entries.
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Active Setup\Installed Components\random
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\policies\Explorer\run\random
Step 4: Remove malicious files of Pup.datamngr virus
C:\windows\system32\services.exe
HKCU\SOFTWARE\Microsoft\Windows\CurrentVersion\Ext\Settings\{F34C9277-6577-4DFF-B2D7-7D58092F272F} (PUP.Datamngr)
C:\Program Files\Search Results Toolbar\Datamngr\SRTOOL~1\searchresultsDx.dll (PUP.Datamngr)
Sep 11, 2013 | Microsoft XP Computers & Internet
Can rocking chairs help students with concentration problems?
They sure can! According to research, rocking chairs help students with ADD and ADHD with concentrating better as well as adapting to learning environment. The reason for this is because rocking chairs keep on moving back and forth, the ADD students don't need to worry as much about moving all the time, leaving more room to concentrate on studying.
Oct 24, 2012 | Furniture
My father has a Jazzy 600 electric wheelchair and it has been working fine, batteries are only a few months old but all of a sudden it will not charge. Should not be able to move the chair while it is...
Sounds like the inhibit function of the chair has been damaged. This function will not let you move the chair while charging. If Dad doesn't have the charger off when plugging in to the chair or removing it it can short out the charger port causing your problem. Unfortunately the only fix is to replace the joystick/controller. If Medicare paid for Dad's chair then they will pay for most of the repair costs. Contact the provider that brought Dad's chair and ask if they can order a new joystick for you Hope this helps
Jun 06, 2011 | Health & Beauty
The power funtion drive on my Invacare Storm TDX 5 wheelchair, which operates the tilt, recline, elevating leg rest and seat elevator has stopped working. The drive switch as it appears on the LED screen...
1) Yes your power seat functions can be programed into your drive 4,You'll need a programmer or have to take it into a shop.
2) yes the chair can be manually elevated down,You'll want to take it to a shop for that ,because it requires jumping the power to the seat elevator and swapping the wires around and I would never recommend my customers to do such a thing because of electric shock or burning up the chair.
If your chair has a four wat toggle switch("what controls your power seat functions elev,recl,telt,ext) If thats what your using right now there may be a red light that comes on in drive lock out ,If that light is not on follow that wire all the way down it may have been pinched or cut.If so it will need to be replaced.
Problems like this one is hard to trouble shoot over text or phone ,if your four way switch cord is cut or smashed .Your gunna have to take it into a shop just to make sure ,It didnt cause any electrical problems in your chair .
Good luck hope i had the chair in front of me so i could help you more.
Jan 15, 2011 | Invacare Health & Beauty
HT 125 Stretching Robotic Human Touch Massage Chair - Black Logo
29 people viewed this question
Top HT Furniture Experts
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a HT Furniture Expert? Answer questions, earn points and help others
