Question about Bushnell BackTrack Handheld GPS Receiver
Back tracker m88 manuel
Midi file player
Ctk 810in not able to read or play midi files
If you connect to PC using USB interface, then use a commercial midi player - e.g Melody Assistant or Harmony assistant to play MIDI files to it.
Or else download "SMF convertor" to convert midi files and download compatible file to keyboard.
Aug 10, 2013 | Casio CTK810 61 Key Keyboard
Best midi player?
You my find this midi player useful. It's provided at no cost and is rather simple-in-use, perfectly compatible with any Windows OS. Having it set up you'll always be able to listen to midi files.
Sep 20, 2012 | Samsung N Computers & Internet
I CAN NOT PLAY MUSIC USING MY MEDIA PLAY
windows media does not support all extensions. Below are the examples. if you have the right format and still you are not able to play then best option is to upgrade or reinstall media player. Windows Media Player 6.0 loadTOCNode(2, 'moreinformation');
  • Windows Media formats
    File name extensions: .asf, .asx, .avi, .wav, .wma, .wax, .wm, .wmv, .wvx
  • RealAudio and RealVideo (version 4.0 or earlier)
    File name extensions: .ra, .ram, .rm, .rmm
  • Moving Pictures Experts Group (MPEG)
    File name extensions: .mpg, .mpeg, .m1v, .mp2, .mpa, .mpe
    Note MPEG 2 requires third-party software or hardware decoders.
  • Musical Instrument Digital Interface (MIDI)
    File name extensions: .mid, .rmi
  • Apple QuickTime (version 2.0 or earlier)
    File name extensions: .mov
  • Macintosh AIFF Resource
    File name extensions: .aif, .aifc, .aiff
  • Intel Video File
    File name extensions: .ivf
  • UNIX
    File name extensions: .au, .snd
Windows Media Player 6.1, 6.2, 6.4, 7, 7.1, Windows Media Player for Windows XP, and Windows Media Player 9 Series loadTOCNode(2, 'moreinformation');
    File name extensions: .asf, .asx, .avi, .wav, .wax, .wma, .wm
  • Audio Visual Interleave
    File name extension: .avi
    File name extensions: m3u, mp2v, .mpg, .mpeg, .m1v, .mp2, .mp3, .m3u, .mpa, .mpe, mpv2
  • DVD Video
    File name extension: .vob
    Note DVD playback requires third-party software or hardware decoders and is supported only in Windows XP.
    File name extensions: .mid, midi, .rmi
  • Apple Macintosh AIFF Resource
  • Sun Microsystems and NeXT
  • Intel Video File
    Note Intel Video File support requires the Intel Video 5.x codec.
  • Windows Media Player Skins
    File name extensions: .wmz, .wms
  • QuickTime Content
    File name extensions: .avi, .mov, .qt
    Note Windows Media Player can play back older forms of the QuickTime format only. For additional information, click the following article number to view the article in the Microsoft Knowledge Base: (http://support.microsoft.com/kb/316992/EN-US/ ) Windows Media Player Multimedia File Formats
  • Algebraic-Code-Excited Linear Prediction
  • UNIX
  • Macromedia Flash
    File name extension: .swf
Dec 10, 2010 | Gateway M350CS PC Notebook
How does one download playbacks of arrangements in Sibelius to an MP3 player?
There are a couple of ways to do this. If you have a sound exporter you can use them, (File>export>audio) if not you need to create a MIDI file of the score. I've done this for a few songs and it creates audio that can be played back in iTunes, and I'm guessing on MP3 players too.
File>export>MIDI File. chose your type of file and where you want to save it. This plays back on iTunes and Windows media player etc etc.
Good Luck!
NB the resulting MIDI file is usually really quiet, but this is normal so don't panic.
Dec 21, 2009 | Sibelius 5 Professional Edition
Loading an MPC5000 with midi files
if the mpc has GM soundbank then this should be possible. You might be better off recording the audio from a suitable GM unit first of all before gigging with it, then you can make it sound the way you want and change the key to suit etc.
Dec 18, 2009 | Akai Mpc2500 Music Production Center
Cell phone - cect m88 - front camera?
Hello, I got an m88 miphone too!... go to programs... press camera.. and then press menu... then go to mode and select which camera u want
May 24, 2009 | Microsoft Computers & Internet
My MIDI won't play back even when I play the file, no matter which program I use to play it. The computer I use is a Compaq Presario, I have Cakewalk Home Studio 2002 on it, and my sound card is SB X-FI...
The default MIDI setting of your PC may have been set for another MIDI device (for example, if Cakewalk Home Studio has been used with a MIDI compatible keyboard). Go to... Control Panel / Sounds and Audio Devices / Audio / MIDI music playback and change the setting back to your soundcard (and set as default if you prefer).
May 03, 2009 | Computers & Internet
Midi vs. Sound
Think of MIDI like the old time player pianos where you put a roll into it and the punches on the paper roll told the piano what notes to play. MIDI is a way for computers and musical instruments to communicate what is being played. When you plug your keyboard into your computer and enable it in Cakewalk, then Cakewalk records what notes you are playing on your keyboard (makes a piano roll file). Then when you tell Cakewalk to play this file back it communicates to your keyboard and says play these notes just like a person was sitting there playing these notes. The distinction here is you are recording and playing back your performance (which keys you pressed, how hard you struck the keys, how long you held the keys for sustain, etc...). No sound is actually being recorded, just the PERFORMANCE. When you play it back, the keyboard regenerates the sounds on the fly just as if you were actually sitting there performing the music again. Same thing applies to other MIDI enabled instruments (drums, guitar, saxaphone, etc...). This opens up all kinds of possibilities, you can redirect the recorded MIDI file to a completely different sound or instrument. Example... you record MIDI of you playing piano song, then you have Cakewalk play this MIDI back to your keyboard but you change the sound on your keyboard to guitar, it will play the same song, but now you will hear guitar instead of piano. Get it?
Feb 02, 2009 | Cakewalk Music Creator 2 for PC
Playing of midi files
At the start menu click on control panel>add or remove programs>custom settings>choose default media player. Select the playmusic as your default media player. Then press ok.
Nov 06, 2008 | Notation Technologies Play Music
No midi out device is detected
If you dont have a joystick port on the card, then you dont have a midi out. make sure your "out" or"playback" is patched to your card's synthesis engine, wavetable or GM/GS midi playback, and not to a "midi out" which really means a physical midi port.
Mar 01, 2008 | Creative Labs Sound Blaster Live! 5.1...
Bushnell BackTrack Handheld GPS Receiver Logo
83 people viewed this question
Top Bushnell GPS Experts
Martin Murray
Are you a Bushnell GPS Expert? Answer questions, earn points and help others
