Question about Hype Mini Capsule Bluetooth Speaker
My Hype mini capsule bluetooth speaker will connect to my phone but won't play music
The bluetooth will connect on my phone but cannot get sound out of the speaker, even when volume is highest
I have purchased 2 of these speakers. I want to Bluetooth connect them to my iphone. How do I do this and get music from both speakers?? Thx
If you have purchased Speakers with Bluetooth Connectivity capability you can do this by switching on the speakers and on your iphone use the Bluetooth Pairing Option from Bluetooth settings to establish connectivity and play music to hear from speakers
Jun 15, 2015 | Audio Players & Recorders
Still need to know how to download music from cell phone to the Omnitech Bluetooth speakerphone everything else works except for music playing on my bluetooth
You do not download music from your cell phone to your Bluetooth speaker. You pair and connect your cell phone with the speaker via Bluetooth and when you listen to music or make phone calls on your phone the sound comes out through the speaker. Please read the instructions on how to connect the phone to the speaker.from the set up guide that came with the speaker.
Jan 03, 2015 | Cell Phones
How to pair ny mini bluetooth craig speaker to my
Turn on the bluetooth of your phone first: Go to settings>Wireless and Networks>Enable Bluetooth and disable discovery limit in bluetooth settings. After that make sure the bluetooth in your speaker is on and let your phone search the speaker and let it pair with it after that go into your phone's music player and look for its play options and if you see via bluetooth click it. Just let me know if you need further instructions or you could watch this video showing how he pairs his bluetooth speaker from his phone DBEST London Bluetooth Mini Speaker Review
Oct 16, 2014 | Cell Phones
Why does led flash blue then red constantly
Hello there,
From this download here
http://store.x-mini.com/upload/manuals/120416%20X-mini%20KAI%20Manual%20%28Eng%29.pdf
LED Battery Indicator
When charging:
Red - X-mini KAI Capsule Speaker is charging
Blue - X-mini KAI Capsule Speaker is fully charged
When in use:
Blue - X-mini KAI Capsule Speaker is turned on
Blue (dim) - X-mini KAI Capsule Speaker battery low
During playback through bluetooth, users will be alerted if
charging is required by a three-beep indication
If this is not right you will have to email them on support@xm-i.com
or if is in Warranty, get it repaired by the Seller.
Sep 16, 2014 | X-Mini KAI XAM11-B Bluetooth Capsule...
How do i pair my x-mini kai capsule speaker with my phone?
Where the bluetooth options on your phone will depend on your phone.
So to put the speaker into Bluetooth pairing more slide the power switch to the right hand side. If the speaker has power then a blue light to the right should light up.
Once this is done you will need to find the Bluetooth devices option on your phone. This will be located somewhere under settings - connectivity.
When you locate the device in bluetooth devices, select it then select pair.
If you can't find the bluetooth options on your phone, comment on this answer with the phone name and model and I will see if I can find out for you.
Sep 11, 2014 | Xskn XAM11-B X-mini Kai Capsule Speaker -...
Bluetooth & sound
Generally, connecting phones via bluetooth to a laptop just allows for file transfer between the two devices. It is not to input sound from the phone through the speakers of the laptop. You would need a bluetooth audio device for that such as bluetooth speakers or headphones
Jan 28, 2014 | Dell Vostro Computers & Internet
XMI X-Mini Ii Capsule Speaker won't charge
The rechargeable battery may be exhausted and probably needs to be replaced. Try www.ebay.com type make and model of Capsule Speaker and scroll through the list. The only other option is try the manufacture, contact customer support and the technical department.
Jun 01, 2012 | KB Covers Xam4-r X-mini Ii Capsule Speaker...
My eternity will not playback any music or ringtones i have even the keypad sound is not working!
If you had a bluetooth device connected and it did not disconnect properly then the phone may be trying to play the sounds to the bluetooth and not the speaker, Turn the phone's bluetooth off and then on and it should work. Also, if you look at a sound file or video file it will show the bluetooth symbol next to it, which means that it is playing to bluetooth and not the phones outher outputs.
May 10, 2010 | Samsung Eternity Cell Phone
Hype Mini Capsule Bluetooth Speaker Logo
22 people viewed this question
Top Hype Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Hype Audio Player and Recorder Expert? Answer questions, earn points and help others
