Question about Olympia InfoGlobe Caller ID
Only the top half of the text is displaying. - Olympia InfoGlobe Caller ID
    Problem Solver:
  • 9 Answers
If you can afford to , reset your phone. Otherwise, your display might have an error
Posted on Nov 23, 2013
Panasonic viera
Try replacing your video cable, if that doesn't work, try using a different input on the T.V. If that doesn't fix it, you may be out of luck with out an extended warranty.
Dec 06, 2013 | Panasonic TH-50PX75U Plasma HDTV
Printing text at the same label in two directions
Have you tried unplugging it and plugging it in again?
Nov 22, 2013 | Zebra TLP 2844-Z Thermal Label Printer
Why is my screen opening at half screen?
not sure what half screen you are referring to
click start control panel display desktop you can select a different desktop from the drop down list
or a browse button where you can select different pictures this may vary depending on your operating system
also settings you can change the settings for more or less pixels or from the drop down list pick the appropriate level of color range or troubleshoot also select advanced then general dpi normal size,larger size or custom settings
always click APPLY after making any changes
on the top of the internet page you should see some tabs file edit view favourites tools and help click on the view tab on the drop down list you should see a zoom size %
click a different percentage also a text size you might try a different text size although this will not increase the size of the page only the text fonts inside it
if you do not see these tabs in the top toolbar
right click in the top toolbar you will see a number of toolbars and options select the menu tab this will add at it to the toolbar
or if its actually half of the screen
you will need to connect to another monitor or your television to your computer with the vga lead monitor connection
click start control panel display change display settings adjust resolution this may vary depending on your operating system
you should see a no 1 and a no 2 with detect and identify keep an eye on the screen when you select the number tabs this may vary depending on your operating system
when you select the no 2 tab this should be the extended desktop always click apply after making any changes
or click start control panel administration tools computer management device manager scroll to monitors right click select scan for hardware changes
if you can get an extended desktop your monitor is faulty
if you cant get an exended desktop
hope it helps
Aug 09, 2012 | HP Computers & Internet
Vizio half of screen is solid color bars. Top half works great.
You have either the circuit board that drives that half of the screen(one for top and another for the bottom) or you have a bad display panel.
May 25, 2012 | Vizio 32-inch Sv320xvt Full 1080p 120hz...
My JVC model AV-20F476 has a black-out box that covers most of the bottom half of the screen.
Go into menu and under CLOSED CAPTIONS look to see if TEXT is engaged---if it is set to text 1 turn it off or to text 2,3,4, etc
Text was a feature never really used but it is there, some cable boxes also have this setting/feature.
Let me know if you have questions.
Jan 11, 2012 | JVC Televison & Video
Display on my Brivis LCD panel is missing half the text.
There could be a problem with the LCD display or the PCB of the control. If it doesn't bother you, I wouldn't have it fixed, but if it does I would. Generally the text/numbers displays the time and the room and set temperatures. It also shows messages about the heater. i.e. "Pre heating heater furnace - Please wait!" This display is not really important.
Mat
Jul 20, 2009 | Heating & Cooling
Bottom half of monitor displays top half of desktop
You could try a different resolution for the monitor.It's possible the monitor cant support the resolution your trying to display your desktop at.
Jun 01, 2009 | ViewSonic GS773 (White) 17" CRT Monitor
Tool, taskbars and text all shrunk to half normal size
Did you try Control Panel and Display, Setting tab and adjusting the resolution by moving the slider? That should take care of it.
Jan 17, 2009 | Dell Latitude D800 Notebook
Text is too high on tilt display. Top of text and numbers are cut off.
sounds like the lcd screen has come unglued from the tilt window.
Aug 14, 2007 | NorStar T7316E Corded Phone
Olympia InfoGlobe Caller ID Logo
117 people viewed this question
Top Olympia Lands Phones Experts
ray gallant
Jose Ma DM.
Jose Ma DM.
Tom Chichester
Are you an Olympia Lands Phone Expert? Answer questions, earn points and help others
