How to remove bezel from around instrument panel on 1991 jaguar vp.
I need to remove bezel and instrument panel from 1991 jaguar vp. i understand bezel is retained by screws but i can't locate the screws.
4 Suggested Answers
pal03246
  • 726 Answers
SOURCE: Interior center bezel removal...
Clips only. Give it a good tug and it should come out.
Posted on Jul 20, 2008
  • 28 Answers
SOURCE: Instrument Cluster removal
you need to take off the steering column cover upper and lower halves to get two the two screws that are hidden under the rubber dust cover.thanks for using fixya!
Posted on Aug 30, 2008
  • 14036 Answers
SOURCE: I need to replace the
DISCONNECT NEGATIVE BATTERY CABLE FIRST,REMOVE HEAD LIGHT SWITCH KNOB, REMOVE THE AUTO DIMMER KNOB. REMOVE THE RIGHT AND LEFT MOULDING FROM THE INSTRUMENT PANEL BY PULLING AWAY FROM THE INSTRUMENT PANEL AND SNAPPING OUT OF THE RETAINERS.REMOVE 12 SCREWS RETAINING THE FINISH PANEL AND REMOVE THE PANEL,REMOVE THE 2 HEADLIGHT SWITCH BRACKET RETAINING SCREWS AND PULL THE BRACKET AND SWITCH FROM THE INSTRUMENT PANEL,REMOVE THE NUT RETAINING THE SWITCH TO THE BRACKET, DISCONNECT THE CONNECTOR AND REMOVE THE SWITCH.
Posted on May 28, 2011
How to remove the instrument cluster cover 98 chevy cavalier
The cover-is that like a bezel? Older cars always used screws to hold the bezel in place. On lots of newer, the bezel or cover just has plastic clips that snap into holes or slots. If you see no visible screws, try pulling the cover off, starting at one end. Once the cover is off, you can see the screws that hold the cluster to the instrument panel.
Dec 06, 2016 | Cars & Trucks
How to replace the headlight switch assembly on a 1997 dodge grand caravan
The best I can offer is for a 1996 caravan:
REMOVAL
  1. Remove steering column cover.
  2. Remove over steering column bezel.
  3. Remove left end cover.
  4. Remove screw at left end of cluster bezel and headlamp switch.
  5. Remove screws holding cluster bezel to instrument panel from each side of steering column.
  6. Disconnect clip holding cluster bezel to instrument panel from above right vent louver.
  7. Separate cluster bezel from instrument panel.
Disconnect wire connectors from back of the bezel.
INSTALLATION
  1. Connect wire connectors into back of the bezel.
  2. Place cluster bezel in position on instrument panel. Use care not to place hands on louvers.
  3. Connect clips to hold cluster bezel to instrument panel. Use care not to add pressure on the A/C louvers to seat the cluster bezel clips.
  4. Install screws to hold cluster bezel to instrument panel on each side of steering column.
  5. Install screw at left end of cluster bezel and headlamp switch.
  6. Install left end cover.
  7. Install over steering column bezel.
  8. Install lower steering column cover.
May 02, 2015 | 1997 Dodge Grand Caravan
Removal of instrument panel in a 1991 c2500 chevy pickup
remove bezel from around instrument panel , take your time not too break the bezel , block wheels pull shifter down into 1st if automatic and then take bezel cover loose and unplug wiring frrom switches .
be careful not too break these pieces they r usually very easy to break
then remove four retaining screws and gently remove cluster and unplug wires .
install in reverse order
Feb 02, 2013 | 1991 Chevrolet Silverado 2500
Need to find out how to change the turn signal/headlight switch on a 2001 Dodge Neon
dissconnect negitive battery terminal, open dirvers and passenger doors.remove dash end caps then use a pry stick or screwdriver and pry out left and right A pillar trim panels. next is to remove the bezel, lift up on the outter bottom edges of top bezel and along rearward edge of top cover top disengage clips, pull top cover rearward intil pins disengage from instrument panel and then remove from dash, next is to remove the cluster bezel and then the top and bottom steering column covers, the next step is to remove the screws holding the switch. then the connectors to switch.lift switch straight up and remove. to install reverse removal procedure. heres a diagram to help you understand the covers and bezels locations. hope this helps good day.johnjohn2_135.gif
Jun 25, 2011 | Dodge Neon Cars & Trucks
I need to replace the instrument panel bezel. How do I remove the headlight switch in order to remove the dash bezel?
May 28, 2011 | 1991 Lincoln Town Car
I need to know how to take the old stereo out of my 1999 buick regal to put in my new cd player? i cant figure out how to get the dash out
Hi, here is the procedure from autozone.com. Please let me know if you have any questions, and thanks for using FixYa.
Removal & Installation
  1. Obtain the THEFTLOCK® codes and radio station presets before attempting to remove the radio, if applicable.
  2. Disconnect the negative battery cable.
  3. Remove the trim plate bezel from around the radio using the following procedure.
    1. Adjust the steering wheel for access.
    2. Remove the ignition switch cylinder bezel.
    3. Remove the left side instrument panel fuse block access opening cover.
    4. Remove the instrument panel cluster trim plate screws.
    5. Starting at the right side of the instrument panel cluster trim plate, grasp the trim plate and carefully pull rearward. Continue working around the trim plate until all of the retainers are released from the trim pad.
    6. Detach the electrical connectors from the hazard switch and remove the trim plate from the vehicle.
  4. Remove the screws from the radio and pull the radio gently from the instrument panel.
  5. Detach the instrument panel wiring harness connector and the antenna cable connector from the radio.
Fig. You must remove the instrument panel cluster trim panel in order to remove the radio assembly
To install:
  1. Installation is the reverse of the removal process, noting the following:
    1. After the electrical connection is secure and the antenna cable is connected, find the radio locator tab.
    2. If the locator tab is difficult to align to the instrument panel locator opening, pull the radio towards you and reposition the antenna cable.
    3. Gently install the radio to the instrument panel, aligning the radio locator tab to the instrument panel locator opening while carefully pressing the radio into the instrument panel until fully seated.
  2. Install the trim plate bezel.
  3. Connect the negative battery cable.
  4. Unlock the THEFTLOCK® radio (if applicable).
  5. Program the radio stations back into the radio as recorded at the beginning of this procedure (if applicable).
Jan 28, 2011 | Car Audio & Video
How to change heater core on 2005 dodge stratus?
  1. Disconnect the negative battery cable.
  2. Remove the radio/HVAC control module bezel. CAUTION
    The vehicles covered by this manual are equipped with a Supplemental Restraint System (SRS), which uses air bags. Whenever working near any of the SRS components, such as the impact sensors, air bag modules, steering column and instrument panel, disable the SRS, as described earlier in this section.
  3. Remove the right instrument panel side trim.
  4. Remove the two retaining screws at the lower right side support beam.
  5. Remove the instrument panel support bolt at the A-pillar.
  6. Remove the left instrument panel side trim and upper instrument panel bezel.
  7. Remove the lower knee bolster and console screws at the instrument panel.
  8. Remove the gearshift knob and shifter bezel.
  9. Remove the mounting screws at the front and rear of the floor console. Remove the front and rear console halves.
  10. Remove the right side instrument panel support strut.
  11. Drain the cooling system into a suitable container, then disconnect the heater hoses at the cowl panel. Plug the heater core outlets to prevent coolant from spilling during unit housing removal.
  12. Remove the mounting screws and heater core cover.
  13. Remove the heater core from the vehicle. To install:
  14. Carefully position the heater core unit into the heater housing.
  15. Install the heater core cover onto the heater housing and tighten the mounting screws.
  16. Install the right side instrument panel support strut.
  17. Install the front and rear console halves.
  18. Install the shifter bezel and gearshift knob.
  19. Install the lower knee bolster and console screws at the instrument panel.
  20. Install the upper instrument panel bezel and left instrument panel side trim.
  21. Install the instrument panel support bolt at the A-pillar.
  22. Install the two retaining screws at the lower right side support beam.
  23. Install the right instrument panel side trim.
  24. Install the radio/HVAC control module bezel.
  25. Fill the cooling system to the proper level.
  26. Connect the negative battery cable.
Aug 13, 2010 | 2005 Dodge Stratus
I need to replace globe on instrument panel. How do I dismantle the dashboard in order to get to the globe. I have a 1994 Ford Falcon ED Futura Cheers
the instructions are as follows:-- The dash on a Ford is made up of numerous trim panels that help contain the instrument panel, cluster and other components. You will likely need to remove any to all dash panels to work on any parts in the front of the truck, and you will need to remove some panels first to remove others. Please note that the removal procedure can vary greatly depending on the model year of your car. 1) Disconnect the truck's negative battery cable by peeling back the insulator if one is equipped and loosening the clamp nut for the black cable with a wrench. Set this cable aside so it won't accidentally come into contact with the battery post during the dash removal.2Remove the driver's-side knee bolster by removing the two screws located at the bottom (they should require a Phillips-head screwdriver) and prying around the top of the panel with a trim stick, flat screwdriver or other dull, flat-bladed tool to release the panel from its clips.3)Unscrew the screws for the instrument cluster bezel, which surrounds the cluster and steering column; these screws are at the two lower corners. Use the trim stick to release the bezel's clips at the top end, pry it off and disconnect any electrical connectors attached to it. You may need to remove the steering wheel in order to remove this bezel.4)Work the trim stick or other flat tool around the entire edge of the instrument panel center bezel--which surrounds the stereo and heater/air conditioner controls--to release it from its clips. This one panel has no screws to remove.5)Remove the screws for the upper finish panel, which aren't accessible until you remove the instrument panel bezel, and remove the panel from the dash.6)Open up the glove compartment door. Press the two sides of the compartment inward until until its bumpers clear the stops. Remove the fasteners at the bottom of the box to remove the glove compartment.7)Remove the pushpin fasteners that secure the center brace cover at the bottom of the panel and remove the panel. This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya
Mar 02, 2010 | Ford Futura Cars & Trucks
Need to replace instrument cluster/AC bulbs
Hello, You can obtain a 2004 Ram Factory Service Manual with all of that information available from Promanuals.net. The reason why it may be so important is because right before the removal instructions the service manual has diagnostic instructions to try. There are numerous pages on removing the instrument cluster, and cluster bezel.
(1) Disconnect and isolate the battery negative
cable. (For Airbag)
(2) Remove the cluster bezel from the instrument
panel. (Refer to 23 - BODY/INSTRUMENT PANEL/
CLUSTER BEZEL - REMOVAL).
(3) Remove the four screws that secure the instrument
cluster to the instrument panel structural support
(Fig. 5).
(4) Pull the instrument cluster rearward far
enough to access and disconnect the instrument
panel wire harness connectors for the cluster from
the connector receptacles on the back of the cluster
housing.
(5) Remove the instrument cluster from the instrument
panel.
Oct 01, 2009 | 2004 Dodge Ram 1500
Dashboard Gauge
  1. Disconnect and isolate the battery negative cable.
  2. Remove Over Steering Column Bezel Replacement.
  3. Remove over steering column bezel.
  4. Remove left end cover.
  5. Remove screw at left end of cluster bezel and headlamp switch.
  6. Remove screws holding cluster bezel to instrument panel from each side of steering column.
  7. Disconnect clip holding cluster bezel to instrument panel from above right vent louver.
    1. Separate cluster bezel from instrument panel.
    2. Disconnect wire connectors from back of the bezel.
    INSTALLATION
    I wouldnt Recomend This Procedure To Anyone juse for Cleaning Purposes Unless Your VIEW OF IT IS "SERIOUSYL IMPARED IF it Moisture Has Accumilated Behind Face of it Then Find Out WHY and Resolve THAT PROBLEM FIRST Onherwise Here you Are. Have A Great DAY !! And Please Dont forget to RATE Me Thank You !
Jan 15, 2009 | 1999 Dodge Caravan
Computers & Internet Logo
11 people viewed this question
David Payne
David Payne
