Question about Beverage-Air MT45 Beverage Cooler Commercial
Model mt 45-v trouble shooting can not get cool
  • Beverage-Air Master
  • 5,323 Answers
FREEZER /FRIDGE NOT COOLING: Optimum refrigerator temperature at or below40° F(4° C). The freezer temperature should be0° F(-18° C). Check temperatures periodically. Appliance thermometers are the best way of knowing these
Check ur cold control thermostat, ur thermistors in both fridge and freezer ( they should be checked for both ohms and for amount of current being put out as per ur model ), ur air flow vent from freezer to fridge.( to make sure it opens and closes without any restrictions) On thermistors check for A close circuit and amount of ohms not just an Ohm reading. As per ur model. Most should atleast show 1200 ohms. Also Check door seals for leakage.
Evaporator coils
Poor cooling is often the result of a heavy frost build-up on the evaporator coils. You can't see these coils without removing a panel on the inside of your freezer. A sure sign that there is a build-up is the presence of any frost or ice build-up on the inside walls, floor, or ceiling of the freezer. Such a frost build-up usually indicates a problem in the self-defrosting system or damaged door gaskets.
If one of the components in the self-defrosting system fails, the refrigerator continues to try to cool. Eventually, though, so much frost builds up on the evaporator coils that the circulating fan can't draw air over the coils. There may still be a small amount of cooling because the coils are icy, but with no air flow over the coils, cooling in the refrigerator compartment is quite limited.
FAN check to see if it is operating or restricted A fan that is not blowing or restricted will not circulate the cold air properly.
Often, the first thing that folks do when their refrigerator starts to feel warm is turn both controls on the coldest settings.This is exactly the WRONG thing to do.Turning the cold control to the coldest settingwillkeep the compressor running longer and make lots of cold air.
But turning the air door to the coldest settingclosesthe airway to the food section. Lots of cold air is made, but most of it stays in the freezer section, and the food section actually getswarmer.
Condenser
Self-defrosting refrigerators all have a set of coils and a cooling fan, usually under the refrigerator, that need to be cleaned regularly. If these coils get coated with dust, dirt or lint, the refrigerator may not cool properly. The coils may appear to be a thin, black, wide radiator-like device behind the lower kick-panel. To clean them, disconnect the refrigerator from the power source, use a refrigerator condenser brush and your vacuum cleaner to clean the coils of any lint, pet hair, etc. You may not be able to get to all of the condenser from the front, it may be necessary to clean the remainder of the condenser from the rear of the refrigerator.
May also need to check the defrost timer, u can get by and test manually by placing a small screw driver into the tiny slot or hole underneath the timer and turn slowly clockwise till u hear 1 click. this will engage ur defrost cycle in about 15 minutes u should be able to come back and feel the heat in freezer as it melts the ice providing ur terminator is not bad?
Another way to test it is with a multi meter. Remove timer it from fridge and you will see 4 prongs numbered 2,1,4,3 in that order. Place ur meter prong on prong 1 & 3 (if your fridge has a capacitor wired in series with the windings, then u check for micro fares rather than OHMS) If u cannot confirm this test, still try the next.
Take ur meter prong and connect to prong 1 & 4, it should read resistance or ohms ( closed) now remove prongs and place on prong 1 & 2, this should now read infinity or open (no ohms) now take a small screwdriver place it in the tiny hole or slot under the timer. Turn it clockwise slowly till u hear 1 click. Now ur 1& 2 should read closed ( showing ohms or resistance) now place meter prongs on 1 & 4 and you it should now show open ( or no resistance - no ohms) this is how u know ur timer is good, Remember when testing for ohms ADJUST meter to use a high ohms rating in the thousands as the resistance is very high in OHMS. And adjusting to low ohms rating may give a false reading or not show the proper resistance..
THE COMPRESSOR:
If you hear a clicking sound coming from the back of your refrigerator/freezer, then the problem is most likely the compressor, relay and or capacitor is overheating or not getting proper power and will not start.The compressor is the component on your refrigerator that allows your refrigerator to cool. If this component is not working properly your refrigerator will stop cooling. Most of the time the compressor is not the component that has failed.
To check ur compressor with multi meter:
Disconnect and remove the relay and capacitor from compressor, some located next to compressor in a casing.
You wills see 3 prongs coming out of compressor. 1 goes to ur srtart winding, 1 goes to ur run winding and the center goes to ur ground.
Place ur meter connector or prong on the start prong and the other on the ground (center prong) take note of the reading in OHMS for example 5 ohms.
Next place meter prong on run prong and the center ground prong agin. Take note of the reading in OHMS. Example 4 ohms
Next place meter prong on the start prong and the other on the run prong, now take note of the reading example 9 ohms. Now match the total of this ohms test with the total of ur two separate test. 9 ohms, if they match ur ok give or take 5 percent plus or minus. One more test to make to test of there is a short in compressor attach meter prong to ground prong and rub the other end of meter prong to metal ( scrape the metal clean of paint and test on metal surface not painted surface. If it shows continuity or ohms , u have a short in ur compressor. It should show infinity
Lastly you should also check ur THERMISTORS in the freezer and fridge section for continuity OHMS and for amount of OHMS current being put out. In most models around 13000 ( give or take 150 ohms) ohms is required.
Read more:http://removeandreplace.com/2013/10/31/fix-refrigerator-freezer-wont-cool-freeze/#ixzz3WDEo5NDJ
REMEMBER GOD IS THE REASON FOR GOOD ADVICE"
Refrigerator Is Not Cooling What To Check And How To Fix
Posted on Jun 20, 2015
  • Jorge Rendon
    Jorge Rendon Jun 20, 2015
    Evaporator coils
    Condenser
    THE COMPRESSOR:
    Read more: http://removeandreplace.com/2013/10/31/f...
    Refrigerator Is Not Cooling What To Check And How To Fix Refrigerator Is Not Cooling What To Check And How To Fix
What is error code 12
Entire service manual below - see page 7-28 (chapter 7, page 28) about page 343 by normal page number methods...
Crank shaft position sensor is not getting a signal. See trouble-shooting section in chapter 8
http://www.mt01.hu/upload/mt_01_service_manual0.pdf
Aug 28, 2014 | Motorcycles
Lenovo mt 6072-bt4
hope this helps you:
http://community.skype.com/t5/Windows-desktop-client/Skype-Audio-Problems-Trouble-Shooting/td-p/73760
Aug 23, 2014 | Lenovo ThinkCentre Computers & Internet
Atv trouble shooting
poss overheating--carb needs rebuild--or need tune up
Jul 14, 2017 | ATVs
Model mt 17-54 will not cool
Go to page 10 of this PDF=> MT Merchandisers (MT Series) If you do not have Adobe Reader Click=> HERE For Customer Service at Beverage-Air=> HERE Go through pg.10 and that should give all answers you need, Good Luck, Sea Breeze
Feb 23, 2012 | Beverage-Air MT45 Beverage Cooler...
My beverage air MT 12 works but it turn on and off every 5 minutes
for cooling or heating is similar in the same basic funtion they need a thermostat for on and off cycles , don't know how it is integrated in your refrigerator but try to trouble shoot that sector first ,maybe locating the thermostat, see if the manual has spec for readings with a multimeter if not might try to research values on the net and tested first , see if it helps good luck hope you can fix it
Feb 23, 2012 | Carrier Beverage Air® Marketeer® MT12-1-B...
LG ac with heat model lwhd 1200 hry7 has power to it, cord reset, but nothing comes on, compressor or fan
Hello, Here is a trouble shooting guide for you and some details of how to fix it based on your symptoms. Here is a link to go to and make sure you jump around the site, it will tell you the fix based on your problem off the trouble shooting table. Link is below , copy and paste in browser. If this helped you, please rate it and some kind words are nice. Thanks Mike
http://home.howstuffworks.com/home-improvement/heating-and-cooling/how-to-repair-room-air-conditioners1.htm
Oct 12, 2011 | LG Heat cool Window Air Conditioner
Slow to cool. bought used only got to 45 in frig. reset on 9 and in 24 hours stay at 38 to 40. But moved to 7 and it is at 45. GE tfh22 PR. Thanks for your input.
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Sep 15, 2011 | GE (PSS26MSRSS) Side by Side Refrigerator
My car overheated the other day bc i was in stopped traffic for about 45 min to an hour i put anti freeze in it and hasent overheated since what could be the problem??
It sounds like you put your cooling system to the test.
If you have an older car, it may be that the cooling system needs to be flushed to improve the cooling. It could be worn impellers on your water pump which could make it hard to keep the coolant moving fast enough to keep things cool.
You could also have a Thermostat that stuck for a while.If your drive belt for your water pump is worn or the idler tension is low, then the water pump may not have spun efficiently. It could have also been a malfunction with your cooling fan operation....as you see cooling systems can be compex to trouble shoot.
I hope this has helped more than confused
Nov 30, 2010 | Hyundai Tiburon Cars & Trucks
Beverage-Air MT45 Beverage Cooler Commercial Logo
90 people viewed this question
Top Beverage-Air Refrigerators Experts
Dennis Boxerman
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a Beverage-Air Refrigerator Expert? Answer questions, earn points and help others
