Question about Garmin eTrex Venture HC GPS Receiver
Handheld gps just quit.
I did a map updaate on my Garmin eTrex Venture. When it had completed, I disconnected it and the GPS just shut off and will not start up. I changed the battaries without any results. I tried to to a master reset of the unit and nothing happened. HELP!!
  • 37 Answers
Go to GARMIN Website and seek help there [from their techys] asap ... ok
Posted on Nov 24, 2013
  • 6 Answers
SOURCE: GPS displays BNG on location
BNG stands for 'British National Grid'
  1. Go to the Setup menu
  2. Select Units
  3. Change the Position Format to hddd°mm.mmm'
Posted on Jun 24, 2008
marcelbakker
  • 174 Answers
SOURCE: Garmin Nuvi Firmaware Update Complete, Unable to catch satellite signal
So what happens when you connect it to the PC?
Make sure no sd cards are installed while you do this.
download and install web updater, run it it gets to a screen where it looks for the gps, plug the usb cable into the GPS (no USB hubs please!!!) Make sure it detects the GPS before you continue. Select the updates you need (don't install all the languages !!) after this is done the program will report the downloads are on the garmin, unplug the unit and it will reboot and whilst rebooting it will install the updates....so don't touch it until it reboots again and displays the regular screen....and make sure the batery is fully charged before you do this...!
Posted on Jul 23, 2008
my garmin nuvi200 keeps on searches for satellite,but it couldnt able to pick up signal. A question mark over a map is always im seeing througout
Posted on Oct 06, 2008
SOURCE: Garmin zumo 550 map update problem
  1. Make a backup of your Zumo by copying all the file to your computer.
  2. Using your PC and MapSource select all the maps then send them to a SD memory card need 2Gig or bigger card.
  3. Try to rename this file to gmapprom.img and replace the same named file in your zumo. (I haven't tried this personally, so if it fails, just replace this with your backup and all will be as it was.)
  4. If this fails, you can use the SD memory card in your zumo and it will use this map instead, but it will take longer to boot your zumo.
Posted on Apr 11, 2009
SOURCE: My Garmin StreetPilot c340 is frozen.
No.......the C340 STREET PILOT has a hidden reset button. Put your fingernail in the slot just under the GARMIN name on the front face plate. Gently pull the face plate outward. Don't take it all the way off. The reset button is on the right side of the front screen just under this plate. Use a pointed object and hold the button IN for 3 seconds and unit will turn off. When you power it back up it will REBOOT.
Posted on Jun 10, 2009
How to put in coordinates
Coordinates can be entered by marking the waypoint and editing it.
From the map screen, press the joystick down for 2 seconds to mark the waypoint. Toggle up to the coordinates and press the joystick to enter the edit mode. Make the changes to the coordinates to the new coordinates and toggle to OK, press the joystick to enter the coordinates.
Dec 10, 2011 | Garmin eTrex Venture Cx 2.1 in. Handheld...
Webupdater crashed my etrex!!! I did everything they said and it crashed. I need this fixed for my trip up north please help!!!
never use the garmin webupdater, it is unreliable. download the previous version 3.10 firmware from http://www.tramsoft.ch/gps/garmin_etrex-venture-hc-firmware-upgrades_en.html, extract to c:\garmin, plug in your gps via usb, hold the front button in the down position until update process completes, run the updater.exe program and let it complete. You will see an error message at the end of the update process, ignore and let the garmin reboot and it should work again after that.
Jul 30, 2011 | Garmin eTrex Venture HC GPS Receiver
Somehow my map got erased from my garmin etrex vista, how can I get a map back on it?
meu etrex vista hcx não reconhece nenhum cartão de memoria, ja tentei pelo menos uns 3
diferentes que funcionam em outros lugaresaguardo uma resposta obrigado
Nov 23, 2010 | Garmin eTrex Vista HCx Handheld GPS...
How do I install maps from the Garmin US Topo 100K to my Garmin Etrex Vista HCx? I've put in a microSD card, then what?
You need to install the map software on your PC. From there, using the map select tool, select the maps you want to add to your GS unit and then send them to the microSD card which will show up in the SEND window.
Mar 29, 2010 | Garmin eTrex Vista HCx Handheld GPS...
I can't put maps on my Garmin etrex legend HCx
Your MicroSD card may be full just from the basic maps. Try larger card for additional maps. The vendors supply the minimum to keep the cost low and then force the customer to upgrade the resources at their own expense.
Dec 22, 2009 | Garmin eTrex Vista HCx Handheld GPS...
Hi I have a Garmin eTrex Venture and have downloaded maps from Mapsource. When I turn on the GPS and go to the map page, no map appears on the screen.
Did you download the maps via your PC into Mapsource and then transfer them to the Venture? You have to unlock the maps on your PC with the code which is specific to your unit.
Sep 26, 2009 | Garmin eTrex Venture GPS Receiver
Black and blue
Setup > Map Setup > Marine (far right icon) > Marine Colours.
If this fixes your problem, please come back and tell us.
Sep 22, 2008 | Garmin eTrex Legend GPS Receiver
Unlocking a Garmin etrex venture cx
The unit comes with a base map. You will need to purchase City Navigator software if you want more detailed maps which will show all roads. If the box contained a copy of the City Navigator and you threw away the code, you'll have to purchase another unlock code from Garmin.
May 22, 2008 | Garmin eTrex Venture Cx GPS Receiver
Garmin etrex handheld
There's really nothing to setup, you just mark waypoints and it displays them on the map. If you press enter on any screen, it will give you options for that screen.
Jul 30, 2007 | Garmin eTrex GPS Receiver
Garmin eTrex Venture HC GPS Receiver Logo
77 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
