Question about PANDIGITAL (DPF802) Digital Picture Frame
Screen flashing - PANDIGITAL (DPF802) Digital Picture Frame
Rca hdtv dlp screen flashing
Sounds like it could be the power supply. Try changing the brightness of the screen and changing picture modes like movie or standard. If this causes the flashing to change in severity, it will most likely be the power supply board
Dec 13, 2013 | Televison & Video
Screen line flashing
What do you mean screen line flashing? Is there lines on the screen flashing or is the cursor just flashing? When is this happening?
Apr 07, 2012 | Computers & Internet
On my ds the light comes on for two seconds then a white screen appears then it goes off what should i do
Depending on which screen flashes, one of them has died. If the bottom screen flashes then the top screen needs replacing, if the top screen flashes then the bottom screen needs replacing, the easier of the 2.
Hope this helps
Jul 23, 2010 | Nintendo DS Console
Digital Camera HP Photosmart M517 Want to take a picture of my computer screen to send by email. Flash goes off every time and leaves a bright white light that obscures the screen. Can I disable the flash...
Press the flash button (just under the viewfinder) to cycle through the flash settings. Your choices are Auto Flash, Auto Flash with Red-eye Reduction, Flash On, Flash Off, and Night.
If you want to capture the screen image, you're better off using the computer operating system's screen-capture capability. This will give you the screen exactly as it is, without the distortions inherent in converting to an analog image and then converting it back to a digital image.
Mar 15, 2010 | HP Photosmart M517 Digital Camera
I changed the batteries and continued to take photos when i noticed that the screen was flashing on and off and then going to standby mode. tried resetting back to default but screen still flashes. flash...
Hi Bill,
You are not using this flash like a sub-machine gun, right?
Is your reachargeable batteries older than 15 months?
Try this:
Set to low power on flash, set flash to manual.
Remove flash from hotshoe.
Fire the flash by pushing the flash button for 3 mins, same problem(s)?
atdlee@netzero.com
Jan 17, 2010 | Nikon Speedlight SB-600 TTL Flash
I get a flash of blue screen when I power on the set.
I have the same problem.
"I get a flash of blue screen when I turn on the LT 30HV. Then the screen goes blank."
Jan 10, 2010 | Syntax LT30HV 30 in. HD-Ready LCD...
Wont Boot Power Light Flashing orange
onbord video maby might wann add pci card video see if u get screen ok thx nick
Feb 06, 2008 | Compaq Refurbished TC2120 (c23742001)...
MRM 700 won't start; screen flashes white . . . help.
stonelinton, It's not your LCD, otherwise you would have heard the sound of buttons being pushed. If your units first screen is white and there is no logo screen or any legible images, then it's your NAND flash on your main board. The first image produced upon boot is the blue magellan screen. This is produced from the NAND flash and will show it no matter if a hard drive is present or not. After the Magellan screen it pulls images from the hard drive. So, it is the mainboard and the only way to fix it is to send it to Magellan repair and they will have to put in a new mainboard then reprogram your serial number, etc.
Jun 07, 2007 | Magellan RoadMate 700 GPS Receiver
PANDIGITAL (DPF802) Digital Picture Frame Logo
42 people viewed this question
Top PANDIGITAL Photography Experts
Gareth Cockram
Gareth Cockram
Are you a PANDIGITAL Photography Expert? Answer questions, earn points and help others
