Question about Frigidaire FRS26F4C Side by Side Refrigerator
The refrigerator switched off the main switch once it plugged on
Every time I switch a refrigerator on it switch off the main switch and keeps doing it.
    Sergeant:
  • Frigidaire Expert
  • 302 Answers
The main switch has a circuit breaker built in to prevent electrocution or fire caused by faulty appliances. Have a sparkey check your fridge.
Posted on Nov 22, 2013
How do I fix a Fridgidaire Refrigerator that won't come on?
Dear Sue,
Here are two things I learned about this.
1) Underneath your refrigerator is a compressor with a "Kilx-on" mounted onto it.
The "klix-on" is a half of a two piece thing about the size of your fist, and is attached to the compressor.
The Klix-on is removable from the other piece and it is what starts the compressor when that is needed.
I just bought one for $ 38 from a local appliance parts store.
The way to test it is to tap the klix-on that is already on your refrigerator with a hammer, whilst it is plugged in, and see if it starts. If it does, you may have found the problem.
2) Sometimes the problem is with the temperature selector/on & off switch inside the refrigerator.
That switch has a set of points, and they can stick.
To try to keep that from happening, you should , once a year, turn the switch dial on and off about a dozen times, opening and closing the points.
God bless your efforts.
Feb 13, 2017 | Refrigerators
How long after i installed my side by side can i switch it on?
Daryl,
You can switch it on immediately. Its getting late. Do it now and enjoy the benefits that much earlier.
There are no pre-power-on processes. Once plugged in it is ready to be used. But do give it enough time to cool the contents.
Apr 11, 2011 | Samsung Refrigerators
Fridge light takes 2.5 sec to come on
Hi!!!
Have you cleaned the switch actuator? It is usually located on the door frame since it is activated by the door. Some times accidental spills will keep the switch from working correctly.
Good Luck
Mar 11, 2010 | Refrigerators
Lights in refrigerator stay on when doors are closed
take a putty knife and pry out the door switch from its resting place in the door,take some electrical cleaner and clean and lube it then try it again,if it still doesn't make/break connection,replace it,a lot of times they just get sticky from spills and dirt,etc
Feb 04, 2010 | LG LFX25960 Bottom Freezer French Door...
GFI switch outlet may have damaged Kenmore 55771 side-by-side?
Could be the GFI switch.
The washer has a 3-prong (grounded) plug, what about the other appliances that you tested?
The GFI may not have a good ground and the 3-prong appliance provided a "difference" that the GFI detected as a "fault".
Sep 30, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Refrigerator keeps throwing receptacle switch plate
I'm assuming this is on a GFCI outlet? May be a problem with the outlet rather than the Fridge. I had an outlet that would do the same thing when it encountered loads. I replaced it and everything was fine.
May 23, 2009 | Kenmore Refrigerators
Leviton wireless switch fails to work all the time
50 feet is the maximum range for the switch, per manufacturers spec. Range is diminished somewhat for walls, doors, etc.
IIRC, there is a plug in transceiver available from Leviton, however, if the price of the booster for the main panel is included in the $100 installation, then I'd say that's a fair price. You may try to keep fresh batteries in the switch.
Jan 15, 2009 | Leviton #601-6696-I Ivory Wireless 3WY...
Lost instructions how do i defrost my freezer cda cw186.i have a defrost button?
Hi, this is gil1714 in Scotland. how to defrost freezer cda cw186.
lost instructions? try getting the user manual online and print it.
just enter the make and model on google and choose best info. in
the meantime extract contents and wrap in blankets/duvets to keep cold. open door and push defrost button or switch unit off at mains plug. use appropriate containers and towels to catch melt water .
you may use a hairdryer or fan heater to speed this process but don't get them too close to the plastic bits. if using the defrost button it should auto-reset, if it switches back on too soon, switch off at mains. leave for half hour after defrosting, switch back on and restock. Hope this is helpful . gil
Dec 15, 2008 | Refrigerators
My Mustex MP-100
my mp100 mustek player will not switch on or charge up also it will not switch on when the mains charger is plugged in. the light on the charger went out and will not come on anymore.
Aug 12, 2007 | Mustek MP100 Portable DVD Player
Frigidaire FRS26F4C Side by Side Refrigerator Logo
42 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
