Question about Canon PIXMA MP830 All-In-One InkJet Printer
Cant get my printer to turn on
During the early morning we had a power surge and computer did shut down then restarted and was protected which I also though the printer was too but when I went to use it it would not turn on so I shut everything down and unplugged the printer (all outlets) and plugged it back in and turned on the computer etc and nothing...still no power at all to printer. Could it be damaged now because of the power going off in the night? I checked everywhere for a reset button or something. Read the manual and still no solution to get my printer to even turn on.
  • 661 Answers
Check the fuse in the plug??
Posted on Oct 09, 2007
SOURCE:
I have a Tripp Lite G1010USB uninterruptible power supply that only powers the surge surge-suppressor outlets and not the battery-backup outlets. Unless the UPS is unplugged from the wall, and then i
You know they have a TWO YEAR Warranty ?
Sounds to me that it is faulty (one of the relays or switches is not providing 'through' power to the supposed 'backup' socket when the AC power is on.).
Have you followed the manual ?
available here http://www.tripplite.com/support/model/mid/G1010USB
Have you done a 'self test' ?
'To Run a Self-Test: With your UPS plugged in and turned on, press and hold the MUTE/TEST button for two seconds. Continue holding the button until the alarm beeps several times and the UPS performs a self-test. See "Results of a Self-Test" below.
Note: You can leave connected equipment on during a self-test.' see manual
If the LCD does not give you the answer then it is faulty. Seems like something went faulty on restarting your UPS in the morning.
Seems like plenty of help available from this companys' website.
Sep 13, 2014 | Tripp Lite Ups Battery Backup G1010usb
How can I get Dynex TV out of "protection mode"?
the protected mode kicks in when there is a safety issue with the receiver. This usually comes from an overload to the system via a short in the system or perhaps a surge in power. Your receiver shuts down, and you'll need to shut the entire system down to fix it.
In some older homes, some of the wiring doesn't deliver the "cleanest" power, delivering minor power surges to the items you plug directly into the wall. If your receiver is plugged directly into the wall, purchase a surge protector to stop this
Read more: http://www.ehow.com/about_5516888_problem-sony-receiver-protected-mode.html#ixzz2ZYa9W0Mi
God bless you
Read more: http://www.ehow.com/about_5516888_problem-sony-receiver-protected-mode.html#ixzz2ZYZm8THG
Jul 20, 2013 | Dynex 32 in. LCD Flat-Panel HDTV
Computer shuts down on its own
Open Control Panel, Power Options, set to High Performance, open Change Plan settings, open Change Advanced Power settings, set Sleep and Hibernate to Never, adjust advanced settings to your preference. Always shut down your computer when not in use, it will last longer, If you don't have a UPS, will help protect against power surges.
Feb 07, 2013 | HP Pavilion P2-1013W AMD DualCore 1.65G3GB...
Power supply malfunctioning
Most surge protection power boards will protect computer equipment from mains spikes and surges.
A better and more expensive solution is to use an uninterruptible power supply (UPS). These units provide surge and spike protection and also provide power in the event of mains power failure.
Make sure you select an UPS model that meet the power requirements of all your computer equipment that is connected to the UPS with a mains down time of say 1/2 hour to give you time to shut down your computer in an orderly manner.
Sep 09, 2012 | Dell OptiPlex 780 PC Desktop
My Acer Aspire M1201 won't turn on.
More than likely your power supply got fried from a power surge during that storm anyway. You'd be surprised at how worthless most surge suppressors are these days.
Jul 25, 2012 | Computers & Internet
After power outage the printer won't power up.
The printer is dead, the surge got thru and fried it. Replace it and the surge-protector.
May 08, 2010 | Dell 922 All-In-One InkJet Printer
PC won't power up. When power switch is turned on only fan works. Also, there is no blue light on power switch. The problem started when I tried to restart my PC and in the process of shutting down power...
When you say your fan works I'm assuming this is your power supply fan and not the fan above the processor? It sounds like you experienced a power cut and obviously this has affected your pc. I take it you don't have your pc conneced to a surge protector? If you have your pc connected to this, this normally protects your computer from being fried during a power cut, the surge protector absorbs the excess power that can originate from a power cut. It sounds like you may have a problem with your motherboard as a result of this. Changing the motherboard can be very expensive so you shouldn't do that without determining that it definitely is the motherboard that has been ruined. What I would say is, get yourself a surge protector and make sure that all computer equipment is plugged into this. The other thing to use if you can afford the expense is a Smart Uninterruptable Power Supply. If you get a powercut this quickly takes over and enables you to shut down the computer properly. Sorry, not much help otherwise, good luck with your situation. Andrew
Jan 15, 2010 | Gateway GX7022E (RBGX7022E) PC Desktop
My computer get restarted very often
Perhaps the computer is overheating and shutting down to protect its components. If so, blowing out the inside of the computer and the heatsink fins on the processor could alleviate such a problem.
When a computer shuts down for such protection, it seldom damages the harddrive. If there's a sudden loss of power, a surge of power across the heads could damage the disks as the head drifts across them. Usually a disk check can repair this type of damage. But even with damaged sectors, most data would be recoverable.
May 07, 2017 | Yahoo Messenger
Hp psc 2200 printer will not turn on.
If connected to a power surge protector, turn the protector strip off / on.
Jun 10, 2009 | HP PSC 2210 All-In-One InkJet Printer
Printer Surge
I agree with first thought circuit overload.
I dont think it is the printer, I think it is your power supply in house. Just moving it to another socket does not change it from what might already be a circuit with a lot of load already.
You are experenceing surges that are normal operation ie at power on quatz lamp turns on reaching temp of 180 deg cel, then idles, if print command is issued back on comes the lamp drawing power.
Dec 01, 2007 | Brother MFC-8840D All-In-One Laser Printer
Canon PIXMA MP830 All-In-One InkJet Printer Logo
139 people viewed this question
Clive
Clive
old marine
old marine
Ekse
