Something is in the fan, behind all the shelves and some cover panels. It could be ice building up. Put all the frozen stuff in a cooler and take all the trays out and find the cover over the fan. If it is all frozen up, you may have the thermostat set too low. You will have to turn it off and defrost it if you see a lot of ice. A hair dryer will speed things up.
The fan usually stops when the door is open....
SOURCE: Troubleshooting defrost system failure on Amana Fridge
YES YOU GOT IT,IT'S THE BOARD BECAUSE EVERYTHING ELSE CHECKED OUT GOOD,BOTH FANS,HEATING ELEMENT,DEFROST THERMOSTAT,THE ONLY OTHER THING I WOULD DO IS TURN THE THERMOSTAT OFF IN THE FRIG.TO SEE IF THE COMPRESSOR AND FANS TURN OFF,WAIT 3 MINUTES AND TURN IT BACK ON, IF THAT CHECKS OUT THEN IT HAS TO BE THE DEFROST TIMER,LET ME KNOW-MIKE
SOURCE: Amana 22 side-by-side refrigerator, freezer door opens slightly
There are three possibilities to this problem:
1. Door seal which should be magnetic is faulty.
2. Ice maker caddy (container) has not socketed properly into ice maker rear drive tang.
3. Door stay closed plastic hing pieces are damaged. These are tapered pieces that fit in hinge area that allow door weight to help close and hold door. Some are black in color and some are white. As far as I know they are interchangeable.
SOURCE: freezer door wont seal and stay closed
Your pushing air from the fridge part over to the freezer door when you clos it,the only thing i can suggest is make sure that the seal (which is magnetic) is clean and not falling apart,inspect it all around the door,and when closing the door i would close it gently.
Hope this helped.Let me know by rating me or
for more help go to live chat.Thanks
Len West
SOURCE: freezer door pops open when fridge door is closed.
well u need to check the rubber of ur freezer ;s door .some damaging in the rubber is causing the problem.
Well I opened the freezer door checked the gasket, my model does not have any type of filter reset so I raised and lowered the ice maker arm closed the door and it stopped, now waiting on compressor to start up and operate.
