Question about Frigidaire FRS26F4C Side by Side Refrigerator
Refrigerator what cause refrigerator to switch off the main switch when it's plugged on?
    Prodigy:
    An expert who has answered 500 questions.
  • 512 Answers
Short ciurcute in wireing
Posted on Nov 22, 2013
The refrigerator switched off the main switch once it plugged on
The main switch has a circuit breaker built in to prevent electrocution or fire caused by faulty appliances. Have a sparkey check your fridge.
Nov 21, 2013 | Frigidaire FRS26F4C Side by Side...
My fridge c380 is working properly but after 20 minutes or so it is causing the main switch to fall,what can be the problem.
It is either electrical or mechanical problem.
If electrical the overload protector is tripping or shorting hence, the main switch will fall and if that is a circuit breaker you can reset it again.
If it is mechanical the compressor itself, the winding wire inside the compressor is already shorted causing the switch to fall.
Call a service technician for help it is not just a simple problem.
I hope I give you idea regarding your problem.
Jun 23, 2011 | Refrigerators
The led re-outs @ top right inside refer are not visible but this is on and off. When the refer door switch is touched it seems to short out the display as well as the ice dispenser lights, I think this is...
your main board in the rear area of the unit is defective and needs replacing,and also replace the ptc overload relay on the side of the units compressor too,both components just unplug and plug back in after removing and replacing the harnesses connected to them
May 21, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Lights in refrigerator stay on when doors are closed
take a putty knife and pry out the door switch from its resting place in the door,take some electrical cleaner and clean and lube it then try it again,if it still doesn't make/break connection,replace it,a lot of times they just get sticky from spills and dirt,etc
Feb 04, 2010 | LG LFX25960 Bottom Freezer French Door...
Refrigerator temperature control panel not lit. This happened last week but corrected itself....not sure how....but now display panel is off for good, it seems. Main Refrigerator lights are still working,...
Your Refrigerator Has a main controlboard located in the rear of the machine. This Controlboard sends power and reads the user information. if your user display (Temp Control panel) is not working it can only be 2 things The user display or the main controlboard.
As far a the refrigerator working without it, I would not trust it.
The clicking noise is a relay on the main control.
Usualy when I here this relay go on and off rapidly, there is a problem whith the main controlboard.
The big problem with this is why did the main control go out ? some other componet on the refrigerator could be the cause. A comon cause in the past has been the evaperator fan motor.
Jan 15, 2010 | Refrigerators
Doesnt get cold??
Okay,
Defective compressor, refrigerant low from a leak in the system, dirty condenser coils, condenser fan not working, bad compressor relay or capacitor, main thermostat control not working, thermostat needs to be set at proper setting, frozen evaporator coils do to faulty defrost timer, defrost heater coil broken, or the defrost determination thermostat has stayed in the open position, which would result in no defrost and the ice blockage would stop air the circulation, defective evaporator fan, defective door switch which controls the evaporator fan when one opens and closes the freezer door. Freezer drain clogged which would possibly cause the fan to be stuck because of ice built up around it.
Oct 13, 2009 | LG LFX25971ST Bottom Freezer French Door...
Gsl25jfpa bs fridge is warm on top and frozen on bottom and freezer is warm
It sounds like the fan in the freezer is not working , to circulate air , and the coldness is just dropping . This will cause the icemaker to stop working first , then the top portion of the refrig next . As this coldness drops , the lower portion of the fridge ( crispers ) , will freeze . The main control board , causes the fan , not to run . Part Number WR55X10656 . The main control board , is located , behind the refrig , behind an 8 " X 10 " , small panel . There is usually a burnt resistor on the board , which is connected to the fan . Unfortunantly , the whole board will need to be replaced . It is easily replaceable . Doesn't take any special knowledge . All the plugs 6 or 7 , each fit the pin plug designed for it .
Oct 03, 2009 | GE GSL25JFPBS Side by Side Refrigerator
My GE side by side Model # GSS20IEPA has frost on
Is the fan in the freezer working ? May have to press the light switch in to test . If not , main control board is probably bad . not the fan moter . Pull refrigerator out and remove the small 10"X13" metal cover . Unplug refrig first . Then remove the blue plug with 3 wires attached to it . The wire sequence on the plug looks like this : wire 1,wire 2,space wire 3.
Use an insulated jumper wire with both ends stripped and insert one end into wire 2 and the other into wire 3 . Plug refrig back in and look in freezer at the bottom . If the heater and defrost thermostat are good , the a red glow should appear . No red glow , either bimetal or heater is bad . Most likely heater pt# WR51X10101 . Do not forget to reinstall the blue plug with refrig unplugged or could cause main board dammage .
Aug 15, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Getting Error Code "er if"
I posted a similar problem with the er if code. I think I have isolated it down to the ice maker fan problem. It appears that the master unit is not getting the correct code from the ice maker fan. I managed to get rid of the problem by dumping the ice, turning the ice maker off (there is a switch next to the ice maker), and unplugging the unit for three minutes and plugging it back in. However, I am without an ice maker. But the problem has not returned and the rest of the unit seems to work normally.
Hope this helps.
Nov 01, 2007 | Kenmore 73502 / 73504 / 73509 Bottom...
Interior Light
try and reset the door switch by pushing it down once or twice and confirm
Aug 30, 2007 | LG LRFD21855 Stainless Steel French Door...
Frigidaire FRS26F4C Side by Side Refrigerator Logo
37 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
