Question about Xerox DocuColor 242-252-260 PS
Docucolor 252 color toner dropping on back of sheets
When printing in color on back of sheets toward bottom of print leaves various CMY toner in same spots not in the file, looks like brushed lines about 1/2" or so area, always in same spot. Doesn't do it printing grayscale
  • 2072 Answers
SOURCE: Xerox 7700 intermittant banding on a diagonal black only
You most likely have a bad black developer housing.
You can try removing the waste bottle and using that bla\ck stick inside the cover to clean the laser ****.
But it sounds like the developer housing has failed.
Posted on Sep 08, 2008
  • 62 Answers
SOURCE: Xerox Docucolor 12 : Four colors ( CMYK) dots printed each time on paper on 3 separate area
print cartridge is past its best. If you get a new one and the same thing happens, its the developers that need changing
Posted on Nov 19, 2008
  • 2072 Answers
SOURCE: Xerox Phaser 7400DX - leaves "smudges on the printed sheet
It sounds like you have a developer housing failure.
Posted on Mar 29, 2009
  • 49 Answers
SOURCE: Color Printer Xerox Phaser 6180 Black Background Print out
Try the link below. If the toner is leaking from the cartridge return it to shop were you got it if it is damaged.
http://www.support.xerox.com/SRVS/CGI-BIN/WEBCGI.EXE/,/?St=466,E=0000000001344030351,K=1906,Sxi=11,Case=obj(1307)
Niallbt
Posted on Mar 30, 2009
  • 49 Answers
SOURCE: Just changed the black toner and now it won't print black.
Sometimes it may not be the toner that is the issue in this case the problem is with the black imaging unit, remove it and check for any damage and check the how life is left on it, if you have a spare then replace it!
http://www.support.xerox.com/SRVS/CGI-BIN/WEBCGI.EXE/,/?St=49,E=0000000001347412543,K=9952,Sxi=0,Case=obj(4002)
copy and paste this directly into your address field!
Posted on Mar 31, 2009
Ink is smudged on envelope. How do I stop that from happening?
i bet you're printing in Black,
what happens is when black is selected, the 3 colored drums lift up 2 mm annd only the K drum is engaged, amd there is no static in the transfer belt under the CMY drums.
envelopes have air in them and can bounce along the bely after the black has printed, and seeing the toner is powder and not yet fused on, the toner touches the cyan drum as the envelope hits the fuser entry point as well as dragging on the Left transfer belt Blue lift handle(take out the belt and spring the handle off).
If you open the lid in this print mode, and lift out the cyan drum, turn it over and pull back the cover for the OPC drum, you will see the black toner on the green drum.
FIX 1. In the art work place a tiny dot of yellow. this will run the print mode in color and enagage all the drums. gaurantee your print will be fine, and know one ever sees that yellow dot.Problem is, this then runs down your CMY drums for black only printing.
FIX2.
If you have a later machine, downlaod iQueue from Xante.com (free) fantastic software. and get the machine updated with the latest X1.11 firmware from your dealer.
This allows with iQueue, to set the machine to print Black only, and you run the machine without the CMY drums installed....it works, it's great...
Aug 10, 2010 | Xante Ilumina Digital Color Press Printer
XEROX Docucolor 12 Color Developer PN needed HELP
DEVELOPERS:black 5R616 ; yellow 5R 619 ;magenta 5R 618;cyan 5R617
TONER : magenta 6R1051 ; cyan 6R1050 ;yellow 6R1052
Sep 14, 2009 | Xerox DocuColor 12 Color Copier
Prints aren't plain, it have some texture like crayon
its problem of toner
its of good quality
and also check proper supply of toner into develper assembly
trying to add some extra ink directly in developer assembly
if problem solve
check
cartridge motor running
and supplying toner proeprly
May 24, 2009 | Xerox DocuColor 12 Color Copier
Docucolor 12 no print color & B/W
the only thing apart from software corruption is that you could try printing a configuration sheet. If this prints then black printing is working. If it won't then print a test page then you need composite patch 1-7QU5B.ps from the xerox "drivers and downloads" site. If none of this works it is a software reload.
Jan 16, 2009 | Xerox DocuColor 12 Color Copier
Printing Problem With My HP cp1700D Color InkJet Printer
First clean the cartridge and then go to toolbox and give test print.
Feb 17, 2008 | HP cp1700 Color Inkjet Printer
No Magenta Color Printing, Xerox Docucolor 1632
Are the properties set correctly in the print driver.
You can turn certain colors up or down.
Does is copy magenta?
If so I would suspect the driver or the settings within the driver.
If it does not copy magenta, then I suspect a developer housing issue.
Printing only then suspect a driver issue.
Oct 22, 2007 | Xerox DocuColor 1632 Laser Printer
Docucolor 12 error code HELP
9-357.
Black toner problem.Probably You have low toner sensor defect.
But try first to vacuum and clean black toner dispenser.You must vacuum whole path wich is used to transport black toner to developer unit.Then if printing B/W print only, you must print 10 full color sheets every 100 copies.
Sep 13, 2007 | Xerox DocuColor 12 Color Copier
System Fault
9-357.
Jan 29, 2007 | Xerox DocuColor 12 Printer
Open Questions:
See all Xerox DocuColor 242-252-260 PS Questions
Computers & Internet Logo
35 people viewed this question
Top Xerox Computers & Internet Experts
Jack McCann
Jack McCann
Outback Jack
Outback Jack
Steven's...
Steven's...
Are you a Xerox Computer and Internet Expert? Answer questions, earn points and help others
