Question about Panasonic NIR71NR Iron
Doesn't turn on when plugged in - Panasonic NIR71NR Iron
No steam is coming out i think it needs cleaning
Some irons like Rowenta have a self cleaning feature. If yours doesn't make a solution of 1/2 vinegar and 1/2 water and put it in your iron. Plug it in and allow it to heat that up. keep working your instant steam button for a while. Hopefully the vinegar will help remove the calcium build up and let it work.
Nov 11, 2012 | Irons
My Remington Keratin Therapy Flat Iron Doesn't Turn On.
see thi steps and fix it.God bless you
If the iron doesn't heat, make sure 1) power is on to the outlet, 2) check the electrical cord and 3) check the thermostat and replace if necessary. Use the VOM.
Oct 15, 2012 | Remington Style Therapy: Keratin Therapy...
Wont turn on
see this steps and fix it. God bless you
As with many small appliances, regular maintenance makes a dramatic difference in how trouble free your electric iron will be. Even so, things can happen.
If the iron doesn't heat, make sure power is on to the outlet, check the electrical cord, and check the thermostat (see the Appliance Controls Fix-It Guide) and replace if necessary.
Oct 01, 2012 | Irons
Rival IR600 Iron Does not turn on, not heating or lights on ?
see this causes, and use the common sense.God bless you
Sep 19, 2012 | Rival IR600 Iron
Does not turn on
please see the causes and use the common sense. God bless you
Plug gets very hot and sometimes the iron doesn't work
your plug needs replacement. you have to put high wattage plug ,because iron has 1000watts or 4 amphere load.
Aug 15, 2011 | Rowenta Professional Luxe DM880 Iron
I have a B&D 2030 steam iron which I really like, but recently it isn't always turning on when plugged in. I think there may be a short in the cord somewhere, possibly the plug?? It seems to work...
Likely the wire inside the cord is broken from lots of use. You can usually tell where by turning the iron on while plugged in and bending the cord. You will hear a spark when you bend the spot with the break. It isn't very difficult to replace the cord with a new one.
May 31, 2011 | Black & Decker D2030 Iron
Iron will not heat up when plugged into outlet
My wife has used these since they were made by Sunbeam. The majority of the times they failed it was the cord broken inside the black insulation right behind the plug. If you can get access to a continuity tester or an ohm meter (part of all multimeters) just set the meter on ohms or continuity, connect the red lead to one prong on the plug and the black lead to the other prong. If the meter doesn't read any resistance, hold the plug still and move the wire around behind it. If that results in intermittent continuity readings there is where the break is. If there is a reading on the first try, move the temperature selector to the OFF position and the reading should disappear. As you move across the range of temperatures, the resistance reading should climb. If it does not, the thermostat is bad.
Nov 14, 2010 | Black & Decker Classic Metal APP F63D Iron
Panasonic NIR71NR Iron Logo
Top Panasonic Irons Experts
Bill Boyd
Rani wadia
Rani wadia
iranna
iranna
Are you a Panasonic Iron Expert? Answer questions, earn points and help others
