Question about Music
Yamaha dd55 pad not working
A pad on my Yamaha dd55 drum set is not working or not sound ing the proper sound programmed to it. I have had this problem before, but I am sick of sending it to Yamaha to fix.Does any one know how difficult it is to repair? Last time I had this problem, the other pads eventually died too. Thanks for any help
SOURCE: DTXpress III Special Yamaha Drum Kit - high hat won't sound closed
solution!! you go to "voice" hit the hihat pedal, then press "page" till you get to hhat ofset and bring the value to negative. approx -25. pressure that you applied to hhat pedal becomes less
Posted on Nov 13, 2008
petraman7
  • 1175 Answers
SOURCE: Yamaha clavinova won't play C natural in any octave
Hi ...
There are flexible cables that connect the keys to the main electronics. The connectors for those cables sometimes age poorly..
It is fixable. But dont "get taken" on a repair.
If it's just resoldering a few points,it shouldnt be more than $100.00
to fix
Posted on Jan 12, 2009
  • 17 Answers
SOURCE: i want to connect my YAMAHA DTXPRESS IV SPECIAL to my PC
Any pro-audio interface with a midi input would do the trick. There are numerous products out there that offer this. You can get a simple usb midi interface, and connect the Yamaha up with a midi cable running from the midi out of the drum module to the nidi in of the interface.
one of the simpler ones:...
http://www.amazon.com/M-Audio-Midisport-Uno-MIDI-Interface/dp/B00007JRBM
Posted on Mar 04, 2009
  • 1126 Answers
SOURCE: CHANGE THE SENSITIVITY OF DRUM PADS ON (YAMAHA DTXPRESS IV SPECI)
http://www.yamaha.co.jp/manual/english/result.php?div_code=emi
This should link to owners manual..Hope this helps.
Posted on Aug 25, 2009
SOURCE: Low Volume using Kaoss Pad Mini while DJing
I'm having the problem too...I'm thinking that maybe getting the DC adapter MAY fix it though as stated in the Manual: "...The output level of the mini-KP will be smaller than its input level. This is because the attenuator circuit is connected at the input section, considering that the mini-KP is used on battery power." so maybe the dc connector will increase output volume?
Posted on Jan 30, 2010
My Yamaha DD55 set has started making weird crackling noises every time I hit one of the pads. Was fine until I started playing them this morning, sounds quite static when contact is made with pads.
It could be either the internal pickup is coming unglued or the electrical connections need to be re-soldered. If you're not familiar with the process, have it done by a repair shop. You risk causing more damage if you're not careful.
Jul 07, 2015 | Yamaha Music
Yamaha dd55c hi hat foot pedal not working
This could be caused by a number of things.
1) Socket on DD55 could be broken
2) Cable could be broken
3) Plug at end of cable could be broken
4) Switch in foot unit could be broken
Eliminate each by working through 1 - 4 using a multimeter and then repair accordingly once you have found the fault.
Jun 30, 2014 | Yamaha DD55C 7-Pad General MIDI Digital...
Setting up in logic studio
I assume you are using a Mac or similar Apple product. you may need to go the chooser to select the DD55 if the system does not recognize it automatically. If it does not appear as a choice you need to install/reinstall the driver.
Apr 06, 2012 | Yamaha DD55 7 Pad General MIDI Digital...
I get random unwanted midi notes triggering while I plug my dd-55 into my emu x-midi 2x2 with my Reaper DAW. I don't know if this is a problem with the emu or the dd-55 itself, but it doesn't...
Check that you don't have MIDI echo on in the DAW. If the MIDI data is echoed, it MAY be merging with the outgoing and when MIDI signals are merged in pieces instead of whole messages the data is corrupted. If you can look at the data stream with software, you should be able to spot the problem. Another problem might be excessive latency of the recording software. Make sure you do not have antivirus or antispyware programs running or network running. The Roland will spill data at much less rate and while the dd55 may overrun the DAW the Roland might not be able to. The key to the problem is to analyze the MIDI data stream that is being recorded.
Sep 05, 2011 | Yamaha DD55 7 Pad General MIDI Digital...
My dd55 work well if i play gently and simple. But if i play something more complicated, then, after a few seconds, it restart power. It look as there some problem with polifone tones and power. Adapter,...
Whatever is the problem is probably vibration sensitive. The adpater connections are notorious and you would have to use test equipment to verify they are OK. Looking at them you cannot verify they are OK. Try to see if the display blinks right before it stops. If it isn't the connections, then it is possible one of the buttons is marginal and is vibrating down and restarting. Instead of complicated stuff, just do everything on one pad at a time to see if you can create the problem. Try different pads as the vibration may need to be neaar a particular point. Myself I would open the unit and inspect for loose wires etc.
Jul 09, 2011 | Yamaha DD55 7 Pad General MIDI Digital...
Two of the pads on my Yamaha DD55c drum machine do not seem to be triggering properly. For example, if I hit the snare pad it seems to always be triggering at a low velocity, but if I strike it flat with...
A weak snare is a characteristic of these... The triggers are typically piezo discs that were often used in musical cards but those have now gone to using very flat little speakers... You may find some have been dislodged or broken loose... worth a look inside.
Apr 11, 2011 | Yamaha DD55 7 Pad General MIDI Digital...
I have an electric triggered bass drum pad, and it will not trigger the sound through the machine unless I practically slam the pad the model is a KP65 bass drum pad, on a yahmaha DTXpressIV
Test the pad driving a different sound... If the pad is weak, the sensor probably came loose in it... They are a piezo disc usually like in older musical cards.
Some of the triggers have an adjustment pot that is very tender... ALSO there usually is a setting in the machine for sensitivity.
If this has just gone bad, it is likely the sensor came loose... repairable if one opens the pad...
May 24, 2010 | Yamaha Dtxpress Iv Special Electronic Drum...
Sampling into yamaha dtxpress iv
If you have a sampler, you could midi out of the DTX brain into the midi in of the sampler to trigger the sounds. If not ,try downloading KORE2 from Native Instruments onto your computer and triggering it using the above mentioned method . Midi out from your brain to Midi in on your computer. Hope this helps.
Jan 13, 2010 | Yamaha Dtxpress Iv Special Electronic Drum...
Sep 19, 2008 | Yamaha Dtxpress Iv Special Electronic Drum...
Music Logo
57 people viewed this question
Top Music Experts
Michial Gueffroy
Vito Vacirca Jr.
Are you a Music Expert? Answer questions, earn points and help others
