Question about Myron & Davis AD-212 Car DVD Player
It saying that I have no signal
When trying to watch a DVD it telling me that video 1 has no signal
I can watch regular channels. But when I try to watch a dvd or vhs tape it says not connected.And when I switch the input to video 1 it still wont work ?
Your tuner is working but, unfortunately, your input circuits on set are fubar. Cheapest way to resolve issue is to get an rf modulator, connect to external source, and feed that rf signal to channel 3 or 4 of your tuner.
Sep 28, 2016 | Televison & Video
Why has my Alba TV Screen say no Sygnal
how is youre cable connected to the 1-tv 2-cd/dvd player 3-amplifier, coming from satelitte..If you watch a dvd, somtimes you half to push the tv.video button on the dvd remote control just once to allow the tv cable signal to pass to the tv. each time you watch a dvd it blocks the tv signal. this is normally true unless you have a special wiring configuration
Aug 30, 2014 | Albatron Computers & Internet
No signal fromdvd player video 1 (av)
yellow is video and red and white are audio you a get by with one audio. i think you are missing your video cable you can get by with two cables just use the white cable as a yellow and plug it into the yellow dvd plug and tv yellow plug and the red will stay hooked up for sound ( you wont have stereo but it should work)
Aug 05, 2012 | Audio Players & Recorders
No video signal comes on screen when watching movies and playing games in video 1 signal
Look for any loose contacts in RC jacks/sockets/Cable. Try changing the input device to something you are sure, works such as a DVD player.
Aug 04, 2012 | Toshiba Televison & Video
No signal on TV when we go to watch a movie on the DVD player
You may have to select a different input on the tv. iIs there an "input" put on the tv remote? If not, try channel down.
Apr 30, 2009 | Sanyo DS31520 31" TV
Connect tv vcr and dvd player to digital converter box
Yes you can first connect the converter box to the antenna first. Next hook the tv out on converter box to vcr in on vcr. Next hook the vcr out to the tv in and watch vcr and converter box on channel 3 sometimes channel 4.on the actual tv and of course change channels with converter box remote. For dvd player hook it straight to tv with red,white,and yellow cables that come with your dvd player. Then to watch dvd player if it's hooked up that way you have to put your tv on a input like video 1 or input 1. This can be done by using the tv remote and looking for a button that says tv/video or input or source button. This is some common names for that button on tv remotes.
Nov 02, 2008 | Insignia Digital-to-Analog Converter for...
Input problem
If you have the original remote, hit video, source, or input button, if it dont have them, then try to change the tv to channel 00 (zero or zerozero), if not then the channels might have to scroll to it, from channel 02 down to make it loop, if it goes to the next highest channel, then you need a remote. It may be set in the menu options to have the video source not saved to your list of saved channels. when you scan the channels, the tv might not look for the A/V source (audio / video), maybe just the RF source. The 3 DVD RCA wires are 1 video and 2 stereo, one stereo for left and one stereo for right. The TV has only 2 , 1 for video and 1 for mono 1 channel sound. This wouldnt have anything to do with why you cant use the DVD player. but try that with the original remote (or a universal remote that is set to your tv set that has either video, input, source or something similar. It is what tells the tv to change from the cable source (RF) and the AV source (the Red White and Yellow plugs, in your TV's case, 2 plugs, one yellow and the other either red or white or something). Dont really know how to explain it much more but hope it helps.
Jan 05, 2008 | Sanyo DS24205 24" TV
Video
Bad video cable is first thing to check. The output is composite or progressive? need more info on your configuration to solve. It almost sounds like the IC for the video is heating-up.
Jan 01, 2008 | Memorex MVD4543A
Unusable signal
Substitute video jumper cable....
Re-check video out hook-up on back of DVD......
Sub out DVD with different DVD / VCR for test......................T.
Sep 01, 2007 | GE 31GT660 TV
Multiple video inputs
Unfortunately, you cannot use the connectors at the same time. The S-Video connector overrides the standard video connector. This is why they share common audio left/right inputs. If you could use them separately, they would each have their own set of audio inputs. (S-Video does not carry audio signals on the cable.) I'm assuming that you are connecting your Satellite as an input to your VCR, and then your VCR to the TV via a video connection. The VCR passes the satellite signal through unless you are watching a tape, then it overrides the dish signal. You have a few choices here: 1. You can connect the coaxial (RF) output from the VCR to the TV, and watch the satellite and VCR on channel 3 (or 4). You can then connect the DVD via S-Video, and watch it on "video". This is the simplest solution, and provides the best picture quality for the DVD (with this TV), but lower quality for the dish and VCR. 2. You can connect the DVD player via RF (if it supports that), watch the DVD on channel 3, and connect the VCR via video. This will make the DVD picture quality terrible. 3. You can replace the VCR with a combo DVD/VCR unit. You can then connect the S-Video out from the combo unit to the TV. This is a more expensive solution. 4. You can replace the TV with a model that includes more inputs. This is the most expensive solution, but will allow you to watch your DVD over component cables (very high quality) and VCR and dish over S-Video. Ironically, the obvious choice, connecting the DVD as an input to the VCR (as a pass-through) simply WON'T WORK. The signal put out by the DVD player is "copy protected" (using a system called MacroVision) which the VCR will refuse to play, even as a pass-though. Best of luck with this. Given that you are trying to make this all work without replacing equipment, I recommend option #1, until you decide to break down and buy a shiny new HDTV. They are coming down in price every week, but only you can decide when the time is right.
Mar 22, 2007 | Sony KV-32S26 32" TV
Myron & Davis AD-212 Car DVD Player Logo
20 people viewed this question
Top Myron & Davis Car Audio & Video Experts
xxxxxx xxx
Tom Chichester
Joe Ball
Joe Ball
Are you a Myron & Davis Car Audio and Video Expert? Answer questions, earn points and help others
