Minolta cspro Ep6001 error codes - Office Equipment & Supplies
SOURCE: ep2080 minolta cspro
Ep2080 minolta cspro error code comes up with c0500
Posted on Jun 17, 2008
Cogz
  • 1326 Answers
SOURCE: minolta ep5000 cspro
What you need to do is to take the new toner out bottle out and close the front door and let the copier come to ready again and then try to reinstall the toner bottle again and run the copier... Basicly, the toner bottle was put in wrong and you have to let the hopper go back to home postion and then reistall the toner bottle
Posted on Dec 05, 2008
Cogz
  • 1326 Answers
SOURCE: error code C0070
This could be a easy fix for you. Did you just add a new toner? If so, try this..... Remove the new toner bottle CAREFULLY, mahe sure the hole in the bottle is in the upward position. Once you have removed the bottle, Close the front door and turn the copier OFF then back On. Let the copier come to ready and reinstall the toner agian as it is displayed on the front cover or box. Then close the front door and try to make a copy. It should work for you... If not you most likely have a problem with the toner motor or the home position sensor for the toner bottle. You may have to call a service rep. to handle that problem. Good Luck...
Posted on Jan 24, 2009
Cogz
  • 1326 Answers
SOURCE: Minolta CSPro 3000 Copier/how to enter service mode
Press Stop - 0 - 0 - 1 or it maybe User Funciation then meter count - Stop - 0 - 0 -1 , it's been years since I worked on them
Posted on Feb 07, 2009
  • 15 Answers
SOURCE: Error Code C04
Let the copier on then press S1 (reset switch ) on Board-A.
Posted on Apr 09, 2009
I have a MINOLTA CSPRO EP6001 and the paper is jaming in the fuser area need help fast!
Replace the upper/lower fuser roller? Check the pick fingers on both rollers any of the broken? By pass front door is the fuser rollers moving ?
Apr 22, 2016 | Minolta Office Equipment & Supplies
I have a MINOLTA CSPRO EP6001 And its jamming and giving the eror C004E
remove all covers! Check fan units one is not turning. clean all filters and fans if one is not turning try this site for parts as a start
Precision Roller Printer Toner Cartridges Parts and Supplies Office...
I have a Minolta CSPro 3050.. legal paper drawer won't close..and it won't copy
To the rear cover located one hole before waste toner box.Introduction one long screwdriver and push the unlock button.
Jan 18, 2013 | Konica Minolta Copier Toner EP6001 CS Pro...
Error Code C000
Minolta cs pro ep6001
error code - C 000
Sep 02, 2012 | Konica Minolta Copier Toner EP6001 CS Pro...
What's your problem?Minolta EP3050 CSPRO Copier printed copies, then display read ''malfunction detected'' code C0070
Main hopper toner replenishing motor M8 failure to turn.The output from toner bottle home position sensor does not go high within 5 seconds after M8 motor has been energized.Verify the conectors,sensor and motor.Open the front door,turn the toner bottle 1/4 turn clockwise manually with the bottle holder closed.Under the above condition does the toner bottle turn when the front door inter lock switch is turned on?NO - change the toner replenishing M8 motor.Does the toner bottle stop at home position after turning?NO- change PC35 toner bottle home position sensor.Recomanded use vacuum cleaner.
Aug 14, 2012 | Konica Minolta Copier Toner EP6001 CS Pro...
Have a Minolta CSPro 3050 with error code C004A. What does it mean
There is a fan located under the big glass section remove the glass an check the fan clean it or replace it.
Feb 01, 2012 | Minolta Office Equipment & Supplies
Minolta cspro 2010 error code c05
pLEASE DESCRIBE YOUR PROBLEM CORRECTLY.tHE 05 CODE REFER TO FUSING UNIT.Check or change the fuser unit components,clean the thermofuse and thermistors.
May 12, 2010 | Minolta EP4000/5000 CS/PRO Copier
MINOLTA EP2010 CSPRO ERROR CODE C04, WHAT DOES IT
MINOLTA EP2010
C0400Exposure lamp does not turn on or AE sensor problem
1 Check the sanity of the lamp of the scan, contacts of the lamp
2 Contacts of the sensor to automatic exposure, he near by lens, do cleaning optometrists.
Oct 10, 2009 | Office Equipment & Supplies
Feb 06, 2009 | Minolta Di3010 Copier
Dec 06, 2007 | Minolta EP4000/5000 CS/PRO Copier
23 people viewed this question
jasbo
jasbo
