Question about LG Computers & Internet
Printer spooler service not running - LG Computers & Internet
    Problem Solver:
  • 17 Answers
Is this an error message or a statement? If you need to start the spooler service, you can either open command window and type:
"net start spooler" without the quotation marks and press ENTER or click START button, right-click on Computer and select Manage. Then on the left, expand "Services and Applications" and click on "Services". Afterward, scroll down till you locate Print Spooler and its Startup Type should be "Automatic" and Status should be "Started" but due to the error, I am guessing the status is "Stopped". If the Startup Type is indeed set to "Automatic" then rebooting the computer should start this service automatically as listed, if you keep getting the same error message then there is something either preventing this service from starting or it is stopping it when you try to use it. Not very common but faulty or corrupt printer drivers could cause that so that would be the first thing to check unless you have other errors or issues on this computer that might indicate a filesystem corruption, bad Windows image or malware infection.
Need more info. I am sorry but this is a good example of "How not to ask for help". Better description of the issue, better the help you will receive.
Posted on Nov 21, 2013
Operation could not br completed. The print spooler service is not running
Hi There,
If your print spooler service is not running, then follow the below steps to get it working :
Step 1 :
* Start > run > services.msc > ok
* Select the service name called print spooler from the list.
* Check the status on the print spooler service, if it is stopped, then right click and select start or restart.
* Then the spooler service will start working....
Step 2 : ( NOTE :USE THIS STEP ONLY WHEN YOUR STEP 1 DOESN'T WORK )
In this case, we assume that the print spooler service is gone bad and we would have to recreate the spooler service.
* Start > run > cmd > ok
* Type: sc delete spoolsv (this will delete the corrupted spooler for us to create a new print spooler)
* Reboot the system and after rebooting the computer back.
* Type: sc create spoolsv (this will create a new print spooler service)
* Reboot the system and this time the print spooler service is a new and fresh spooler and it should work normal and perfectly.
Enjoy printing !!
Oct 22, 2010 | Office Equipment & Supplies
Microsoft said spooler subsystem app not working
1) Click the Star>Run, type in "Services.msc" in the Run dialog box.
2) A services window popup, find the service name "Print Spooler", double it and change the Service Status to "Start".
Now u can use your printer with your spooler services enable now.
YBC (/\)
Nov 12, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
Printer is not working.
Hi Surenderpdsi
It sounds as if the printer spooler needs re-starting.
This is the path to the printer spooler service,
Windows XP Path (category view)
Start – Control Panel – Performance and maintenance – Administrative tools – Services.
Windows Vista Path (category view)
Start – Control Panel – System and Maintenance – Administrative tool – Services.
Once in Services both XP and Vista are the same.
Look down the list till you find Printer Spooler.
Once found, right click your mouse on Print Spooler and select Properties.
In the properties box that open the service status should read “Started” if not click on start.
If it says the spooler is started click stop, wait till the spooler has stopped then click start.
This will re-start the spooler and should fix your problem.
Hope this helps,
MK Support.
Mar 15, 2009 | HP DeskJet 3745 Printer
Trying to install the HP Deskjet F2210 printer onto my Dell with windows XP everything loads except the printer spool. What do I do?
Restart the Print Spooler:
start-> run-> type services.msc-> scroll down to the print spooler service n hit start.
Verify that that the Print Spooler service, and all the services that it depends on, are correctly installed and running.
  • Open the Services Management Console (click Start, Run and enter services.msc).
  • Double-click the Print Spooler service to open its Properties window.
  • On the General tab, check that Startup type is Automatic.
  • Select the Dependencies tab.
  • Note all of the dependent services listed, then close the Print Spooler Properties window.
  • Repeat the above steps for the dependent services noted.
If any of the dependent services are missing or cannot be started, try uninstalling all installed printer drivers and then reinstalling them.
If this method cannot be completed or does not resolve the problem, try Method 2.
Method 2
Remove all Print Spooler service dependencies other than the Remote Procedure Call service.
  • Click Start, Run and enter sc config spooler depend= RPCSS (there must be a space after "=" but not before it.)
By removing the other dependencies the Print Spooler service should be able to run, but the printer functionality may be affected, and it may be necessary to reinstall the printer drivers.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Jan 11, 2009 | HP PSC 2210 All-In-One InkJet Printer
Printer Spooler service!
Click on "Start, Run", type "services.msc"
On the right side of the services window, scroll down to "Print Spooler". Double-click it.
If startup type is "disabled", click the drop-down and set to "Automatic" and then click "Start". If already on automatic, click "Stop" to stop the service. Once stopped, click "Start" to restart the service.
Reboot and try again :)
Hope this helps - remember to rate!
Oct 01, 2008 | HP DeskJet 5550 InkJet Printer
Now u can use your printer now.
YBC (/\)
Aug 04, 2008 | HP LaserJet 1018 Printer
hi,buddy
you have to start printer spooler by this.
click "start btn"
click on "run"
write here "services.msc"
double click on "print spooler"
select status type "automatic"
than click on "start"
now install your printer.
Jul 27, 2008 | Lexmark Z645 InkJet Photo Printer
Spooler not running after Lexmark x83 installation on windows XP laptop
From what you're saying the windows print spooler service is not starting following the installation of your printer (and thereby you cannot print i'm assuming)
try the following to start the print spooler service if it is not already running.
Click Start
Right Click My Computer
Click Manage
Click "Services and Applications"
Click Services
Scroll down to "Print Spooler" and double click on it to open up the properties page
where it says "startup type" select automatic from the combo box list
Apply
If the service is NOT running, start it by clicking "start"
click OK
The print spooler service is started now, and **should** work properly. If the spooler is still not starting properly, then you may have a driver issue and i reccommend uninstalling and reinstalling the drivers for your printer.
Jul 01, 2008 | Lexmark X4270 All-In-One InkJet Printer
click on start ..RUN.....type cmd......type sc config spooler depend= RPCSS......click on start ..RUN......type services.msc.......look for ptrint spooler......it will be started if not then double click on print spooler and click on start.
Now try installing the printer.
May 31, 2008 | Lexmark X4270 All-In-One InkJet Printer
Computers & Internet Logo
Top LG Computers & Internet Experts
Michael Vincent Cruz
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
