Question about Parks Optical 2500 Gallon Intex Quick Set Pool Water Replacement Filter Pump only
Ineed owners manual for sta rite p2ra5e-142l pool pump. Must include a parts diagram and instructions for repalcing motor shaft seals.
How to wire motor sta rite p2ra5e 181L
The green wire is the ground and bolts onto the motor frame on the top part,(should see a green screw). the other two wires go to the two posts with screws to clamp down on the wires. It does not matter which way these two are hooked up, one on each post.
Most motors are pre-wired for 220v from the factory. If you have 220v you're good to go. If you happen to have a 115v setup the motor will run at half speed. The motor can be converted to 115v by moving a brown wire and a white wire in the motor. The diagram is on the motor label.Best to verify your voltage first.
Mar 21, 2013 | Sta Rite Sta - Rite 1hp Dura - Glas...
I lost the gasket that seals the 2 halfs of a duraglas P2RA5E. Would you have a part number
this is the best pump going ! I hear a guy is going to list one on ebay for $5.00 shipped, MONDAY the part # should be STA-101-3745G retails for about 15.00..
remember to prime that pump !!!
Jay.. the pool pump repair guy in longwood Floida 32750
Nov 20, 2010 | Sta Rite StaRite DuraGlas Pump 34 HP...
Pump is leekin water
there are a couple of places where the pump may leak. The discharge fitting, the seal plate o-ring, or the shaft seal. If the shaft seal is leaking, water will be dripping from the bottom of the pump where the motor mates to the seal plate.
Sep 16, 2010 | Sta Rite 1 HP Sta-Rite Pump: 1.5" in/out,...
How do you replace a seal on a Sta-Rite pool pump? How do you remove the old seal? Ceramic and graphite.
Replacing a shaft seal requires some good mechanical ability.
first, always make sure power is off at the breaker before you work.
You'll have to remove the band holding the wet end to the seal plate. Then remove the diffuser covering the impeller. Remove the cover on the back of the motor. You either need a 7/16 open end wrench or a armature tool to hold the motor shaft while you unthread the impeller (if the impeller has a screw in the middle, you will have to remove it by turning clockwise, left hand threads) counterclockwise. You can then pull the carbon part of the seal off of the impeller, make sure to remove all of it including the metal sleeve. You will then have to remove the seal plate and push the ceramic part out from the back. You can then clean and lube the seal plate and install the new ceramic part of the seal, try not to touch the ceramic with your hands if possible. You can then lightly lube the impeller shaft and slide the carbon part of the seal with the carbon facing toward the ceramic as you thread it on. If the seal plate had a copper heat sink, you can either replace it or use a different size seal. (I believe it's a PS-201) Re-install the seal plate, impeller (and screw if applicable) and diffuser. You should now be ready to mate the seal plate to the wet end. Make sure you fill the pump before you try starting it up, especially with a new (dry) seal.
Aug 14, 2010 | Sta Rite 1 HP Sta-Rite Pump: 1.5" in/out,...
My motor on my Hayward pool pump is making a loud squelling noise like theres a leaf or rubber seal or something not set right,is there any way to oil the motor or maintnance the problem(the motor is 10...
NO ! YOU WILL HAVE TO GET IT SERVICED NEW BEARINGS AND SHAFT SEAL , ABOUT 75.00.. SEARCH YOUR AREA FOR YOUR LOCAL POOL PUMP MOTOR REPAIR GUY.. THIS A GREAT PUMP ! REMEMBER TO VOTE FOR YOUR FAVORITE FIXIT GUY ! THANKS JAY
Jun 07, 2010 | Sta Rite 1 HP Sta-Rite Pump: 1.5" in/out,...
I had to replace my pump motor and can't get my pump to quit leaking at the joint. I am trying RTV Sealer as we speak.
Did you change the seals? Whenever pump motors are replaced, the ceramic shaft (mechanical) seal should be replaced. Its also a good idea to replace the seal plate and diffuser seals.
May 29, 2010 | Sta Rite Sta - Rite Dyna - Glas Pool Pump...
Disassembling the pool pump to change the seals
Try consulting the owners manual for these pool pumps. You can find one online. That should give you a diagram with detailed and numbered parts to help you figure out where your seals are and how to get to them.
May 19, 2010 | Sta Rite 1 Hp Above Ground Pump Ne641
Sta-rite problem
Pump is heating up and kicking the breaker try cleaning the pump filter and let me know by posting to this solution.
Sep 29, 2009 | Sta Rite Sta - Rite 1hp Dura - Glas...
Tring to take the pump face off the motor
You have to remove the back cover from the motor. Next loosen the capacitor. Put a 7/16" wrench on the shaft and the pump impeller will screw off by hand.
May 28, 2009 | Sta Rite 1 Hp Sta - Rite Abg Swimming Pool...
Removing a staRite pump
a picture on how 2 remove sta rite , remember to prime the pump after any repair !.. the shaft seal used on this pump is a 100 or a 200 . i use pac seal mechanical shaft seals cost about 10$.. go kits are not required on 90 % of repairs $$
Apr 13, 2009 | Sta Rite GO-KIT-6 Sta-Rite P2RA DuraGlas /...
Parks Optical 2500 Gallon Intex Quick Set Pool Water Replacement Filter Pump only Logo
Top Parks Optical Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Parks Optical Pool and Spa Expert? Answer questions, earn points and help others
