Question about Dryers
White knight tumble dryer cl847 not heating
Dryer just blows worm air iv pressed the reset button on back of dryer but still worm air but no hot air,
    Genius:
  • Dryers Master
  • 1,966 Answers
-Possibly one of the heater element blow out.
-Timer switch assembly stuck in low position.
Good luck
Mai
Posted on Dec 21, 2013
4 Suggested Answers
  • 135 Answers
SOURCE: tumble dryer not hearting up
Check the reset button on back of machine.
If it clicks when pressed heat will be restored.
Please post back your findings for further assistance if required.
Posted on Jan 07, 2009
beltronic205
  • 1466 Answers
SOURCE: White Knight sensordry tumble dryer which only works on low heat
Could be element or thermostats, element is twin giving two heats ie !00watt/ +1800watt, possible one side has gone, you bcan check with multimeter and compare readings..Good luck
Posted on Oct 01, 2009
  • 534 Answers
SOURCE: my white knight tumble dryer does not heat
you have a heating element burnt out. You will need to remove the back of the dryer and in the bottom of the dryer casing you will see the element Looks like a toaster element. Take model and serial # to an appliance parts house for replacement. An appliance tech shouldn't charge you that much to repair if you dont want to do it yourself.
Good luck hope this helped you some
Dave
Posted on Jan 28, 2010
Heater not blowing hot air
when you operates the heater button worm water of your engine's water jackets enter to the evaporator locates inside your A/C blower & air flows through it & air becoming worm. Therefore I proposed you to check your vent linkages for vent doors inside the blower unit.
Nov 24, 2013 | Land Rover Range Rover Cars & Trucks
I have a Whirlpool Gold Dishwasher Quiet Partner IV. GU Series. It has stopped working and there are no lights on the panel. We have checked the power supply and that is fine.
Hello & Welcome to FixYa
Press and hold the AIR DRY/RINSE ONLY button to reset the control, if you have already tried this and it is possible that the door was opened while in cycle then the first thing that should be checked is the door switch/lock assembly. You can take a hair dryer and try to blow air on that, if the problem returns then replacing the door switch/lock assembly is recommended repair. Please get back to me if you have any other questions.
Kevin
Dec 11, 2010 | Whirlpool Gold 24 in. Built-In Dishwasher...
My doesnt get hot do i need to replace element took back cover of noticed reset button on element box was kicked do i need to replace element and re set switch to
Hi!!
Before spending money on another heating element, clean filter, vents and exhaust pipe (take it off and check both, the pipe and inside the dryer). A restricted hot air passage will make the heating elements thermal protection (reset switch) to activate.
Once unclogged, press the reset button and try again.
Good luck!!
Mar 20, 2010 | Dryers
Kenmore HE Dryer not blowing hot air
I have a gas kenmore dryer... the drum runs- it blows air and for just a few minutes warm air but after a few minutes the air is cold. I have cleaned the vent checked it good. I didn't see the fuse on the back I have the bottom latch open and see several wires that can be disconnected; snap together.
Mar 10, 2010 | Kenmore 63942 Dryer
Dryer turns but air is cold not hot. it not drying at all has been running for more\ than an hour and my towels are still very wet
Depends what make of dryer you have? check on back of dryer and see if there is a small red button, if so then press this and it should reset your thermel cut off switch. not all dryers have this button.
Feb 18, 2010 | Dryers
Dryer does not heat model td-v75120E
Hi, open the back panel. You will find a black cutout switch with a red button on it. Press the red button to reset the heating mechanism. Close the back panel and test the machine.
Sep 10, 2009 | LG DLE2532W Electric Dryer
Tumble dryer not hearting up
Jan 07, 2009 | Dryers
Bosch exxcel tumble dryer blowing cold air only
Remove smallish cover in center of back, 2 self tappers. Press RED reset button till it clicks, located just left of center at the back.
Oct 05, 2008 | Bosch Dryers
Dryers Logo
102 people viewed this question
Top Dryers Experts
