Question about Garden
Need recoil for a blue max chainsaw - Garden
3 Suggested Answers
kel1guy2002
  • 3740 Answers
SOURCE: I have a Blue Max high presure washer, 2200 psi.
Hi Greg. Walk into your nearest Lawn Mower parts supply with your engine model number (usually on the recoil) and they will have the replacement part or repair your old one. It is less expesive to have the old one repaired unless the support struts have broken. 2200 PSI should have a Honda GX160.
engine:
Here is another source....
http://www.northerntool.com/shop/tools/product_200327175_200327175
They can range from $32.00 to $68.00 depending on source.
Honda PN is: 28400-ZH8-013ZA (do net search this number) Or call your local Lawn Mower repair Supply with the number.
If you have a Briggs & Stratton engine I will need the ENGINE model number off of the air shroud just above the spark plug.
Thanks for using FixYa.
Kelly
Posted on May 04, 2010
Testimonial: "yes - your info was helpful Thanks Greg"
kel1guy2002
  • 3740 Answers
SOURCE: Can't find replacement recoil kit
What engine is on your presure washer? I really need a model number to give you the correct information.
If you have the engine model number you can look the engine up on the net at:
http://jackssmallengines.com/help.cfm
and find your recoil assy.
If it is just the rope that broke you can take the recoil to any lawn mower repair shop and they will repair your recoil by replacing the needed parts or replace the rope. You do not need to take the whole unit to the lawn mower repair shop. FYI a NEW honda recoil assy ranges from $32.00 - $68.00 depending on net source.
Kelly
Posted on May 28, 2010
Why is my 14 &20 chainsaw Model 8901/8902 having difficulty pulling cord. It seems to lock. What could be the problem?
if it runs ok after you get it started it could be the starter pulley. the blue max saws have that problem
Feb 10, 2015 | BLUE MAX 2-in-1 - 14"/20" Combination...
I bought my husband a 2 pc. chainsaw set. Blue Max 14"-20" It will not stay powered up to make a cut, after it is started. We need to know where to take it for service, or what process is needed for a
A good idea to take it to home depot. Some of them have stations that work on fixing power tools and other things that break often. As for your problem it seems as if there is some sort of connection problem with the battery. Whenever you move it may jostle the connection enough to cut it off there for turning of the chainsaw. If you can check they battery and see if there are any loose cables that may help and if not take it to home depot.
Jan 29, 2015 | BLUE MAX 2-in-1 - 14"/20" Combination...
I changed the chainsaw chain on my Blue Max chainsaw. The kick-back seems to be locked
Bob take the chain off again and remember to tighten the tensioning bar so that the chain is slightly loose. Enough to pull a few cm of the bottom just to stop it being tight.
Aug 30, 2014 | BLUE MAX 14" Chainsaw replacement...
How to test ignition coil on a stihl ms290 chainsaw?
remove spark plug .put new one on to plug lead make good earth.turn ign. on pull over check for a good blue spark.
Jul 06, 2014 | Stihl Ms310 Ms290 Ms390 Complkete Starter...
Stihl chainsaw MS460 Can't pull recoil
It could be the recoil is stuck. a couple of things to check. Take the clutch and chain cover off, remove the spark plug and manually try to turn the motor over by turning the clutch. If the motor/engine is not seized, take the pull start/recoil cover off and pull on the cord to see if it will work and that the cord returns back into the recoil automatically. Don't take the nut off the inside of recoil holding the cord spool on. If the engine is not seized, and the recoil now goes in and out by pulling the start cord handle reassemble and pull over the engine a few times. This a good time to check the spark plug is working, now put the spark plug back in and start the engine. It's a good time to clean the air filter as well while the chainsaw is mostly apart and clean all oily sawdust off the chainsaw in the crevices etc..
Jun 05, 2014 | Stihl Chain Saw Handle Models 044 046...
Kelly
Apr 16, 2010 | Psi Blue Max 2200 High Pressure Gas Power...
engine:
Kelly
Apr 05, 2010 | Psi Blue Max 2200 High Pressure Gas Power...
Recoil problem
Hi there .
You can try to remove the recoil starter and turn the flywheel by hand . If it turns by hand you have to replace the recoil starter if it does not turn by hand that means the piston is seized and you have to replace the piston ans probably the cylinder . To do that you need some mechanic experience .
Hope this help
Sep 02, 2009 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Recoil not recoilling good
hey fark
This is easy. Take off rope housing (four screws). Once off, pull the string out 3/4 of the way. Once out, tie string around spindle one extra time ( real easy just wrap string once more around winding spool ). This oughta make string snap back after pulls.
Jun 28, 2009 | Poulan Pro 16-Inch 38 cc Anti-Vibration...
Garden Logo
105 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
