Question about Vivitar DVR Video Cameras
DVR 584 HD MANUAL
TOUCH SCREEN
  • THOMAS MOORE
    THOMAS MOORE Nov 23, 2013
    its ok my friend who is a computer expert set everything up for me even acer my pc maker could not do it
  • Anand Sethi
    Anand Sethi Mar 06, 2014
    what is the recording time on this camera?
Need a manual I can print out
Sorry, but it would seem one would need first to know the brand and model. If this is a standard option in a car, then the make and model of the car would also do.
Jan 11, 2016 | HD DVR Hd Portable Dvr With 2.5 Tft Lcd...
How to format HD DVR Camera
read the instructions again . perhaps it needs done on a computer .
Feb 26, 2015 | HD DVR Hd Portable Dvr With 2.5 Tft Lcd...
Top and bottom of the screen are cut off
That set has an aspect ratio of 4:3. The problem is that what you are sending to it is 16:9 So you are sending an hd signal to a non HD television. The tuner is NTSC which is not HD. Theres not much that you can do about this.
Jan 17, 2014 | RCA F27650 27" TV
Need manual in english hd portable dvr with 2.5"
Hi Cynthia: Not sure what brand name your camera is, but I found this using a simple google search. The picture is the same, but as you must be aware there are several manufacturers along with numerous brands...Hope this helps....Best.....James
Oct 14, 2013 | Mostbuying Portable HD Car Camera DVR with...
Why can't i see 1080p programs on my directv hd dvr? The test on the hdr says my receiver doesn't receive 1080p. My tv is a Sharp LC-62C42U which is suppose to receive 1080p!
Your DVR can't detect whether your TV can do HD or not. If the message is stating that your receiver (which is your DVR) can't receive 1080P, then you'll need to contact DirecTV for assistance. You may need to replace your DVR.
Mar 01, 2011 | Sharp LC-62C42U 42 in. LCD TV
HDTV goes blank when connected to Fios HD-DVR or Fios DTV recvr.
If you can first connect the Fios box via component and that will rectify the issue and still allow HD. HDMI is funny, if there is anykind of communication issues between the TV or the Fios box you see what happens. You might also call Samsung to see if there is ANY firmware/software updated for your TV specifically to fix such an issue with the Fios/Mortorola connection. If there isn't then the issue is the cable box since the TV works ok on HDMI with other devices.
Jul 23, 2009 | Televison & Video
Dish Network VIP612 DVR - unwanted "Info" screen
The problem has nothing to do with the television. To fix it, simply change the remote address. The directions for this are in the Dish manual, or you can check it out on the website here: http://tech.dishnetwork.com/departmental_content/TechPortal/content/tech/receiver/622.shtml
Hope this helps.
Oct 18, 2008 | Kenwood RC-R0720 Remote Control
Mitsubishi hd 1080
The format of what you are watching plays a major part in whether all of the screen is used. If the program is 4:3 the screen will remain pretty much square. 16: 9 would be the most desirable for filling all the area. Go ahead and acquire a manual, they're not much...accordianman
Feb 16, 2008 | Mitsubishi WS-65869 65" Rear Projection...
Hd dvr
if you are connecting the dvr via component video cables select the output to 480i and not 480p or other higher formats.the tv cannot support anything higher than 480i. or try using composite video hookup instead.
Jan 29, 2008 | JVC AV-36320 36" TV
Video Cameras Logo
80 people viewed this question
Top Vivitar Video Cameras Experts
Lawrence Oravetz
abdul rauf
abdul rauf
Luis Soria
Luis Soria
Level 1 Expert
Are you a Vivitar Video Camera Expert? Answer questions, earn points and help others
