Question about Gateway FPD1810 18.1" LCD Monitor
Monator has no signal
I have a gateway flate screen modale number FPD1810 it is the 19inch. When I plug it in to my labtop it says self diagnostics no signal check singnal cables, in a 4 by 2 box. I did, the cables are pluged in, I even restarted the computer, but there is no picture. I had it pluged in before and it worked, but know it does not.
    Genius:
  • 2,985 Answers
Plugging into the laptop as an alternative monitor needs you to set the Laptop to divert the signal to the external monitor.
As you did not mention the laptop I cannot go further  except to suggest you read the manual with regard this situation.
On some models of laptop this function is actuated  by pressing a certain key- which may have for example a BLUE symbol on  in the front edge whilst pressing another key in the region of the space bar with a blue symbol on it.
Then manual will tell all
Posted on Oct 10, 2007
SOURCE:
I have a 2006 ford fusion which the radio system
Inspection and Verification
  1. Verify the customer concern.
  1. Visually inspect the following for obvious signs of mechanical or electrical damage.
Visual Inspection Chart Mechanical Electrical
  • Audio unit
  • Antenna
  • Antenna cable
  • Door trim panel(s)
  • Speaker(s)
  • Noise suppression equipment
  • Smart junction box (SJB) fuse(s):
    • 12 (7.5A) (accessory delay feed)
    • 17 (20A) (subwoofer amplifier) (Audiophile)
    • 18 (20A) (audio unit hot at all times)
    • 22 (7.5A) (audio unit hot in START)
  • Battery junction box (BJB) fuse(s):
    • 20 (20A) (LH audio amplifier) (THX®)
    • 21 (20A) (RH audio amplifier) (THX®)
  • Circuitry
  • Digital signal processing (DSP) module (THX®)
  • Subwoofer amplifier (Audiophile)
  • Audio amplifier(s) (THX®)
  • Audio unit
  1. If an obvious cause for an observed or reported concern is found, correct the cause (if possible) before proceeding to the next step.
  1. If the cause is not visually evident, connect the diagnostic tool to the data link connector (DLC) and select the vehicle to be tested from the diagnostic tool menu. If the diagnostic tool does not communicate with the vehicle:
    • check that the program card is correctly installed.
    • check the connections to the vehicle.
    • check the ignition switch position.
  1. If the diagnostic tool still does not communicate with the vehicle, refer to the diagnostic tool operating manual.
  1. Carry out the diagnostic tool data link test. If the diagnostic tool responds with:
    • CAN circuit fault; all electronic control units no response/not equipped, refer to Section 418-00 .
    • No response/not equipped for the audio unit, Go To Pinpoint Test A .
    • NOTE: Do not press any buttons on the audio unit while the audio unit is carrying out the self-test. System passed, retrieve and record the continuous diagnostic trouble codes (DTCs), erase the continuous DTCs, and carry out self-test diagnostics for the audio unit.
  1. If the DTCs retrieved are related to the concern, go to Audio Unit Diagnostic Trouble Code (DTC) Index.
  1. If no DTCs related to the concern are retrieved, and the concern is not visually evident, proceed to the Speaker Walk-Around Test and the Audio Unit Self-Diagnostic Mode.
NOTE: To enter the audio unit self-diagnostic mode, the audio unit must be turned on and in radio tuner mode (AM/FM).
  1. To enter the following tests, press the desired preset button while in the speaker walk-around test or while in the audio unit self-diagnostic mode.
  1. To exit the audio unit self-diagnostic mode, turn the key OFF or the audio unit off.
  1. If the concern remains and the fault is not detected, GO to Symptom Chart to continue diagnostics.
  1. The self-diagnostic mode has the following functions available:
    • Preset button 1 = On-Demand Self-Test. This button runs the on-demand self-test.
      • Pressing the MENU DOWN button allows scrolling of any DTCs found during the test while in this menu.
    • Preset button 2 = Display Continuous DTCs. This button enables viewing of any continuous DTCs that have been logged.
      • Pressing the MENU UP button allows scrolling of any DTCs while in this menu.
      • While continuous DTCs are being displayed, pressing the EJECT button will clear all present DTCs.
    • Preset button 3 = Signal Strength Test. This button displays the signal strength.
    • Preset button 4 = Software Version Display. This button displays the audio unit software version.
      • Pressing the MENU UP button allows scrolling of all audio subsystem software versions while in this menu.
    • Preset button 5 = Display Test. This test illuminates all the display segments for 5 seconds, then turns all segments off.
    • Preset button 6 = Configuration Status. This button enables audio unit configuration status.
      • Pressing the MENU button displays the ACM part number while in this menu.
  1. To exit the self-diagnostic mode, turn the audio unit off or turn the key OFF.
Feb 05, 2018 | Cars & Trucks
Hardware diagnostics
several reasons. first make sure all cables are corectly plugged in. make sure that monitor is working by testing it on another pc. if it turns on. most likely bad cables or the pc it self its not sending a signal to the monitor. ( which is bad the cause for it could be anything) try plugging it into another working pc and let us know.
Jun 03, 2013 | Gateway Computers & Internet
The modal is a 37inch samsunge modal le37a557p2f and it just keeps cummin up no signal on the screen wount giv me any channal at all and im pluged rite in 2 the ariel at the mains and i no my arial is good...
Go into the menu and make sure that it is set up for the type of signal you can receive. Some will receive terrestial and some are set to receive digital. If it is set up wrong, it will give the no signal message because there is either no digital available or no terrestial avalable.
Oct 16, 2010 | Televison & Video
I bought a Gateway FPD1830 monator from a friend. What does it need other than a power cord to hook to a dell computer?
VGA or DVI cable, this cable has approx 1" x 1/2 inch blue or white ends and should connect both to the monitor and to the computer to transmit the video signal between the two.
Aug 29, 2010 | Gateway FPD 1830 18.1" Flat Panel LCD...
Screen monitor self diagnostics show
that means no incoming signal, but some problem i encountered related in vga cable and lost connection on ckt board. as long that the cpu is working and the monitor show (no signal) focus trouble shooting on that parts. replace cable if possible( same port configuration)
Apr 20, 2010 | Princeton Digital VL2018W Monitor
Print screen
Press first the PRINT SCREEN key then open an application PAINT from ACCESSORIES >> PAINT. Then on PAINT application just do the pasting of the print screen that you made. Thank you.
Oct 09, 2009 | Gateway 2520915 Keyboard
To put the immision light off
you need to have the coed cleared with diagnostic.machine
Jun 08, 2009 | 2000 Suzuki Reno
Li-ion S62044L (11.1V)
First Try charging the battery fully, then try turning on the computer. If it goes out suddenly it will more than likely need to be replaced.
You can request a new battery from the gateway website under customer support.
If you are not sending the battery back and are planning to throw it out if it is no good, Refer to the Material Safety and Data Sheet for proper disposal.
Jul 21, 2008 | Gateway 4026GZ Notebook
Open Questions:
See all Gateway FPD1810 18.1" LCD Monitor Questions
Computers & Internet Logo
142 people viewed this question
Top Gateway Computers & Internet Experts
Ekse
Prashant M
Prashant M
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
