Button doesn't work
I have new router ZyXEL Keenetic GIGA II. May be it's not bad, but it doesn't turn up:-( Just that f..g button was inserted not working obviously. I have to short this button. Right now i don't have tester to determine suitable contacts. Could anyone point me they? https://plus.google.com/photos/117656213542387417839/albums/5948771464744515025?authkey=CLqEkars5ajVswE
  • Serge Nov 23, 2013
    There is usual micro switch. I'd like to know contacts i need to short, to make item turned on always
    Scholar:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 183 Answers
Unless you have no other options I would recommend replacing your router. Really can't recommend shorting anything to force something to work as it may damage your equipment or injure or kill you. If your are an experienced tech and are confident you can do it safely, you may be able to take the unit apart and solder another switch in place or simply solder a bridge across the contacts. you may be able to find a shematic but if it is a simple swich, it should not be hard to determine how to short the contacts once you can see them plainly. If this is a new router, why not return it for a replacement? Hope this helps.
Posted on Dec 06, 2013
4 Suggested Answers
SOURCE: Zyxel Modem Router P660hw wont work on LAN
If a LAN connected PC will not work while a wireless laptop is connected you need to go into advanced router setup, bandwidth management, and untick the three boxes labeled "active" to disable the band width management. Easy!
Posted on Apr 30, 2008
megax01
  • 50 Answers
SOURCE: my zyxel 660 hw works fine for 10 minutes, then starts disconnect
If the same thing is happening with the USB WIFI on the PC. This sounds like a problem with your PC rather than your router. Is your antivirus / spyware scanner up to date? If not up date it and run a full system scan. Also you should check to see if your Firewall is up to date, and that the wireless network you are connecting to is included in the safe zone area of your firewall.
1 more thing if you are using a Thrid party firewall (i.e. Norton, Zone Alarm, McAfee, Etc.) Make sure Windows Firewall is deactivated (in Conntrol Panel) having 2 firewalls on can lead to random problems
Posted on Jan 19, 2009
SOURCE: can anyone help me set up a dmz on this router(zyxel p 334)
Do you have a static IP to portforward with? i would not recommend DMZ because most routers lie - they still use a firewall even with DMZ.
Posted on Jul 01, 2009
Zyxel P660HW-D1 Router. Which settings need to be changed to turn it into a repeater and connect with my main broadband router.
Can't use a router as a repeater in a wireless sense. You could set it to AP mode and run an ethernet cable from a lan port on your other router to the WAN/uplink port on the Zyxel. If it doesn't have AP mode then you could have it in gateway mode run have a different subnet on the Zyxel with DHCP.
Oct 29, 2011 | Zyxel P660HW-D1 Router
Hor to reset my router zyxel 660HW
There is a small button/hole at the back of the router. Usually you need a pin or an sharp object to poke the button.
Press & hold the button for 5seconds to reset your router to the factory settings.
Apr 05, 2011 | Zyxel Prestige 660HW Wireless Router...
I forgot my routers password.
There will be a button or small hole to insert a pin it that is the RESET for thee router. Resetting it will remove the password and you'll have to set it up again with new password.
Feb 18, 2011 | Zyxel (91-004-361002) Wireless Router
How do i accesses my router's configuration page, and how do i find out it's username and password? I have a Lxair b-3000.
If you forgot your username and password to any wireless router, the normal procedure is to do a factory reset. This means it will set the router back to the way it was the day you bought it. Warning: this will forget all the configuration you have done and you will need to reconfigure. If you don't know how to reconfigure then I don't recommend this.
To do this there is a RESET button on the side of the router. Hold it for 10 seconds or until one of the LED lights turns red. Release the reset button and if the SYS LED light begins to blink the defaults have been restored and ZyAir will restart.
If this doesn't work you have a second option
Turn off the ZyXel ZyAir B-3000, then while holding the RESET button turn the ZyAir back on. Continue holding the RESET button. The SYS Led light will begin to flicker and blink rapidly for 20 seconds. Release the RESET button and the ZyAir will restart. Wait for it to restart.
The factory password for the ZyAir B-3000 is 1234
Click here http://192.168.1.2 and type in the 1234 password and click LOGIN. You will probably see a screen to change your password. I recommend you do this.
You will need to reconfigure the router
As I said before change the password from 1234 to something else, plus If there is no security after the factory reset I would read the manual (see below) and setup at WPA or WPA-PSK security on the wireless router (I do not recommend WEP security it is too easy to crack).
You can find the ZyXel ZyAir B-3000 manual here: ftp://ftp.zyxel.com/B-3000/user_guide/B-3000_3.50.pdf
and the
ZyXel ZyAir B-3000 quick start guide here: ftp://ftp.zyxel.com/B-3000/quick_start_guide/B-3000_.pdf
Jan 28, 2011 | Zyxel ZyAIR B-3000 802.11b (ZAB3000)...
I need router configuration password for Zyxel P-660H-D1 modem
Download a userguide from http://us.zyxel.com/Support/Download-Library-Result.aspx?mif=20050726121025
I think the password is 1234 for admin mode
Aug 01, 2010 | Zyxel Prestige 660H Router
I keep having to type in my router number to the WEP box
Check your Protocol or Encapsulation settings within your Routers configurations it should be set to PPPoE/ LLCbased.
Jul 24, 2009 | Zyxel G-220 802.11g/b Wireless Adapter
I can't get access for new laptop via existing zyxel 600 router
On the left side there is a menu called Advanced Setup. After you click on that button you must select on the main panel view the Security button. There you will find the settings for the wireless connection and the MAC filter option also.
Mar 12, 2009 | Zyxel Prestige 600WH Wireless Router...
Can I completely delete the memory from my Zyxel P-334WT router?
Hi there, in short yes. the reset button on the back will delete all the info on the router however a short press will not. What you will need to do is hold the button down for a good 20 second.... if this does not work then pull the power lead out and push it back in with the reset button pushed in, again for a good few second. Now to view all setting on the router before hand open your web browser up and in the top address bar type 192.168.1.1 or 192.168.0.1 the access code for your router varies on the make but can usually be found in the manual.when asked for a user-name and password just enter those (usually the user-name is ADMIN & the password is PASSWORD or also ADMIN. anyway you shold then be able to view the log and all settings.... hope this help ....Tony A
Dec 13, 2008 | Zyxel P-334WT Router (91003155003)
Modem router
I can tell that your network topology is not the most complicated ever.So u ve got 3 terminals,1 desktop pc and 2 laptop.Simple,reset your zyxel(from the button on the back) and reconfigure the Local area interface connection(ip & subnet mask for the zyxel),reconfigure your internet connection,(WAN zyxel interface) in case the zyxel is your Internet gateway too.Third,make sure NAT & Firewall are up and running(usually are by default) Finally,reconfigure the WiFi interface with the correct SSID name & WEP key or whatever security you prefer.Write down the security pass for your wireless and you are done.Good Luck.
Apr 19, 2008 | Zyxel Prestige 660H Router
Computers & Internet Logo
24 people viewed this question
David Payne
David Payne
