Question about Blanco Plumbing
Blanco Model 157074R causing a water hammer situation.
Temporarily replaced it with a cheap model and no more hammering. What part do I need to replace in the BLANCO?
danhawke
  • 4 Answers
SOURCE: how to replace cartridge on
Somewhere around where the handle fixes to the tap should be a grubscrew of some kind undoing this will allow the handle to be removed this will give you access to the cartridge which can then be removed with the correct socket, obviously you will need to turn off the water supply to the tap first!!
Posted on Jan 27, 2009
  • 33 Answers
SOURCE: blanco purus II poor water pressure
If the pressure is the same for both hot and cold. Then most of the time it could be just a blocked Screen/Aerator. Unscrew it and see if the pressure has improved. If so the replace it! Lowe's or Home Depot have them.
Posted on Jan 30, 2009
jgwhomeequip
  • 1902 Answers
SOURCE: Leaky Blanco Single Lever Kitchen Faucet with separate sprayer
You only need one small o-ring. If you put two of them it will not work properly and will mostlikely leak like crazy. If this helped please rate.
Posted on Feb 12, 2009
gary1121
  • 332 Answers
you can call or e-mail the company, if the faucet is the one in the picture it is a single cartdridge, turn of bith hot and cold water, take an allen wrench into the little plastic cover to remove the handle , unscrew the top cover or it might pop off, that there is either a large lock not or 3 screws holding down the cartdridge, take it out replace it put some faucet frease around all rubber gaskets then install it in the smae way it came out
Posted on May 30, 2009
snap101
  • 117 Answers
SOURCE: low water pressure/slow flow Blanco Elan faucet 2.2 gpm
pull the sprayer out, get some plyers or a wrench and losen up the connection. between the hose and the sprayer there is usually a screen take it out and walla it should take care of you, it also helps to leave the sprayer in some lime away or vinegar for a few hrs to get the hard water losened up in it
Posted on Aug 01, 2009
I have a black and decker rotary hammer drill i can only read 3 numbers of the model it is 045 but its the last three sn number 0481121 under pat 3309541 need parts manuel for
Your one sounds like this one
http://www.ereplacementparts.com/black-and-decker-5045-type-100-rotary-hammer-parts-c-4167_7879_17406.html
However there are three variants on this page.
http://www.ereplacementparts.com/black-and-decker-hammer-drill-parts-c-4167_7879.html
Black and Decker Hammer Drill Parts ' Great Selection ' Great Prices ...
  1. Cached
  2. Similar
Black and Decker 22738 Type 1 1/2-Inch Hammer Drill Parts. 22738 Type 1 Black ... Black and Decker 27106 Type 1 3/4 Rotary Hammer Parts. 27106 Type 1 ...
Black and Decker 5045 Type 100 Rotary Hammer Parts
www.ereplacementparts.com/black-and-decker-5045-type-100-rotary-hammer-parts-...
  1. Cached
  2. Similar
Black and Decker 5045 Type 100 Rotary Hammer Parts .... Drill Parts Hammer Drill Parts Rotary Hammer Parts. Search within model. SEARCH. Discuss ' Repair ...
Black and Decker Hammer Drill Parts & Repair Help ' Fix.com
https://www.fix.com/parts/power-tool/drill/hammer-drill/black-and-decker/
  1. Cached
Shop for Black and Decker Hammer Drill parts today. Find genuine replacement ... (Type 100). Variable Speed Reversible Rotary Hammer · 5014. (Type 100).
Black and Decker Parts - Tool Replacement Parts ' Tool Parts Direct
www.toolpartsdirect.com/brands/blackdecker.html
  1. Cached
  2. Similar
Black and Decker Drill & Driver-Drill Parts · Black and Decker Hammer Drill Parts ... Black and Decker Rotary Hammer Parts Model Schematics and Tool Parts ...
Black and Decker 5043K_TYPE_3 ROTARY HAMMER KIT Parts ' Tool ...
www.toolpartsdirect.com/blackdecker-5043k-type-3-rotary-hammer-kit.html
  1. Cached
Find the Black and Decker blackdecker_5043K_TYPE_3 ROTARY HAMMER KIT parts you need at Tool Parts Direct. Shop thousands of Black and Decker ...
Black and Decker Rotary Hammer Parts ' Tool Parts Direct
www.toolpartsdirect.com/hammer/rotary-hammer/blackdecker.html
  1. Cached
Replacement Black and Decker Rotary Hammer Parts online. Tool Parts Direct has thousands of Rotary Hammer Parts to fix Black and Decker tools. Shop by ...
www.toolpartsdirect.com/hammer/rotary-hammer.html
  1. Cached
  2. Similar
Tool Parts Direct carries the largest inventory of replacement Rotary Hammer Parts for thousands of make and models. Buy Rotary Hammer Parts online for all of ...
Black & Decker Replacement Parts - 1800ToolRepair.com
https://www.1800toolrepair.com/tool-repair-parts/black-decker
  1. Cached
Black & Decker replacement parts for all Black & Decker tools. ... Black & Decker Cordless Circular Saw Parts ... Black & Decker Electric Hammer Drill Parts.
Beyond Parts - Black & Decker ServiceNet
servicenet.blackanddecker.com/Parts/Detail/29096
  1. Cached
  2. Similar
Available, Add Parts to Cart ... Model #, Model Description, Parts Diagram. 5041K Type 1 · MACHO I ROT HAM KIT · 5042-09 Type 1 · HD ROTARY HAMMER.
black and decker rotary hammer drill Google Search
Dec 25, 2016 | Rotary Drills
How to replace cartridge on blanco 157074R-ST
Check "YOUTUBE" for blanco cartridge replacement. They have a great video on how to do it.
Apr 18, 2014 | Blanco Plumbing
How do I replace the cartridge on my 157074R-ST. I'm a little handy, but I have a bad back. Can the repair be completed without going underneath the sink?
This is an easy job.
The only thing to do under the sink is to turn the water off.
The hard part is finding the replacement cartridge (Blanco #2408).
Once you do that, simply remove the handle (undo the set screw in the front, below the temperature indicator,) and remove the lock nut that holds the old cartridge in place.
Lift the old cartridge straight up and out, put the new one in its place, and replace the nut and handle. The whole job will take you ten minutes, from start to finish. (Remember to turn the water back on.)
I've attached a parts breakdown:
http://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=3&ved=0CFUQFjAC&url=http%3A%2F%2Fwww.wdcappliances.com%2Fpdfs%2F440652.pdf&ei=cSCTU8fVLcO-oQSe74CIBQ&usg=AFQjCNHkRKgAx1cbIaGdtfDPk4jSEf7Fuw&sig2=ZORVc7a3zktBNAX9s61QhQ
Check "YOUTUBE" for Blanco cartridge replacement. They have a great step by step video.
Jackhammer is not hammering
Its need service if its anchor / drive gear is worn or the o-rings seals are worn, if its this model hammer make a trade-in service that in case its an old hammer like this model its not the model to service by your one the best option is trade-in by your dealer. if its handle this model
http://dasen-hammer.en.made-in-china.com/product/BMgJKvoEXFpm/China-High-Quality-11e-1500W-Electrical-Demolition-Hammer.html
Mar 27, 2014 | Hammering
I have the chance of a cheap D25303K dewalt 230 volt drill. does it have a chisel rotation stop (percussion only) feature ?
Go to the Dewalt service website at http://servicenet.dewalt.com, put the model number in the parts search box and you'll be able to view or download the parts breakdown and owner's manual. By the manual that model does have three modes; a hammer only, drill only and hammer/drill.
May 28, 2012 | Dewalt D25303K Electric rotary hammers
Blanco Eye Kitchen tap cold water is leaking from tap[ WHEN TURNED OFF. I have remove the allen screw that secures the the cold lever but I cannot remove the leaver
Hello doy.. get a can of WD-40 penetrating lubricant and spray it on the seam connecting the lever and the body. It will penetrate within an hour or so. Repeat if necessary.
Also use a plastic head or a rubber head hammer to tap it up.
Joe
Thanks for choosing Fixya!
Mar 12, 2011 | Blanco Plumbing
The faucet leaks where the spray hose attaches to the spray head. Model 157-074r-st. The problem occurs when water is turned on. If the spray head is in the handle, water leaks below the sink. If the spray...
Yes the leak is the washer. You can get a new washer at any hardware store. Just take the damaged washer with you and have someone at the store help you.
Here is the washer size according to the manual 20X12X2.5
Page 2 of the link below.
http://www.blancoamerica.com/SPECIFICATIONS/157074R.pdf
Feb 27, 2011 | Blanco Classic Single Handle Faucet with...
Need a control knob for : dyna-glo pro propane heater. model # rmc-tt 30dgp-01, # rmc-tt30dg, #rmc-tt30gd. serial: # 09 005720
Contact GHP Group Inc, (877) 447-4768 to order a replacement regulator - MAKE SURE YOU HAVE THE PROPER HEATER MODEL NUMBER. Replacement Part Number: S2TT0001B for the RMC-TT30DGP.
Replacement cost including shipping is a couple bits over $21.
When talking to the technician on the phone, he cautioned me against rapidly opening the tank valve, which hammers the regulator (the replacement one is more robust than the original), kinda' like how water-hammer can cause damage to water pipes and/or water appliances. Open the tank valve gently, don't just whip it open (like I used to), your regulator will last a lot longer that way.
Because of the press-fit and pins used in the regulator construction & assembly, self-repair is not possible or recommended since the regulator may not seal correctly afterwards.
Dec 17, 2010 | Garden
With water hammer arrestors in place, there is
The water hammer arrester installed at the washer is not large enough to suppress the water hammer you are experiencing. This could be due to the length of the pipe between the washer and the water heater or the number of turns in the pipe. Water hammer can occur at right angle turns. Install another arrester near the water heater or at a turn where you hear the hammer sound occur.
Nov 13, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Plumbing Logo
26 people viewed this question
Top Blanco Plumbing Experts
Mack Baxter
Andrew Bugbee
Are you a Blanco Plumbing Expert? Answer questions, earn points and help others
