Unlock computer keyboard
The keys on my HP Laptop do not work.
    Champion:
  • 411 Answers
Plug in an external Desktop USB keyboard to test. If keys work, use that external keyboard, to go to control panel and check/adjust some keyboard parameters. Some virus change some of those parameters to "disable" your keyboard.
Otherwise order a replacement laptop keyboard from HP spares/
Posted on Dec 19, 2013
4 Suggested Answers
myrlex
  • 674 Answers
SOURCE: my hp pc keyboard is locked. how to unlock it
just press fn + f7 or f8 funtions..to unlock the keyboard and touchpad..
Posted on May 29, 2009
SOURCE: .My Keyboard is locked-I cant unlock it.
Steps to unlock HP laptop keyboard.
1. Turn off the computer
2. Remove the battery.
3. While the battery is out, hold the power button for about 30 secs
4. Put back the battery
5. Turn back on the computer and it should be good to go.
Posted on Jun 03, 2009
parrotheadpc
  • 2600 Answers
SOURCE: dell inspirion keyboard 1420 replaced new but not working
Not trying to insult your intelligence but are you sure you plugged the keyboard cable all the way and even into the slot and locked it in place. I have had issues where the contacts were not all the way seated in the slot and not fully locked in and the computer knew the keyboard but I had lost partial function. Below is the Dell diagnostics manual for running start up test on your laptop. If your installation is the original it should have a diagnostics partition on it. These steps will show you how to access and run. Just copy and paste the below in your internet browser address bar, hit enter, you can also print it to follow along when the laptop powers down. Good luck,, ParrotHead PC Repair
http://support.dell.com/support/edocs/systems/ins1420/en/OM/trouble.htm#wp1061039
Posted on Sep 05, 2009
I am not able to work with my keyboard function keys and num keys and function keys . but the the touch pad key is onlyworking .please send a solution to unlock the keyboard. hp pavilion g6-2102tx
Examine your keyboard to ensure your "Number Lock" key is not activated. This activation is indicated by the key being lit up. If the key is activated, press it to deactivate the lock. The number lock key will deactivate an entire segment of your keyboard
Start, click Run, and type regedit to open the Windows registry editor. In the registry, open the below folders.
HKEY_CURRENT_USER\
Control Panel\
Keyboard\
Within the keyboard folder, you should have a string value named "InitialKeyboardIndicators" with a value of 0, 1, or 2. Below is the explanation of each of these values.
0 = Num Lock is turned OFF after the logon.
1 = Disable Num Lock.
2 = Numlock is turned ON after the logon. Hope this helps.
Dec 10, 2012 | Computers & Internet
Hp wireless keyboard not working
exact key board driver install then try
what keyboard model?
download load driver for keyboard
update keyboard driver
May 16, 2012 | HP Computers & Internet
How to unlock keyboard on Pavilion g6 laptop?
press the ctrl button and the pause/up arrow button - keyboard will unlock.
Dec 04, 2011 | HP Computers & Internet
HP LAPTOP G-60 630US KEYBOARD PART # 496771-001 HOW DO I TAKE THE OLD ONE OUT
Do it carefully..at your own risk..
HP 496771-001 Keyboard Repair and Replacement
Are you considering laptop keyboard repair? You might think twice if you happen to be the lucky owner of a laptop, because replacing the keyboard rather than repairing it could be a lot less expensive. Laptop keyboard replacement on this particular model is very easy and takes just a few minutes. Here is a quick HP 496771-001 Keyboard repair tutorial with step-by-step instructions.
Once you have purchased the new keyboard, all you need to replace the old with the new is a screwdriver and something plastic, flat and thin like a credit card or guitar pick.
Step one: Remove the two screws from the bottom of the computer that are holding down the HP 496771-001 Keyboard bezel. The bezel is the bar that sits right above all the function keys.
Step two: Turn the computer over, open the cover and insert the credit card or guitar pick between the bezel and the laptop screen. The bezel has pegs that sit in holes, you need to slowly pry up the bezel. It will make a bit of a popping noise as it is removed.
Step three: Now hold on to the laptop keyboard from the end closest to the screen and gently pull it away from the touch-pad end and flip it over. You will see the ribbon attached to the underside of the HP 496771-001 Keyboard. There is a little plastic connector holding the ribbon to the computer. To unlock it, carefully pull up on the two tabs; one located on each corner of the connector. Be very gentle when you do this as this is the one part that gets broken the most often when changing a keyboard. The ribbon cable will now be released.
Step four: Carefully pull the ribbon out of the connector and remove it along with the entire HP laptop keyboard.
Final step: To insert the new HP 496771-001 Keyboard, place the board face down so you have easy access to the ribbon. Make sure the keyboard is lined up so when you flip it back over the keys are in the correct position. Keep the ribbon straight at all times; twisting it could damage it. Place the ribbon in the connector; it only goes in one way. Once in place, push down on the connector tabs to lock it. Now flip the keyboard over and slide it down toward the touch pad and take the bezel and line the pegs up with the holes and push it in place. Then turn the computer over and replace the two screws you removed from the bottom. You can now power on your computer and see if the HP 496771-001 Keyboard works. If it is not working, more than likely the ribbon was not inserted properly.
Regards,
Ron
Feb 12, 2011 | HP Computers & Internet
How to unlock the key pad on a dell latitude D600 laptop
Hi. Please do troubleshooting steps below:
1. Check to be sure your "Number Lock" or "Function Lock" keys aren't lit. These can lock out certain parts of your keyboard. If either of these is lit, press them to unlock the locked portion of your keyboard. These can be found at the top right on a laptop and between the number pad and main keys on a desktop keyboard.
2. Save all open programs using your mouse. Use your mouse to restart your computer. This will only work if your computer isn't frozen. If your mouse doesn't move, press the power button on your Dell until the computer turns off. Press it again to restart. If the issue was lack of memory or a locked program, this will unlock your keyboard. Continue to Step 3 if the keyboard is still locked.
3. Shut down your computer using your mouse or power button. Don't restart. Unplug your Dell.
4. Remove the battery if you're using a laptop by turning the laptop over and sliding the battery release latch. Slide the battery out and replace after one minute.
Have a good one!
  • Step 2 Save all open programs using your mouse. Use your mouse to restart your computer. This will only work if your computer isn't frozen. If your mouse doesn't move, press the power button on your Dell until the computer turns off. Press it again to restart. If the issue was lack of memory or a locked program, this will unlock your keyboard. Continue to Step 3 if the keyboard is still locked.
  • Step 3 Shut down your computer using your mouse or power button. Don't restart. Unplug your Dell.
  • Step 4 Remove the battery if you're using a laptop by turning the laptop over and sliding the battery release latch. Slide the battery out and replace after one minute.
  • Read more: How to Unlock a Dell Keyboard | eHow.com http://www.ehow.com/how_5063232_unlock-dell-keyboard.html#ixzz0uguUk4bZ
    Jul 25, 2010 | Dell Latitude D600 Notebook
    How can I unlock the blue function keys on my HP Pavilion dv2000?
    If you press the function key (Fn) it should unlock the function keys with normal use. However, sometimes when an external device is removed from the computer while it's in use (such as an external keyboard) the function keys will turn on and refuse to turn off. When this occurs you can typically reboot the computer and the problem will fix itself.
    Jun 08, 2010 | HP Pavilion dv2000t 14.1" Notebook Laptop...
    Keyboard lock
    i think settin of yor computers key board is change. go control panel and click on key board then look setting and correct it, thanks
    Jun 20, 2009 | HP Pavilion ZV6000 Laptop
    Jan 22, 2009 | Computers & Internet
    Computers & Internet Logo
    81 people viewed this question
    David Payne
    David Payne
