I have a error code of Z03-332 on my yellow ink bottle ,that i refilled. I believe the sensor on the cao is bad...how do I bypass it?
  • 320 Answers
SOURCE: Refilling ink cartridges
NVER EVER USE REFILLS ON BROTHER MACHINES, THE PRINT HEAD WILL GO BAD, I AM A SERVICE CENTER FOR BROTHER
Posted on Jan 12, 2009
SOURCE: Refilled my Dell Ink Cartridge
yes, it's safe, and if you are dissatisfied with the cartridge, take it up with the cartridge re-filler...better yet, spend about $100 on a black & white laser printer (HP), and get 2000 pages per cartridge, and reduce cost per page by 20 times or more! And If you buy compatibles for this (which are more reliable) -save even more.
*please rate me
Posted on Mar 25, 2009
  • 10 Answers
SOURCE: I have a Brother MFC-240C printer and need to
YOU are NOT SUPPOSED to "refill" the actual ink cartridges, but replace them with new ones. If you need to know how to replace this ink cartridge (I have this machine too) you just pop open the front rigth side panel and then pull the little plastic purple lever down in front of the YELLOW cartrdige which is labeled with a Y on the pull down cover in front of it, and pull out the old one to dispose of it, take the cap off the new one and push it in-the direction the arrow on the cartridge is facing until it clicks and the purple plastic piece locks it in, then shut the cover and the machine will do a "cleaning" and then you will be ready to print.
Posted on Jun 19, 2009
Ranglo
  • 1194 Answers
SOURCE: canon pixma ip4300 black ink refill. BK and PB
The correct order of install a ink tank (From Left to Right):-
1. CLI-8 Black
2. PGI-5 Black (pigment)
3. CLI-8 Yellow
4. CLI-8 Magenta
5. CLI-8 Cyan
Else you can visit this link and type "correct order of ink tank" in enter your question space.
Good luck...don't forget to rate the solution.
Posted on Feb 22, 2010
Testimonial: "simple and informitive answer to a simple question. excellent"
  • 903 Answers
SOURCE: ricoh cl4000dn toner bottle sensor
The toner bottle sensors don't go bad too often. Do you have an extra yellow toner bottle? Try replacing that first. Compare the tray where the yellow toner bottle sits to the other three colors, and make sure nothing where the toner bottle connects is broken or bent.
Posted on Jun 05, 2010
Epson l200 ink pad error
epson L200 ink pads error Epson L200 is an All-In-One printer, All-In-One printer is a printer unit has multiple function as Scanning, Photocopying, and printing. Epson L200 comes with 6 ink bottle consist of 3 Black Ink, and colored ink, 1 bottle for Cyan, 1 bottle for Magenta, and 1 bottle for Yellow Colors pls check epson L200 ink pads error reset http://www.2012teamtech.com/epson-l200-ink-pads-error
Dec 25, 2013 | Epson L200 Original Continuous Ink Tank...
C-7 980 error code
can you give us the error code?
waitin for your reply.
May 08, 2008 | Kyocera KM-1505 Copier
Canon ip 7240 i used refill ciss but 4 flash
Hi, My name is Liam from rihac, although we do not sell printers I work very closely with them via our inklink products. When a printer flashes 4 times this is a sign that an ink tank is not installed correctly or that the cartridge will need to be replaced as it is low on ink. As you are using a CISS the cartridges will always have ink in them. To bypass this error all you will need to do is press and hold the RESUME button on the printer for 10 seconds and this will turn off the cartridges ink status monitor and allow you to continue printing.
Canon Error Codes
I hope I was of help to you
Oct 30, 2013 | Office Equipment & Supplies
INK PADS FULL
get the ink reset utility with key
May 02, 2013 | Epson L200 Original Continuous Ink Tank...
26.001 error hp 4000
26.0:01 is a bad contact in the Ink Supply System for the yellow ink cartridge. (This can be caused by using non HP OEM ink)
Check that the ISS to Cartridge cable is not damaged and is fully connected to the Ink Supply Tubes PCA.
You can also try switching the magenta contacts with the yellow contacts and see if the problem stays with the yellow, or you now have a magenta problem.
If the problem stays with the yellow, then you will need to replace the Ink Supply Tubes and Trailing Cable.
If the problem moves to the magenta, then you just need to repair or replace the contacts (may just need cleaned)
Good luck !
(My money is on bad compatible or refilled yellow ink cartridges)
Apr 12, 2013 | HP Designjet 4500ps InkJet Printer
Dell a940 error code 50c
From doing my research, I have found that the 50C Error message comes from the cartridge, usually if it has been refilled. If this cartridge is new, please return it to the place of purchase for a new one or a refund.
Here's what happens when you refill the Dell Series 2 ink cartridges. There is a sensor in them that cannot be reset.
Dell ink cartridges can only be purchased at Staples, Walmart or Dell's website.
Dell ink cartridges have a sensor that reports the ink level as low once it reaches a certain level. The sensor can not be reset. If you refill an ink cartridge that previously reported low ink, it may print fine, but the sensor will always report low ink. Buying or replacing ink cartridges with new Dell cartridges will resolve the low ink message.
Dell discourages ink refills. Refilling ink may lead to print quality problems, and even eventual hardware problems.
if u have not refilled ur cartridge and u still get this error i suggest u buy a new cartridge.....
good luck
have a nice day
Jul 08, 2009 | Dell Office Equipment & Supplies
Cartridge error cartridge on right must be replaced
All you have to do is strum the strings in the print that the cartridges ride on. This will tighten them and the error will go away.
Stephen
Jul 17, 2008 | Office Equipment & Supplies
Riso HC5500 error code
Hc5000 System Error S03-231
Jul 09, 2008 | Riso RZ220 Duplicator
I have a solid ink 8560 that has an error 09,037.45:5047, Yellow ink error. How can I resolve?
That is a yellow stick count fault.
1, If you happened to put 2424 ink sticks in it, they have a different bottom and wont actuate the sensor. A stick is either broken, or otherwise stuck in the slot.
That code is the yellow . You could have a bad ink loader, but very unlikely. Check the free movement of the sticks.
Apr 24, 2008 | Office Equipment & Supplies
k24674
jasbo
jasbo
