Question about Marvin W.B. 3150 Convector Heater/Fan
Heater Shuts off at 1500 Watts
I have used this heater and it has worked fine for about a year or so, then recently it will shut off at 1500 watts for no apparant reason. It runs fine at 750 watts. Do I have a bad element?
  • Anonymous Apr 08, 2008
    i want a new heater how can i get one mine just shut off and doesnt go on. its not even a year old. thanks angela
    Problem Solver:
  • 11 Answers
Could be a bad element if the heater does not run at all at 1500w.
If it runs a little before stopping, things could just be dirty causing the thermal sensor to shut it off. A good cleaning is needed in that case.
Good Luck,
Denis
Posted on Oct 11, 2007
SOURCE:
Schematic plf504d thermalinc
My experience with Lasko heaters is with the small portable ceramic types. On mine there are two knobs. One is the "Power"; the fan symbol is for fan only, then (I) Low Power and (II) High Power 1500 watts. The other know is the thermostat from (-) to (+). Set the thermostat towards (+) until the temp in the room is the way you want it. Then turn the thermostat know towards (-) until the unit shuts off. This is now the temperature setting and the heater will cycle on and off to this setting. Hope this helps.
Dec 13, 2013 | Lasko 5610 Baseboard Heater
Heater dont stay lit
I had this problem with a different brand. What was happening was that the wiring to the room where I used it could only support 2000 watts. The heater had an internal circuit breaker. When I turned on my exercise bicycle in that room I was trying to get 2200 watts. I always turned on the bicycle first and that took 700 watts plus the overhead light and so on. Thus when I turned on the heater, as it used up more and more wattage its internal circuit breaker shut off before the circuit breaker in the breaker box. That may not be your problem. This house is forty years old and this "study", the purpose that it was used for by the previous owners must have never reached 2000 watts total. Unfortunately I did. So now I wear a sweatshirt down there at first and take it off when I'm starting to sweat from the exertion of riding the bike. The heater never gets turned on.
Nov 15, 2013 | Dyna-Glo RMC-8001SS Heater
I followed the instructions to a T. I turned my iHeater on using the--O switch located on the back. I adjusted the desired room temperature to 74 degrees. I adjusted the room size to Large. The iHeater...
I would read the customer reviews on this product , looks like nearly 70% of consumers are less than happy with this unit.
1500 watts is the units peak output, and drops to around 600 as it warms up. My hair blower puts out more power.
1500 watts is LESS than the output of a small element on your stove top. The real measure of heat is not watts, its BTUs and btus from gas are much cheaper than they are from electricity.
Nov 12, 2013 | IHeater 1500 Advanced Infrared Heater...
LAK792SGSA Utility Heater: how many watts? What are the dimensions?...
This heater is 1500 watts. It's dimensions are 8 1/4 X 6 1/4 X 14 1/4. It comes in a steel case and is gray in color. Here is the company website http://www.lakewoodeng.com/Category.aspx?cid=1066
It appears that they have filed bankruptcy and now no longer make heaters...just fans.
May 14, 2010 | Lakewood LAK792SGSA Utility Heater
Tankless Watts Water heater (RA_14) 1 element works
you are not to clear on your problem, watts makes the shut off valves, if you have a tankless water heater is it electric> if so you need to contact your installer if they are not in business anymore contact the water heater company, if you are saying that your sut offs aren't working make sure you have power to the unit, with out power the unit will not let the water go thru, that is one of the saftey non flood features,,
May 05, 2009 | Watts & Tankless Water Heater Service...
I would like to know how much is this heater minimum watts? Model: 6507L
with one switch on its 700 watts, second switch is 800 watts, thats 1500 total. even though a 14-2 wire could support this ...I would recommend a 12-2 wire with a 20 amp breaker
Mar 26, 2009 | DeLonghi 6507L Oil Filled Radiator Heater
Rheostat vs. Thermostat Temperature Control
yes, it should work. Just ensure your rheostat will handle up to 1500 watts at reasonable settings. A better approach is a 1500 watt pulse-width modulator circuit that draws little power itself. these are available where power tools are sold (like harborfreight.com and known as speed controllers. I use one for a large air fan in my garage.
Nov 04, 2007 | Presto HeatDish Compact Heater
Basboard heater installation
if the heater is 120 volt or 240 volt its really pretty easy. at either end is a cover. remove the cover and you'll see a wirenut or maybe just two wires. one side has an integral thermostat. connect your supply to the two wires on the thermostat. connect the other end in your breaker box with the appropriate sized circuit breaker. wire size feeding it will depend on its current draw. how many watts is the heater? 1500 watts will draw 6.25 amps at 240 volts so you can use 14 ga wire. 2000 watts will draw 8.3 at 240 volts - so 14 ga is still ok. 2500 watts at 240 draws 10.41 amps. 3000 watts draws 12.5 amps at this stage I'd use 12 gauge on a 20 amp breaker.
Oct 25, 2007 | Fahrenheat Electric Convector Baseboard...
Marvin W.B. 3150 Convector Heater/Fan Logo
375 people viewed this question
Top Marvin Heating & Cooling Experts
Bruce Showalter
john h
Marvin
Marvin
Are you a Marvin Heating and Cooling Expert? Answer questions, earn points and help others
