Question about Aurora Electronics AS1018CD Shredder
Gear replacement is there anyone thats sells gears to fit this model
Can I fix a NB1500 treadmill belt that is bowing in the middle? I've tried adjusting the tighteners on the back and cannot eliminate the bowing in the middle.
No, you need a new belt as it is stretched because that is where it gets pounded all the time. $50 to $100 depending on the quality you choose.
New Balance 1500 Treadmill Walking Belt 20 x 119 - Treadmill Doctor
https://www.treadmilldoctor.com/new-balance-walking-belt-1500
Replacement Walking Belt For The New Balance 1500 Treadmill. Belt size 20" X 119".
New Balance 1500 Treadmill Walking Belt - eBay
www.ebay.com > ... > Fitness Equipment & Gear > Other Fitness Equipment & Gear US$94.99 - ‎In stock
New Balance 1500 Treadmill Walking Belt in Sporting Goods, Fitness, Running & Yoga, Fitness Equipment & Gear, Other Fitness Equipment & Gear ' eBay.
Amazon.com : New Balance Treadmill Running Belt Model 1500 ...
https://www.amazon.com/Balance-Treadmill-Running-Belt-Model/.../B00H4QKAOO Rating: 5 - ‎1 review
This is a 1-ply Residential walking belt, some sellers will try to sell you a 2-ply belt (claiming better quality) for your treadmill, which is not recommended for ...
Amazon.com : Treadmill Doctor Newbalance Treadmill Running Belt ...
https://www.amazon.com/Newbalance-Treadmill-Running-Belt-Model/.../B008EYOF... Amazon.com : Treadmill Doctor Newbalance Treadmill Running Belt Model 1500 : Exercise Treadmill Belts : Sports & Outdoors.
NB1500 treadmill belt Google Search
Aug 14, 2017 | Exercise & Fitness
Reducing gear teeth missing on vtech remote racer smart car... i need a new gear? where do i buy
try seeking assistance from hobbyist stores that sells parts for mini RC cars, they often sell gears to help upgrade their RC cars, you might find a gear that fits your needs.
Mar 11, 2013 | Vtech Remote Racer Smart Car
Bernina 740 Replacement gear needed
check with these sites about parts
sewvacdoctor.com
a1sewingmachines.com
Oct 15, 2012 | Bernina Sewing Machines
I need a new worm gear for my fisher price starlight papasan cradle swing.
I found a set of worm gears that has 2 of the gears you need.
Google search, worm gear svm-103. It is a packet with a lot of worm gears but the 2 big ones work perfectly.
Jul 05, 2012 | Fisher Price Starlight Papasan Cradle...
I have a KitchenAid stand mixer model KT2651X. It recently ground down the worm gear follower, which I purchased a new one along with a new worm gear because this is not the first time it ground down that...
It is not a good idea to modify anything in the unit to make part(s)
designed for another model fit. The KT and KP models have different
part numbers for the motor. I still don't understand why do you have to
change motor in the first place, just because the Worm Gear Follower
has to be replaced. Something is telling me, you have just purchased
the wrong part (Follower). The KT2651x is similar to the KP26xxx
latest models and the Worm Gear does not come with the Follower.
(i.e. they are 2 different distinct parts)
Jul 20, 2011 | KitchenAid Food Mixers
1984 Honda XR250 with wrong clutch, I think.
The kick shaft gear, idler gear, and clutch drum gear on the 1985 xr250 and below are smaller tooth gears than 1986 and newer. I have an 85 and an 88. I had to replace the 85 kick gears 3 times. The last time I replaced them I found that the larger gears on the 88 fit as long as you replace only the gears. The kick gear comes off the shaft and the larger tooth gear fits on the shaft. The larger idler gear fits where the smaller tooth idler was and the drum gear comes out and the larger tooth gear will fit there. Or the drum you have with the larger gear will now fit the other gears. This is a better solution than finding another drum with the smaller tooth gear because the smaller tooth gears will not last. I hope this helps.
Jun 09, 2009 | 1985 Honda XR 250 R
Stripped gear in motor
I just spoke with Nostalgia Electrics Customer Service and they stated that they do not sell replacement parts of any type for this piece of CR4P! Seriously... why would anyone design a nylon gear in between two metal gears unless it was designed to fail.
Feb 18, 2009 | Bond Helman Old-Fashioned Movie Time...
Nylon gear stripped
This is how a got my hard to fine gear!
Contact Michael Business Machines for your local dealer 1-800-223-2508
Good luck, Tom
Feb 15, 2009 | Fellowes DM15C Shredder
Part not available
Thanks for getting back.
I've searched your model, and found both the main icemaker gear and a complete replacement icemaker unit as a drop-in replacement.
Gear is listed at $5.25 , and complete unit at $ 81.41.
It is usually the fingers or the gear teeth that break.
Try this page for ordering information - Both are held in stock
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=114043
If I've identified the wrong part - please get back to me If I can help further
Thanks for using Fixya.
Jan 01, 2009 | Kenmore 57029 Side by Side Refrigerator
Aurora Electronics AS1018CD Shredder Logo
64 people viewed this question
Top Aurora Electronics Office Equipment & Supplies Experts
k24674
skiffy99
skiffy99
Level 1 Expert
Dabu42
Level 1 Expert
Are you an Aurora Electronics Office Equipment and Supply Expert? Answer questions, earn points and help others
