Question about Nordic Track NordicTrack T5 zi Treadmill
Treadmill is stuck in up position
Treadmill stuck in up position
Treadmill is stuck in the full incline position
Tim may not be a easy fix, you may have to dismantle and lube riser slides as it sounds like they are stuck
Jan 17, 2016 | Exercise & Fitness
Incline stuck treadmill
Run the software calibration for easy diagnostic and fix it. Lube the incline mechanism. Go to Hood cover motor and follow the steps or read your owner manual.
God bless you
Oct 15, 2013 | Icon Epic T60 Treadmill
Treadmill is stuck in fastest position and will not change
1) LUBe the elevation motor, in shaft and gear
2) adjust the small POTentiomenter for to liberate the elevation motor
3) clean the relais contacts, and tight every connector.
see the diagram and fix it.
Jan 18, 2013 | Proform 860 Competitor Treadmill
My treadmill is stuck in incline
please RUN the software calibration for easy diagnose, troubleshooting, and fix it.
see the diagram attached, for troubleshooting too.see the b.diagram
Happy New Year.God bless you
Dec 31, 2012 | Treadmill Doctor Encore 1500 Treadmill...
I have a T85 Treadmill and the running platform is stuck in the highest position. A message on the display says 'check Transmitter'. Is there anything I can do to fix it?
PLeae RUN the software calibration for troubleshooting go under the HOOD motor and read the instruction steps, or go to instr. manual in how to enter in the s.calibration and fix it.
However you can measure the input voltage elevation motor, and lube the shafte, gear, see the photo and diagram attached.
God bless you
Nov 18, 2012 | Tunturi T85 Treadmill
Proform 860 treadmill, want to undo incline feature, & use it without it
Run the software calibration for easy diagnose, troubleshooting, and fix it.
God bless you
May 16, 2012 | Proform 860 Competitor Treadmill
Epic treadmill t60 is stuck in max incline how do
Usually when stuck at the max up position it indicates that you may need a new incline motor. It is not the sensor. I have been repairing treadmills for 15 years and incline sensors seldom if ever go bad. If can isolate the incline motor using a 110 volt power cord, this may un-jam the motor and get it back down to 0%.
I use www.treadmillpartszone.com for parts.
Jul 25, 2010 | Icon Epic T60 Treadmill
Proform 2500 treadmill stuck in incline position
Under the motor shroud their is a instruction mini manual it will have a how to calibrate the incline motor, if that does not fix it then you may have to manually adjust the incline motor and sometimes it will take awhile to realign . If that does not work replacing the motor maybe the only option
May 02, 2010 | Exercise & Fitness
Nordic Track NordicTrack T5 zi Treadmill Logo
21 people viewed this question
Top Nordic Track Exercise & Fitness Experts
Matt Olenzek
Matt Olenzek
Ross Metcalfe
Ross Metcalfe
Electro Med Services...
Are you a Nordic Track Exercise and Fitnes Expert? Answer questions, earn points and help others
