Question about Acer Aspire 4730-4516 Notebook
How to fix bootmgr
Bootmgr
    Top Expert:
  • Acer Master
  • 21,550 Answers
Reinstall Windows.
Posted on Nov 22, 2013
How do i fix bootmgr missing on a dell optiplex 760
This is a symptom of a failed hard drive or corrupted operating system. You can try to reinstall Windows however any errors in doing so may indicate your drive needs to be replaced. Online Virus Removal 39 99 Online Virus Removal and Online PC Help
Mar 25, 2015 | Dell OptiPlex Computers & Internet
Bootmgr is missing on another computer how to fix
http://pcsupport.about.com/od/findbyerrormessage/a/bootmgr-is-missing.htm
This has happened to me a few times. Just go to that link and it will solve your problem. :)
Apr 17, 2013 | Compaq Computers & Internet
My computer is saying BootMgr is missing !!!
Bootmgr is missing is an error from your system. The most common reasons for BOOTMGR errors include corrupt and misconfigured files, hard drive and operating system upgrade issues, corrupt hard drive sectors, an outdated BIOS, and damaged or loose hard drive interface cables. you can fix it by the following steps:
Firstly, create a bootable CD/USB byWindows Boot GeniusSecondly, set the computer boot from CD/USB after enter into the BIOS menu.Thirdly, start Fix "Bootmgr is missing" with the CD/USB created at the first step.
Source:http://www.windowspasswordsrecovery.com/fix-windows/bootmgr-is-missing.html
Feb 19, 2013 | HP Computers & Internet
On display - BOOTMGR IS COMPRESSED i pressed ctrl -alt -del but nothing happened kindly advise next step laptop acer extensa 5620
Here is the fix for Bootmgr problem in Vista/7
Bootmgr Windows Vista/7
For windows XP : Try to fix your windows by selecting repair option.
  • Boot your computer with the Windows XP CD
  • At the first screen select R to repair
  • If you got a command prompt, just type on the command prompt "fixboot" then hit enter.
If those information did not help you with the bootmgr issue, then you might need to reinstall windows on your computer.
Hope this will help
Sep 12, 2011 | Computers & Internet
Bootmgr missing
Causes of BOOTMGR ErrorsThere are a number of possible causes for BOOTMGR errors, including the most common "BOOTMGR is missing" error message.
The most common reasons for BOOTMGR errors include corrupt and misconfigured files, hard drive and operating system upgrade issues, corrupt hard drive sectors, an outdated BIOS, and damaged or loose IDE cables.
Another reason you might see BOOTMGR errors is if your PC is trying to boot from a hard drive or flash drive that is not properly configured to be booted from. In other words, it's trying to boot from a non-bootable source. This also would apply to media on an optical drive or floppy drive that you're trying to boot from. Fixes for BOOTMGR Errors
  1. Restart the PC. The BOOTMGR error could be a fluke.
  2. Perform a startup repair of Windows. This type of installation should replace any missing or corrupt files, including BOOTMGR. Continue troubleshooting if this does not resolve the issue.
  3. Check your floppy and optical drives for media. Often times, the "BOOTMGR is Missing" error will appear if your PC is trying to boot to a non-bootable floppy disk or CD/DVD.
    Note: If you find that this is the cause of your issue and it's happening regularly, you might want to consider changing the boot order in BIOS so the hard drive is listed as the first boot device.
  4. Check the hard drive and other drive settings in BIOS and ensure they are correct. The BIOS configuration tells the computer how to use a drive so incorrect settings can cause problems, including BOOTMGR errors.
    Note: There's usually an Auto setting in BIOS for hard disk and optical drive configurations which is usually a safe bet if you're not sure what to do.
  5. Reseat all internal data and power cables. BOOTMGR error messages could be caused by loose or malfunctioning power or controller cables.
    Try replacing the PATA or SATA cable if you suspect it might be faulty.
  6. Update your motherboard's BIOS. An outdated BIOS version can sometimes cause the "BOOTMGR is Missing" error.
  7. Perform a clean installation of Windows. This type of installation will completely remove Windows from your PC and install it again from scratch. While this will almost certainly resolve any BOOTMGR errors, it's a time consuming process due to the fact that all of your data must be backed up and then later restored.
    If you can't gain access to your files to back them up, understand that you will lose them all if you continue with a clean installation of Windows.
  8. Replace the hard drive and then perform a new installation of Windows. If all else has failed, including the clean installation from the last step, you're most likely facing a hardware issue with your hard drive.
BOOTMGR Errors Apply To BOOTMGR issues apply to Windows 7 and Windows Vista operating systems only. Windows XP does not utilize BOOTMGR. The equivalent function in Windows XP is NTLDR
Whish you the best luck.
Mar 06, 2011 | HP Computers & Internet
Bootmgr is missing
Here is a good step by step for this. It is writen for Windows Vista but should also work for Windows 7.
http://www.howtogeek.com/howto/windows-vista/fixing-bootmgr-is-missing-error-while-trying-to-boot-windows-vista/
Mar 01, 2011 | Acer Aspire 5315 Notebook
Bootmgr is compressed Press cntrl+alt+del to restart
I hope you have the Operating System CD, Incase you have it then try booting from the CD and get to recovery console. Once you are in the Recovery console try typing the below mentioned commands and HIT enter after each line.
attrib bootmgr -s -r -h
del bootmgr
ren temp bootmgr
attrib bootmgr -a +s +r +h
if that doesn't fix then try
bootrec /fixboot
bootrec /fixmbr
this should fix the problem.
Dec 11, 2010 | Computers & Internet
Will not open. states BOOTMGR is missing
Follow this link for instructions on how to fix.
Oct 07, 2009 | Dell Inspiron B130 Notebook
Acer Aspire 4730-4516 Notebook Logo
26 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
