Question about Samsung HM1100 Bluetooth Headset
Pair laptop - Samsung HM1100 Bluetooth Headset
Pairing Code for ASUS r503c?
If you are talking about connecting a Bluetooth device to your laptop the laptop would not typically have a paring code. The device however may.
For example you would not be able to enter a code into Bluetooth headset as it does not have a keypad, so a code is pre-set into the device. Whatever the device you are trying to connect with see the manufactures manual or try 0000 as the code.
If however you are trying to pair with something like a mobile phone (providing both Bluetooth devices are set to "Discoverable") then you should be able to start the pairing from either the laptop or phone. Once the 1st device (That you has started the search/pairing from) asks for the pairing code you may enter ANY 4 DIGIT CODE OF YOUR CHOOSING. Once the is done you should be prompted to do the same on the 2nd device and you simply need to enter the SAME 4 DIGIT CODE.
This should complete the pairing.
Nov 22, 2013 | Computers & Internet
I dont know where to find pairing code
If you are connecting to Bluetooth headset, check the manual of Headset to find default pairing code.
If you are connecting to other mobile phone or laptop, you have to enter any pairing code you want and then enter the same pairing code to other mobile or laptop and both devices will be paired.
May 25, 2011 | Cell Phones
I need to install bluetooth modem for my laptop HP compaq mini110c-1111ev pc
I am glad to HELP YOU!
All you have to do is to PAIR the both devices. So TURN ON the bluetooth on your HP mini and turn ON the Bluetooth Modem.
Right-click on the Bluetooth icon on your laptop and choose ADD DEVICE and let it discover the modem.
Once discovered add it as a paired device and [... probably] you ill have to input the PAIRING CODE for your modem.
Once paired click OK and you're good to go!
GOOD LUCK!
________________
Windows 7 tips
Apr 24, 2011 | Computers & Internet
Bluetooth Notebook 5000 Mouse will not connect. The green light comes on and then goes off. The bluetooth light on the laptop is on. Just changed the batteries. What to do?
You may just need to re-PAIR it. You need to press and hold the Pairing button until you get a solid blue light then it is in pairing mode, you can then discover it on your laptop and complete the pairing.
Jul 12, 2010 | Microsoft Bluetooth 5000 Mouse
Can anyone please help, I have an Acer 5735, with a blutooth button but can't get it to work
What are you try to pair to the laptop?
Both the laptop and the item you ar trying to pair together have to be in pairing mode, and they have to be compatible with each other.
Nov 08, 2009 | Acer Aspire 5735 Notebook
What is my Laptop's Bluetooth Pairing "Passcode?"
u dont need to look for a pass code anywhere.
when ur laptop finds a new device and when u click on pair it. just put ant thing as code like 1234. then in ur nokia mobile when it ask fort code write over there 1234. and u r done :-)
Jun 18, 2009 | HP Compaq nw8440 Notebook
Pairing H710 to a computer
Well. This is probably not a solution you guys want to hear, but it just worked. I left it for months, maybe it was just the time, or a recharge needed to wipe out one of the paired devices in memory, but it just paired with my laptop like that. Used it for while too with Skype.
I am also using the new Windows Seven RC this time around, maybe it was a Beta issue, that got fixed with the RC.
Feb 11, 2009 | Motorola Mobility H710 Bluetooth Headset
Samsung HM1100 Bluetooth Headset Logo
253 people viewed this question
Top Samsung Radio Communications Experts
Michael Vincent Cruz
Are you a Samsung Radio Communication Expert? Answer questions, earn points and help others
