Revue slide tray - Office Equipment & Supplies
    President:
  • 412 Answers
Can you provide a more complete description of the issue you are experiencing, please?? I will attempt to assist you... Thanks!
Jim
Posted on Nov 21, 2013
How do i get a Regents HT-391 surround sound system to play sound from my Logitech Revue with Google TV?
More than likely the regent system is needing and alternate audio source, via- analog, digital coax, optical ect... HAs it always been this way, or use to work?
May 22, 2014 | Logitech Revue with Google TV Refurbished
Lift gate tray
No. The slide tray should rotate when the forward or reverse buttons are pushed. Slides are not required for correct actuation of the tray. Before attempting any adjustment, try a few different trays (it may be a tray issue!). A 140-slide tray will be much tougher to get correct movement from than with a 80-slide tray on an older slide projector.... The 140 tray pushes the interface specification between a tray & a projector to the max.
Oct 13, 2013 | Kodak Carousel 4400 Slide Projector
Kodak 140 slide carousel trays jam
The 140 tray with older slides and an older projector is a gamble with slide jams every time!! Slides have a natural curve that gets bigger over time. In addition, as slides age, the corners will begin to de-laminate (aka: "dog-eared" slide). Because the slide slot in a 140-tray is SO NARROW, the least little deformation of the slide from normal will cause the slides not to drop. My recommendation, given the age of the projector, trays and slides, is to get rid of those 140 trays and stick with 80-slide trays. Good Luck !! Jim
Sep 16, 2013 | Kodak Carousel 4400 Slide Projector
Will slides back from 1960 work in a Kodak Carousel Slide Projector?
As long as the slide film is in 2"x2" mounts, yes! I would advise you to use an 80-slide tray as opposed to a 140-slide tray. The individual slide compartments in an 80-slide tray are wider, making it more forgiving to older, possibly warped slides. 80-slide trays can still be purchased from: www.vinevalleyimaging.com. Good Luck! Jim
Jan 16, 2013 | Kodak Carousel 4600 Slide Projector
Retrive incredimail email with revue K700
Pls provide more info on the mail provider
Nov 14, 2012 | Computers & Internet
Need to record
Google TV does not allow you to record any shows.
You need to pick up a DVR (cable box) to do that.
Mar 14, 2012 | Logitech Revue Companion Box with Google...
Hello,We purchased a Logitech Revue today and it will NOT work?!? First, Is the green light on the keyboard suppose to STAY lit? Could be a bad keyboard?
No, the green light goes out after about 10 seconds: saves battery.You don't mention any other problems, but I will make a suggestion. Start with the simplest setup. Run a HDMI cable from the Revue to the TV. Nothing else. Turn on the Revue and the keyboard and follow on-screen instructions. You must know your Wi-Fi address.
Oct 23, 2011 | Logitech Cordless Mouse
Snow on tv cant get bk to pic
Hi nelle_king my name is MikeHouston of DISH Network. There are a couple things we can do to get thatpicture back. What you will need to do is make sure the TV is on channel 3 orthe right input, and if the picture is still snowy and we are on the correctchannel/input you will need to reset the receiver by unplugging it for 10seconds and plugging it back in. After you plug it back in it will power up byitself and you should see the DISH Network screen. I will send the steps tohelp with the setup. b> # Sequentially follow the below steps until problem is resolved or until instructed to skip to another step 1 Verify HDMI Connections Verify HDMI cables are connected from the DISH receiver HDMI Out to the HDMI In of the Revue, and the HDMI Out of the Revue to the HDMI In of the TV. 2 Reset Revue and DISH Receiver Unplug both the Revue and DISH receiver for 10 seconds and plug back in. It may take up to 5 minutes for the reset process to be completed. 3 Check Receiver-to-TV Configuration Check that the wiring between your DISH receiver and your TV is configured properly using http://www.dish.com/wiring. 4 Secure Receiver-to-TV Connections Check that the connections between your DISH receiver, your TV, and any component(s) (VCR, DVD Player, etc.) in between are secure. 5 Bypass Revue Bypass the Revue and directly connect the DISH receiver to the TV using an HDMI cable.
Feb 02, 2011 | Toshiba Televison & Video
My kodak 600H projector tray will not move to the release position? any suggestions.
You may just have a slide jam (particularly common with older slides in 140-Slide Trays).
First of all, you need to get the tray removed. At the center of the tray is the hub, and an emergency tray release slot. Make sure the slide tray locking ring is in place and tight(!), then insert a quarter in the emergency tray release slot and turn, lifting the tray at the same time. One slide will probably fall out. Replace the slide in the tray with the same orientation as the other slides in the tray (markings, slide#, etc.). Then with the tray upside down (now you see why I told you to make sure the slide tray locking ring was in place and tight), rotate the metal bottom plate back to the "zero" position.
Once the tray is removed, cycle the projector 4 or 5 times, then re-insert the tray. If the problem persists, you may have warped slides (get them re-mounted or be sure to use 80-Slide Trays rather than 140 Slide Trays), or you could have a jammed slide change mechanism. And because we're talking about a Model 600H here, it may be cheaper to buy a used projector online than have it repaired. Good Luck !!
Dec 20, 2010 | Kodak Office Equipment & Supplies
37 people viewed this question
jasbo
jasbo
