Question about Aurora Electronics AS1018CD Shredder
Replace gear - Aurora Electronics AS1018CD Shredder
Can any one help me with advice on how to repair the 5th gear on my Chana 1300 Club Star? Greetings, Johan.
Replace the selector and check adjustment. Only replace the gearing if teeth are badly worn as that alone will not cause it to jump out of gear.
Aug 08, 2017 | Cars & Trucks
My 99 z24 cavalier standerd shift it will not shift into 3rd gear
The gear may be stripped, can't catch other gear,have you been grinding this gear,will have to go into transmission and replace third gear, will have to wind second gear out and shift to 4th gear.May be better and cheaper to get a remanufactured transmission cause all parts are new versus just 3rd gear being replaced.
Dec 24, 2012 | 1999 Chevrolet Cavalier
How to remove rack and pinion from 99 chrysler lhs
There are few help links showing exact accurate procedure to replace Rack and Pinion. Click the link below and follow the procedure:-----
Pinion Seal Replace on Dodge Dakota? http://howtobyme.blogspot.in/2012/04/pinion-seal-replace-on-dodge-dakota.html
How to Replace a Rear Pinion Seal.
http://schematicsdiagram.blogspot.com/2011/07/how-to-replace-rear-pinion-seal.html
How to replace Power steering rack and pinion gear on Chevy Silverado 2500 HD? http://technoanswers.blogspot.in/2012/02/how-to-replace-power-steering-rack-and.html
How to replace Power Rack and Pinion Steering Gear on Acura Car Models? http://repairhelpcenter.blogspot.com/2011/11/how-to-replace-power-rack-and-pinion.html
How to replace power rack and pinion steering gear on Toyota cruiser? http://repairhelpcenter.blogspot.in/2012/02/how-to-replace-power-rack-and-pinion.html
Front Drive Pinion Seal Removal on Ford Explorer? http://repairhelpcenter.blogspot.in/2012/03/front-drive-pinion-seal-removal-on-ford.html
How to Replace Driveshaft, Pinion Flange & Seal?
http://repairhelpcenter.blogspot.in/2012/03/how-to-replace-driveshaft-pinion-flange.html
How to Replace Power Rack & Pinion Steering Gear On 2007 Ford Taurus? http://repairhelpcenter.blogspot.in/2012/03/how-to-replace-power-rack-pinion.html
How to Remove Power Rack & Pinion Steering Gear on Ford Windstar? http://repairhelpcenter.blogspot.in/2012/03/how-to-remove-power-rack-pinion.html
Power Rack & Pinion Steering Gear replacing details for Buick Park Avenue and Pontiac Bonneville
http://repairhelpcenter.blogspot.in/2012/03/power-rack-pinion-steering-gear.html
How to Replace Power Rack & Pinion Steering Gear on Mercedes Benz Truck? http://howtobyme.blogspot.in/2012/03/how-to-replace-power-rack-pinion.html
How to replace Power Rack & Pinion Steering Gear on Toyota 4Runner? http://howtobyme.blogspot.in/2012/03/how-to-replace-power-rack-pinion_27.html
Power Rack & Pinion Steering Gear Replacing on Toyota Land Cruiser & Sequoia? http://schematicsdiagram.blogspot.in/2012/03/power-rack-pinion-steering-gear.html
Power Rack & Pinion Steering Gear Removal on Toyota RAV4? http://repairhelpcenter.blogspot.in/2012/03/power-rack-pinion-steering-gear-removal.html
How to Replace Power Rack & Pinion Steering Gear on Toyota Sienna? http://technoanswers.blogspot.in/2012/03/how-to-replace-power-rack-pinion.html
These details will help.
Thanks.
Nov 23, 2012 | Cars & Trucks
Replacing the gear on makita angle grinder
Are you replacing both gears? The armature gear (pinion) is usually held on with a nut or else is pressed on. The spindle gear is also pressed on. Most spindle gears will come as an assembly with the gear and spindle and housing all together.
If yours doesn't, then the spindle will need to be pressed out of the housing, and then the gear pressed off of the spindle. (Always replace the grease as well when replacing gears.)
Mar 31, 2012 | Makita Saws
When you put it in 4th gear in grinds and sounds like the chain is trying to jump off
There are a couple of stripped gears in the transmission. The case will need to be split to locate and replace the bad gears. Be sure to replace not only the stripped gear(s) but also replace any gears that the gear teeth mesh with. Even if they look okay, they were exposed to the same punishment as the stripped gear. If you din't replace the "good" gears you get to do the repair twice in just a short time. Please rate my answer. Thanks. tombones49_57.gif
Apr 06, 2011 | Factory bike Chrono SM 250 Motorcycles
One of the heater gears ( shield ) is continuously broken several times
take out the gear which drives the broken gear then replace the broken with a new gear, check manyally driving the gear,which part or gear causing resistance in the smooth operation, replace the faulty part/gear.lubricate moving parts.
Jan 12, 2011 | Canon NP 6050 Copier
Got a 02' 125 ttr and it make a knocking noise in first gear? shifts fine and no other noise in other gears.
You have a broken tooth on the first gear set. This means two gears will need replaced; the drive gear and the driven gear in first gear range. DON'T just replace the gear with the broken tooth. Replace the gear it meshes with also.
Jul 23, 2009 | 2002 Yamaha TT-R 125 L
I have a 1984 honda vf1000 motorcycle and 2nd gear is going do I have to replace all the gears or just 2nd gear
Replace gears in sets, the bad gear and the gear it meshes with. In what way is 2nd gear going bad? The gear may be fine and the shift fork is the problem.
Google " vintage honda motorcycle parts " and google " honda motorcycle salvage " for parts.
May 05, 2009 | 1984 Honda VF 1000 R
Gear problem with Kia MENTOR (I couldnt select this option sorry)
Your car gear box is completely damaged.
I recommend you replace it with a brand new gear-box.
Good luck.
Please rate this.
Apr 27, 2009 | 1997 Kia Sephia
Slippage in second gear,pulls fine in all other gears and shifts fine,feels like broken tooth off gear or something of that nature
A broken gear tooth will cause a clicking sound. Start out in 2nd gear going slow. Hear any clicking? If so then TWO gears need to be replaced > the broken gear and the gear that meshes with it. If enough pressure was on a gear tooth to cause it to break, then similar pressure was on the gear it was engaged in. The gear may look okay, but it isn't. ALWAYS replace gears in sets.
Please rate this answer. Thanks John!
Apr 17, 2009 | 1997 kawasaki VN 800 Vulcan Classic
Aurora Electronics AS1018CD Shredder Logo
41 people viewed this question
Top Aurora Electronics Office Equipment & Supplies Experts
k24674
skiffy99
skiffy99
Level 1 Expert
Dabu42
Level 1 Expert
Are you an Aurora Electronics Office Equipment and Supply Expert? Answer questions, earn points and help others
