Question about All Land Networking Irulu 7 Android 4.0 Os Cortex A10 5 Points Multi Capacitive Touchscreen Pocket Tablet Google Wifi 3g Internet Support Hdmi Flash 11.1 With 4gb Built-in Capacity Black Color
I want to insert sim card in my irulu AL101 tablet
My problem is that i don,t know how to insert SIM card in my tablet can you please show me the procedure on how to insert s o that i have access to the 3G or 4G network?
I found my old IRulu AL101 in my closet and i plugged it in but all its doing is showing a red light
let it rest in the charger overnight, the battery has become so low it needs a firm charge first to be able to work again might be working after charging it for 1 hour even but i would still let it charge overnight..:)
Jun 02, 2016 | Irulu 10.1"tft Wifi 3g Android 2.2 Tablet...
How & where to insert Sim cards
Hi
I haven't had much luck with finding a manual for this machine to tell you precisely where a SIM card would go, but on the specifications toward the bottom of this page:
iRulu 7 WCDMA 3G Black Tablet PC Dual Core Cam 4GB Android 4 2 Bluetooth...
it quite clearly shows it as a dual SIM machine. This may mean that you have the SIM in the wrong slot, or yoou may need 2 to make it operate. Not having found a manual I' m afraid I can't be more specific.
Cheers
Jan 01, 2015 | Irulu 7 inch Android Tablet PC, 4.2 Jelly...
Can't insect my sim card, can u help
I'm assuming you mean "insert" rather some crawly creature. SD cards are designed to only fully seat in one way. I'd suggest turning the card over and trying again. Take a flashlight and look in the slot to be sure something isn't blocking (remember VCR's,lol). It should slide in with little pressure, the last 1/4" might feel tighter but that's a spring compressing to take it out. Finally have you tried the card in another machine?
Good luck
Nov 27, 2014 | Irulu 7" 4gb Google Android 2.3...
Where do i put the sim card in my irulu tablet phone".
Other than WIFI, it support 3G (3G dongle not include).
There is no sim card slot, you must use a 3g usb dongle.
Oct 17, 2014 | Irulu 7" Google Android 4.0 Capacitive...
I just purchased a 7" irulu android w/2G and it supports a 3G speed but I want the 3G connection but I need to know what sim card would I need or what is the best option for my irulu 7" to give it the...
Most sim cards will now support 3g, best to check directly with the provider, however you do realise that you need a dongle to use 3g with this tablet, the sim card would go in the dongle and it may well be a micro sim depending on the dongle.
Jun 25, 2014 | Cell Phones
Lg v909 tablet keeps rebooting
My LG v909 is complaining of 'too many pattern attempts'. Its asking for my gmail login credentials however it has no internet though a data sim card has been inserted. Anytime I insert/remove the sim card the desktop shows for only 5seconds and reboots. Can anybody help me please ?
Jan 24, 2013 | LG Optimus V909 Android
My tablet sim function is not working
Remove sim card and reinsert ,make sure it's all the way in.
Oct 03, 2017 | Tablets & eReaders
M update my nokia C5 but sume problem in between the updation. and he is not update properly and when m insert sim card into the phone (sim card registration failed) message show on the screen... when
First All Check:
1.Confirm whether same sim card is working in other h.s or not.
2.Make sure the sim slot is o.k. only try these two.
3.If all the above steps fails, check the SIM card connector pins for damage.
if so try to get serviced.
4.if ur sim card is good then it is problum form sim card ic u have u raplace it with SMD.
u can make it jumper mean u can fix this prob with out sim card is for this contact.
5.take sim connector slight up by pin then cheak by inserting sim.
6.hot air gun on sim i.c. then cheak it.
Last Option:
IF make sure that the sim card hasn't been damamged at all sO Please You Go to Service
& Sim Office and Get the Duplicate Sim Same Your No From Office Oprator
Problem will Solved Quickly
Jul 24, 2012 | Nokia C5 Cell Phone
Where to insert sim card?
I'm sorry for the difficulties you're experiencing in inserting the SIM card in the tablet PC. Please follow the below steps to insert the SIM.
Thanks for understanding.
Please let me know if you require further assistance.
Jul 02, 2011 | Samsung Galaxy Tab Tablet PC
I have problem to my phone (N73), if i insert sim card to slot sim card my phone (N73), it show msg "sim card not valid"... any solution to my sim card problem
Hi
please do these tips :
insure that your SIM card working properly test it in another phone
if it work so clean the SIM card place , and test it while you push the battery to keep SIM in its place .
if that don't help try to software the device .
if that don't help so you must check about SIM driver(IC connect SIM base with CPU).
I hope that helps you
Apr 25, 2011 | Nokia N73 Music Edition Smartphone
All Land Networking Irulu 7 Android 4.0 Os Cortex A10 5 Points Multi Capacitive Touchscreen Pocket Tablet Google Wifi 3g Internet Support Hdmi Flash 11.1 With 4gb Built-in Capacity Black Color Logo
37 people viewed this question
Top All Land Networking Video Cameras Experts
abdul rauf
abdul rauf
ray gallant
golisatyaprasad
Are you an All Land Networking Video Camera Expert? Answer questions, earn points and help others
