Halogen work with AC or DC voltage ... 12 volt LED bulbs are DC.
Check that transformer delivers DC, or buy 100 watt IP67 LED driver.
Keep in mind the lutron DV-600 is rated for incandescent and halogen loads, and may not function as expected when connected to inductive load like transformer or driver.
It will not light manually as the ignition probe is electronically controlled. If it doesn't stay lit normally then it will more then likely not stay lit when trying to light manually.
First clean out pilot light with can of air , or blow down it with a tude. Then brush electrode clean with a clean paint brush ,chech to see if electrode is in the right postion to light the gas not too far away and the spark is strong , Clean thermopile head if fitted, then check thermocuople /thermopile connections are tight . see if this helps .
If it lights, use a c-clamp or something to keep the fuel button pressed in until it will stay lit without the button pressed. This took me 3 hours before it would finally keep running normally. If that doesn't work, the jet and engine chamber might need cleaning. This takes some additional work and you may need to make a new fiberglass gasket since the original one falls apart after a few seasons.
I had the same problem. i figured out i didnt have the 15 amp fuse in. Its a blue fuse just like the one you use in your car. fuse goes in the slot to the left of the power LED's. this solved my problem hopefully it solves your problem.
2005CHEVROLETTrailblazer Low beam headlamp 9006 9006SU Silverstar ULTRA for Ultra Night Vision - The Whitest and Brightest Halogen 9006ST Silverstar High Performance Lighting: The Whiter and Brighter Halogen 9006EB EcoBright - Your Environmental Choice 9006XV XtraVision Halogen - The Brighter Light 9006CB Cool Blue Halogen - The Whiter Light High beam headlamp 9005 9005SU Silverstar ULTRA for Ultra Night Vision - The Whitest and Brightest Halogen 9005ST Silverstar High Performance Lighting: The Whiter and Brighter Halogen 9005EB EcoBright - Your Environmental Choice 9005XV XtraVision Halogen - The Brighter Light 9005CB Cool Blue Halogen - The Whiter Light Parking light 3757ALL Front turn signal 3757ALL Rear turn signal 3157LL Tail light 3157LL Stop light 3157LL High mount stop light Assembly Fog/Driving light 880 880ST Silverstar High Performance Lighting: The Whiter and Brighter Halogen 893 893ST Silverstar High Performance Lighting: The Whiter and Brighter Halogen License plate 2825 2825LL Long Life Upgrade: Up to twice the life of the standard lamp Back up light 3157LL Front sidemarker 194 194LL Long Life Upgrade: Up to twice the life of the standard lamp Glove box 194 194LL Long Life Upgrade: Up to twice the life of the standard lamp Map light 194 194LL Long Life Upgrade: Up to twice the life of the standard lamp Dome light 212-2 Step/Courtesy light 194 194LL Long Life Upgrade: Up to twice the life of the standard lamp Trunk/Cargo area 212-2
